Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2020
Old 08-11-2013, 08:29 PM   #1
kmook
Member#: 146168
2017 Impreza
Default Kmook's How To: Evap + Charcoal Canister removal
Hi,
So if you are like me you like to clean stuff up as much as possible and are always tinkering. I've always removed the evap parts in the engine bay on my subies but decided to remove the charcoal canister system as well this time. I took pics in case anyone else would like to do this. (Note there is no performance gain, i am not responsible if this damages your vehicle in any way, this is for appearance and simplifying things, and you will of course have to have your tuner delete codes)
Engine bay clean up:
Remove all parts marked as red:
Which are these parts:
Afterwards cap both items marked A.
Item B can be capped or left vented, doesn't matter. (In my pic I don't have the A port on the right side capped as I'm using it for a vacuum source for a 3bar map, otherwise id have it capped):
Rear end cleanup:
Afterwards we will put a breather on A as it needs to be vented since it goes to the gas tank (breather is just to be cautious and not let anything go in). B can be cut shorter and left alone as it goes to B in the engine bay. C is left vented as that is for the fuel filler overflow. D is the harness which you just zip tie up.
After looks nice and cleaned up:
kmook is offline   Reply With Quote
Old 08-11-2013, 09:42 PM   #2
projectQWKSLVR
Member#: 285270
03 WRX
Nice write up, just needs a disclaimer.
projectQWKSLVR is offline   Reply With Quote
Old 08-11-2013, 09:48 PM   #3
kmook
Member#: 146168
2017 Impreza
Thanks, and added that
Old 08-11-2013, 11:46 PM   #4
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Great write up! Been wanting to do this to my car. Quick question. Would I be able to just remove the canister and leave all the engine bay stuff intact? I run a stand alone and am not sure if it would be any different.
Thanks
recce02 is offline   Reply With Quote
Old 08-11-2013, 11:49 PM   #5
kmook
Member#: 146168
2017 Impreza
Thanks
Yeh you can just do the engine bay half, the rear half, or both.
Old 08-12-2013, 12:13 AM   #6
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Awesome! And thanks again for the write up.
Old 04-20-2014, 10:41 PM   #7
StuartR
Member#: 373039
pulled mine out today, went really smoothly.
I was having an issue with fuel ups, the system would pressurize and keep tripping the pump nozzle, would take 15 minutes to get a full tank. After this that problem has gone away. Now all I need to do if find a way to permanently clear the code...
StuartR is offline   Reply With Quote
Old 04-23-2014, 01:17 PM   #8
Blackcloud556
Member#: 337190
Nice. Ill have to look into yanking mine out..
THanks!
Blackcloud556 is offline   Reply With Quote
Old 04-23-2014, 06:47 PM   #9
kmook
Member#: 146168
2017 Impreza
You're welcome, Glad you found it useful
Old 05-10-2014, 04:59 PM   #10
wrxguy90
Member#: 390443
This is awesome! great write up this is exactly the information i was looking for. thanks
wrxguy90 is offline   Reply With Quote
Old 05-14-2014, 12:35 PM   #11
Ben
Member#: 423
2002 WRX wagon
Whats the advantage and disavantage for remove those parts away from the car?
Ben is offline   Reply With Quote
Old 05-14-2014, 01:17 PM   #12
kmook
Member#: 146168
2017 Impreza
Advantages are cosmetic and weight.
Disadvantages non that i'm aware of.
Old 05-14-2014, 01:18 PM   #13
kmook
Member#: 146168
2017 Impreza
You're welcome
Old 05-14-2014, 07:18 PM   #14
Ben
Member#: 423
2002 WRX wagon
Will it affect any check engine light code for the engine?
Ben
Old 05-14-2014, 08:47 PM   #15
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
yes you will have a check engine light for multiple codes concerning the evap system if you do this. The only downside is that you'll be a much bigger polluter so if you are required to pass emissions i would not suggest doing this just yet.
brew02wrx is offline   Reply With Quote
Old 05-14-2014, 09:46 PM   #16
Ben
Member#: 423
2002 WRX wagon
Thanks for all your advise.
Ben
Old 05-14-2014, 10:21 PM   #17
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
Wonder if there are any cons to this.
Cefaln452 is offline   Reply With Quote
Old 10-14-2014, 09:55 AM   #18
sub9lulu
Member#: 36946
I just capped all 4 circled, and delete the codes
Anything else ?
sub9lulu is offline   Reply With Quote
Old 10-14-2014, 10:23 AM   #19
kmook
Member#: 146168
2017 Impreza
Anything else ?
That is all, i've always kept the bottom pipe vented to atmo, but it might be fine capped.
Old 02-15-2015, 05:25 PM   #20
prettyinpink
Member#: 260109
2005 Impreza WRX STi
aspen white
Thank you for this write up! Really helped me out. I would just like to add to anyone who is wondering, the breather can be any 1/2 inch breather that you could pick up at a pep boys or autozone.
prettyinpink is offline   Reply With Quote
Old 02-15-2015, 05:30 PM   #21
kmook
Member#: 146168
2017 Impreza
You're very welcome, glad you liked it!
Old 02-26-2015, 10:44 PM   #22
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Yes, thanks!
bue car is offline   Reply With Quote
Old 04-26-2015, 08:12 PM   #23
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
What size is that breather????
sackytar is offline   Reply With Quote
Old 04-27-2015, 09:29 PM   #24
musicmankeb
Member#: 411003
If you disable the codes via accessport will you then pass inspection/emissions?
musicmankeb is offline   Reply With Quote
Old 04-27-2015, 09:49 PM   #25
rjp4419
Member#: 292796
2019 Civic Type R
Some of the EVAP codes dont show up with the accessport. Youll need and actual code scanner.
rjp4419 is offline   Reply With Quote
