Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 09-01-2013, 07:32 PM   #1
Deek
Member#: 145458
2008 rdkls STi
Default RDKLSTi 518whp/492wtq (MD) 2008 STi
2008 Subaru Impreza WRX STi - rdkls STi
Follow;
fb/rdklsti
ig/rdklsti
Build thread restructured. First post will always have my latest update, the rest will be on my site.
://sti.rdkls.com
Dyno
  • TO BE DETERMINED... old #'s below.
  • Tuner: William Knose, Delicious Tuning
  • Dyno: Mustang AWD, Infamous Performance
  • Weather: 83 Fahrenheit, 44% Humidity, 646ft Elevation
  • 15 Psi 367whp, 326wtq - [s]
  • 23 Psi 454whp, 391wtq - [S#]
Longblock
  • Outfront Motorsports closed deck EJ257 with pinned mains
  • Outfront Motorsports AVCS pin service
  • Outfront Motorsports spec 1/2" ARP head studs
  • STi JDM 12mm oil pump
  • Molnar 79mm billet crankshaft
  • ARP 2000 case bolts
  • CP Pistons - 99.75mm 9:1 (coated crowns) with upgraded wrist pins
  • Manley Turbo Tuff I-Beam Rods
  • Race ported heads (by SoCal Porting)
  • GSC stage 2 cams
  • Supertech dual valve spring & titanium retainer kit
  • Supertech +1mm stainless intake valves
  • Supertech +1mm inconel exhaust valves
  • Bowl blended heads (for larger valves)
  • King rod & main bearings
  • Gates racing timing belt
  • Killer B oil pan, baffle & pickup tube
  • JE/Athena head gaskets
  • WPC Treatment on select components
Power
  • Rotated GTX3576R
  • Perrin rotated 2" uppipe (T3)
  • Custom rotated 3" downpipe with QTP electric cutout
  • Perrin 3" intake with K&N filter & pre-filter
  • Perrin EL Big-Tube header
  • Perrin EBCS
  • Perrin/Setrab oil cooler
  • Tial MV-R 44mm EWG
  • Fluidampr Crank Pulley
  • TurboSmart Supersonic BOV
  • Maddad Essentials Street Series Cat-back
  • TurboXS FMIC core with custom charge piping (by KPowered)
  • TGV delete & port, throttle body & intake manifold ported (by SoCal Porting)
  • Rotated STi intake manifold
  • KSTech 9.5mm phenolic spacers
  • Koyo Radiator with Mishimoto hoses
  • Perrin AOS
  • Perrin Thermal turbo & uppipe blankets
Fuel
  • Radium pump hanger with (2x) AEM 50-1200
  • Radium multi-pump regulator
  • Radium top-feed rails with pulse dampeners
  • Injector Dynamics 2000CC injectors
  • Fuelab 6 micron micro-fiberglass element
  • Continental Ethanol content analyzer
Electronics
  • DeliciousTuning FlexFuel Kit
  • Ecutek ProECU
  • AEM IAT sensor (tapped just before throttle-body)
  • AEM 5-bar MAP sensor with Cobb MAP sensor adapter
  • NGK 1-step colder plugs
Drivetrain/Chassis
  • Driveshaft Shop Carbon driveshaft
  • CompClutch Rigid Twin-Disc clutch
  • Torque Solution pitch-stop
  • Beatrush engine mounts
  • Beatrush transmission mount
  • Whiteline gearbox mount bushings (positive shift kit)
  • Whiteline steering rack bushings
  • Whiteline Rear Diff fully polyurethane bushings (front & rear)
  • Whiteline Rear Subframe bushings
  • SuperPro Rear LCA bushings (inside & outside)
  • SuperPro Rear Trailing Arm bushings (front & rear)
  • SuperPro Rear Toe Arm bushings
  • Kartboy shifter bushings
Suspension
  • Tanabe Sustec Pro S-OC coilovers
  • Whiteline 22mm adjustable front & rear swaybars
  • Whiteline front control arm inner-front bushings
  • Whiteline anti-lift kit
  • Kartboy front & rear solid endlinks
Brakes
  • Grimmspeed master cylinder brace
  • Goodridge stainless steel lines
  • StopTech Power Slot front & rear rotors
  • Hawk HP+ front & rear pads
Wheels
  • SSR Type-F matte black 17x9.5 +40
  • Michelin PilotSport PS2 275/40
  • McGard spline drive lugs (black)
Interior
  • ATI triple gauge pod
  • -Innovate MTX-D Boost/Shift Light
  • -Innovate MTX-D Oil Pressure/Temp
  • -Innovate MTX-D EGT
  • SMY gauge bezel
  • -Gauges: AEM UEGO Wideband
  • 15% tint all around
  • Weathertech floor liners front & rear
Exterior
  • GTSpec aluminum undertray (splashguard)
  • Hexis 3D carbon roof wrap
  • Hexis 3D carbon front bumper sectional wrap
  • HTAutos full lip kit
  • Rally Armor V2 mudflaps (black/grey)
  • Painted OEM grill/mustache
Roof Rack
  • Subaru factory rails
  • Inno medium fairing (40")
  • Yakima Frontloader bike racks with lock cores
2015, Dec 7 - Engine bay complete and first fire video.
https://www.youtube.com/watch?v=N4bRLdh_2M0
Deek is offline   Reply With Quote
Old 09-02-2013, 01:58 AM   #2
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-02-2013, 01:58 AM   #3
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-02-2013, 10:30 AM   #4
Jacobs11
Member#: 268948
17 STi
Nice mod list, post some more pics!!!
Jacobs11 is offline   Reply With Quote
Old 09-02-2013, 08:54 PM   #5
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-05-2013, 08:30 PM   #6
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-06-2013, 01:47 AM   #7
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-08-2013, 02:47 AM   #8
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-08-2013, 07:57 PM   #9
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 09-16-2013, 07:30 PM   #10
Deek
Member#: 145458
2008 rdkls STi
Reserved.
Old 10-06-2013, 06:35 PM   #11
Deek
Member#: 145458
2008 rdkls STi
Got the interior all sorted out and then more of the engine bay buttoned up. Since my battery is located in the hatch, I was able to reroute my TurboXS FMIC piping, which allows me to reinstall my stock coolant overflow reservoir as well as maintain fog lights without rubbing on the piping.\
Pics added to the first post(s).
Old 10-07-2013, 12:36 AM   #12
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Who did the head work?
wrb08wrxsedan is offline   Reply With Quote
Old 10-07-2013, 12:50 AM   #13
Deek
Member#: 145458
2008 rdkls STi
Outfront Motorsports in Buena Park.
Old 10-07-2013, 01:24 AM   #14
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Any pictures of the port work ?
I had my last motor built by them but no head work.
I am going with a out front closed deck block but maxwell power built +2mm 2.5
Still trying decide on head choices so I am very interested in your setup out come.
Old 10-07-2013, 01:29 AM   #15
Deek
Member#: 145458
2008 rdkls STi
No pictures of head work, I'll be posting dyno results once I've got past the break in and make my way to Church for the tune.
Old 10-07-2013, 01:35 AM   #16
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
My buddy vim from Forman performance swears by church .
I wish I had better tuning choices in Canada looks like I am flying in or driving to my tuner of choice.
Old 10-07-2013, 01:48 AM   #17
Deek
Member#: 145458
2008 rdkls STi
Yeah Outfront recommends them too. Hoping they're familiar with tuning aquamist.
Old 10-07-2013, 04:48 AM   #18
wuuusaa
Member#: 92894
2015 Wrx
Your so detailed and through, I like this build a lot! Curious how much power are you trying to make that black?
Old 10-07-2013, 04:48 AM   #19
halfhilloa
Member#: 370277
Hopefully get some work in tonight, pics should follow.
halfhilloa is offline   Reply With Quote
Old 10-07-2013, 02:36 PM   #20
Deek
Member#: 145458
2008 rdkls STi
I was at 430~ awhp with 25lbs and a water/denatured-alcohol mixture on my last built shortblock that had no headwork.
I'm going to go with Boost Juice (meth/water) and the headwork should allow me to open it up more.
I'll likely have a daily driven map with around 20-23 psi for daily driving; and I'll have a 28-30 psi map for special occasions.
Old 10-08-2013, 05:01 AM   #21
Deek
Member#: 145458
2008 rdkls STi
Stopped in to see my buddy Navid at K-Powered in Palm Springs. Helped him a little with his race engine tear-down and he welded some beads on my FMIC piping that had to be cut. Came home, took a nap for a few with my boy and then headed back out to the garage to finish up the engine bay.
Just waiting on my Dimple magnetic oil and (both) diff drain plugs and I'll be able to do all of my fluids, prime this thing and fire it up.
Oh, I also raised my rear coils a hair; my 275/40's chewed through the upper part of the inner lip of my rear bumper. Since I have a brand new OEM bumper on there now, I don't want that happening again.
As usual, pictures have been added to the first post(s).
Old 10-08-2013, 07:02 AM   #22
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
They are .
Also boost juice .
I have been told by a few your safer to mix your own 50/50 so I have been ever since .
Up to your self .
Old 10-08-2013, 06:29 PM   #23
Deek
Member#: 145458
2008 rdkls STi
They are .
Also boost juice .
Up to your self .
I'll have to read up on boost juice. I've heard good things thus far. I ran denatured alcohol and distilled water (50/50) before but finding the alcohol was proving more and more difficult lately.
Old 10-12-2013, 12:03 PM   #24
Deek
Member#: 145458
2008 rdkls STi
Finally on the road again! Modded the front bumper a bit for more airflow to FMIC, might cut a little more... waiting to see how I feel about how I've got it now after a few days/weeks.
Pics added to first post(s).
Old 10-14-2013, 09:43 PM   #25
Deek
Member#: 145458
2008 rdkls STi
Snapped a couple more pics of the front bumper, as requested (one of of these build thread deals ).
Oct 12 - 14: Tire balance & rotation, A/C charge, a couple interior shots, bath time and a meet with some local subie-pals at Buffalo Wild Wings.
