09-13-2013, 12:01 PM | #1 |
Member#: 238895
Vehicle:2009 STi DGM |
KY: Pristine 1995 240sx Se
I forgot to add my state in the title on the last one. I got clean title on this super clean ride!
Price is very negotiable: $9,500.00 OBO For more pics/info, Call or text: (270) 3one2-one320 I guess first and foremost the chassis is in pristine condition absolutely no rust dings scratches or chips 100% new nissan factory emerald blue paint on all panels, all new window, door, trunk mouldings and seals. OS Giken 2 way Diff and 1 piece driveshaft and new sard in tank 260 lph pump. Markers and turns are new headlights and taillights are flawless. Pristine 300zx turbo staggered rims, wilwood four piston calipers front and rear rotors upgraded stainless brake lines all four corners. Both front and rear sway bars are Megan all steering and suspension components are Meagan adjustable. Tension rods inner and outer tie rods. Front nismo power brace and poly bushings. Rear has Megan toe, camber, control arms and diff brace. Eibach springs and kyb struts. Hawk pads front and rear. Engine is 100% fresh rebuild not even 200 miles on build. New crank king bearings new rings and fresh hone new oil pump all new fasteners new guides chains and tensioners. Slight port on cylinder head with complete three angle valve job and new seals. Camshafts are custom configuration massive low end torque. Koyo aluminum radiator. 4/2/1 long tube header to Megan 3 inch stainless exhaust. Cold air intake. Wire tuck on engine harness. Fuse box relocate. Oil and power steering cooler. 300zx fuel filter. Recaro leather full adjustable seats. Interior is in pristine condition. No cracks on dash and all panels are showroom clean. Brand new battery and trunk mounted battery box. New nissan fuel pump and sending unit. 240 is as close to brand new as you can get. Ton of time and money invested built correct by nissan master tech. Factory keyless entry, 1995 240sx $9,500 negotiable.
09-13-2013, 10:16 PM | #3 |
Member#: 242966
Vehicle:2005 WRX Rally blue |
Beautiful car and color! I had a 96 in this exact color. It goes from green, to purple, to blue. Pictures do nothing for this color!
As much as I want to see you get your asking price for the car I just don't think its going to happen mate. I had to sell my SR swapped, fully bolted, drift ready 240 for 6500 back in 2006 and I just don't see em going for that much any more. Not trying to ***** on your thead or car by any means. I'm still a huge Nissan fan boy. I pray this does go to a great home! |
09-14-2013, 11:13 AM | #5 |
Member#: 328622
Vehicle:1999 Impreza 2.5 RS Aspen White |
for your own benefit, can I suggest putting all of your mods/"the good" about your car in a list? It will make it much easier to read.
Gorgeous car, and I wouldn't mind having one when it's in such good condition. GLWS! |
09-18-2013, 11:09 AM | #9 |
Member#: 238895
PRICE DROP! $9,500.00 OBO. and I forgot to add that it has an OS Giken 2 way Diff and 1 piece driveshaft and new sard in tank 260 lph pump
09-20-2013, 11:15 AM | #11 |
Member Sales Rating: (2)
Member#: 366978
Vehicle:2014 WRX Limited Ice Silver |
Nice car, not for me but just wanted to say im in Etown as well! Live and work here. Nice to see someone with a Subie in the area, it seems they are an endangered vehicle around here. I pick mine up in December.
Either way, free bump and GLWS |
