Welcome to the North American Subaru Impreza Owners Club Tuesday November 21, 2017
Old 01-11-2014, 07:46 PM   #26
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Originally Posted by CatfaceType-R View Post
Looks good, you've been through some motors, you deserve a long lasting one! All the best of luck.
C
I had a bad year for sure. I feel like this one is a good motor.
06rexwagon is offline   Reply With Quote
Old 01-11-2014, 11:26 PM   #27
lee586
Member#: 212926
97 Wrx
What made you go for the cosworth rod bearing instead of using kings on mains and big ends. Was it a clearence issue or do you not trust the kings on the rods?
lee586 is offline   Reply With Quote
Old 01-12-2014, 12:02 AM   #28
06rexwagon
Member#: 114730
[email protected]
I usually use kings but I had a set of Cosworth bearings sitting around that fit.
Old 01-12-2014, 12:50 AM   #29
lee586
Member#: 212926
97 Wrx
How do you find the king berings?
Old 01-12-2014, 01:09 AM   #30
06rexwagon
Member#: 114730
[email protected]
I had some on hand but usually order from my wholesaler.
Old 01-12-2014, 02:36 AM   #31
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
amazing numbers!
DarkKnightBaku is offline   Reply With Quote
Old 01-12-2014, 03:10 AM   #32
lee586
Member#: 212926
97 Wrx
Sorry I sold have worded better how do you co pare them to Acls?
Old 01-12-2014, 11:58 AM   #33
cpturbo
Member#: 49175
2004 STI
So, are you satisfied with the EFR technology? The power is outstanding.
cpturbo is offline   Reply With Quote
Old 01-12-2014, 12:17 PM   #34
06rexwagon
Member#: 114730
[email protected]
The rods are pretty comparable but the xpg kings are a better main design.
Old 01-13-2014, 07:26 AM   #35
Jkor88
Member#: 252165
2006 STI
Very nice Cam! Glad to see you got the car back up and running in such a short amount of time!
Jkor88 is offline   Reply With Quote
Old 01-13-2014, 08:44 PM   #36
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
It's really pretty amazing spool for that turbo at your elevation. Great job on this re-build and results Cam! It's time for lady (good) luck to be with you!
Old 01-14-2014, 10:23 PM   #37
Mkunkle09
Member#: 307669
2009 Wrx
Charcoal gray
Way to go Cam... Way to show how NM area does it, btw my car is still running awesome after my tune from you... Can't wait to go back when I get more work into it
Mkunkle09 is offline   Reply With Quote
Old 01-20-2014, 05:18 PM   #38
STIinthefe
Member#: 314642
2004 STI
great build
STIinthefe is offline   Reply With Quote
Old 01-22-2014, 11:56 AM   #39
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Awesome build! Do you have any port work done on the heads?
calebtharrell is offline   Reply With Quote
Old 01-22-2014, 12:35 PM   #40
06rexwagon
Member#: 114730
[email protected]
Mild hand porting. Mostly cleaned up the casting and smoothed the transition from the seats to the runners. One day I'll have Fuji K do some heads up right.
Old 01-22-2014, 03:23 PM   #41
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Nice! When/if my NF built block goes I definitely plan on having Fuji give my heads the double D treatment.
Old 01-30-2014, 01:46 PM   #42
06rexwagon
Member#: 114730
[email protected]
I had been having some issues with the aftermarket cams and sync errors on the aem, so I replaced the series 1 box with a series 2. I pulled the engine and retorqued the heads, and while it was out, deleted the variable valve timing since I only use a little advance down low. It was just too risky knowing that if I over advanced the cams or had a sensor error I could potentially run the valves into the pistons.
Now the plan is to finish up the tune on the series 2 and turn the car up another 3-4 psi and see if it can do 900 SAE.
Old 01-30-2014, 01:59 PM   #43
Mkunkle09
Member#: 307669
2009 Wrx
Charcoal gray
Your car needs to tx2k14 this year haha
Old 01-30-2014, 04:12 PM   #44
06rexwagon
Member#: 114730
[email protected]
Doubt it. I have a way of being the one that gets in trouble when I go to events like that.
Old 01-30-2014, 04:48 PM   #45
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Just remove your plate and be faster and/or more reliable than at least a few of the other cars around.
WRXt4cy is offline   Reply With Quote
Old 01-30-2014, 09:04 PM   #46
reid-o
Member#: 103631
2004 STI
Well this gives credence to the runner diameter discussion and flow.
Btw did the v2 cure the sync errors?
reid-o is offline   Reply With Quote
Old 01-30-2014, 09:32 PM   #47
06rexwagon
Member#: 114730
[email protected]
Sure did. Revving to 8500 with no issues at all.
Old 02-01-2014, 03:58 AM   #48
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
That's a lot of power! Car looks good and sounds great. Good job!
alcoolaid is offline   Reply With Quote
Old 02-06-2014, 08:04 PM   #49
06rexwagon
Member#: 114730
[email protected]
Decided to dial in the new AEM EMS and turn it up a little more. Car really liked that extra 3 psi of boost!
New numbers:
For the purists, uncorrected numbers:
All on winter blend E70 from Valero.
Old 02-06-2014, 09:12 PM   #50
reid-o
Member#: 103631
2004 STI
It's the delta between runs that's amazing
I've never tuned at such high horsepower. If the power keeps climbing, what do you use as a ceiling? Just chance it?
