Welcome to the North American Subaru Impreza Owners Club Saturday May 28, 2022
Old 02-19-2014, 06:00 PM   #1
alter_
Member#: 328383
Default Another ej20k having issues
Sounds like it is coming from the front of the engine. I can't make sense of what is going on. If anyone has any ideas please let me know.
alter_ is offline   Reply With Quote
Old 02-19-2014, 07:29 PM   #2
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
oh outch, kinda sounds like a ps pump or an oil pump. take the belts off and start it to see if it goes away.
wrxr4ti is offline   Reply With Quote
Old 02-20-2014, 01:21 AM   #3
alter_
Member#: 328383
Yeah I was almost thinking ps pump myself. Other than that I was almost thinking it could be the tensioner pulleys on the timing area.
the car also has a misfire issue when it gets higher into the rpm but that could be a coil issue. Wish I went usdm now just so I could read the codes
The misfire only comes when the car boosts above 15psi. It is a sudden jerk of power loss and I push the clutch in because it scares me. I have stopped allowing the car into these boost lvls since then.
Old 02-21-2014, 06:42 PM   #4
RawRock
Member#: 284365
1996 STi 555 (1/500)
53c
You can still read the codes on these cars by connecting the black plugs together under the dash.
How to read CEL codes
RawRock is offline   Reply With Quote
Old 02-21-2014, 06:58 PM   #5
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
If you dont know the condition of the timing componets I would replace them, 3 days into getting my 20K on the road I had a idler pulley seize at high rpm and bent every valve. It was so much fun replacing all the valves and finding the shim buckets to adjust everything. As for the 15 psi that seems to be the limit until you can supply the fuel it need. What kind of fuel pump are you using? What ECU are you using as well?
Old 02-22-2014, 05:59 PM   #6
alter_
Member#: 328383
we did the timing belt and checked the pulleys and tensioners when the engine was out of the car. They didn't show any signs that they were bad. Spun freely with no noise.
Using 340Lph fuel pump and using the JDM ecu that came with the engine.
I need to get under the hood and check out that power steering.
Old 02-23-2014, 05:14 PM   #7
alter_
Member#: 328383
so I look under the car and found some fresh oil on the cross member and header. Looks like my head gaskets went. I ran my hand along the edge of the heads and found oil at the bottom. Think this might be the issue.
Old 02-24-2014, 11:30 AM   #8
alter_
Member#: 328383
well pulled the codes.. 33 is vehicle speed sensor which I need to change out. Could the ecu be getting the wrong speed/rpm and it could be as simple as that? Second note the oil is the valve cover gasket which is not as bad as the head gasket.
Old 02-24-2014, 05:15 PM   #9
alter_
Member#: 328383
Installed a new vss and just filled the power steering fluid reservoir some more. No misfire on boost and no more whining noise.
Now to figure out why my gauges are reading like this. This is at idle http://i.imgur.com/ANTqWgi.jpg
Old 02-24-2014, 06:48 PM   #10
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
check your grounds, and the JDM harness has a different pin out then the usdm cluster so check all your inputs and outputs.
Old 02-24-2014, 07:19 PM   #11
alter_
Member#: 328383
here is a video of what they do when you first install them. They start off at 0 then when you give them power they creep up for some reason I don't know.
Old 03-14-2014, 01:05 PM   #12
polaks
Member#: 305714
My 96 sti made crazy power steering noises, changed the fluid and it's good as new. Used synthetic redline automatic transmission fluid.
polaks is offline   Reply With Quote
Old 03-15-2014, 03:22 PM   #13
alter_
Member#: 328383
Yep I added new fluid and it is as good as new.
I need to figure out my gauge issue. It sucks not knowing the proper rpm and speed.
Old 03-18-2014, 10:55 AM   #14
luka
Member#: 194742
1993 Impreza WRX JDM
check your alternator voltage; overcharge will make your electronics do very funny (and unpredictable) things.
luka is offline   Reply With Quote
Old 03-18-2014, 10:56 AM   #15
alter_
Member#: 328383
if you see in the video this is when I just turn the key to the on position. Just incase I did check my alt voltage and it was 14.1-14.4
Old 03-18-2014, 02:51 PM   #16
luka
Member#: 194742
do the needles ever move? or do they stay still regardless of speed/rpm?
Old 03-18-2014, 02:58 PM   #17
alter_
Member#: 328383
yes the needles will move. Its almost like they are moving to their start position (0) then once the car is running it will move just like any other needle but is off because of where they start. If you compare the picture to the video.
The picture is when the car is at idle.
Old 03-19-2014, 12:47 PM   #18
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
If you grounded the cluster properly, then maybe you tapped into the wrong wires for the tach and vss.
Ver.III is offline   Reply With Quote
Old 03-19-2014, 04:36 PM   #19
alter_
Member#: 328383
they function but doesn't explain why they move to that starting point when you turn the key to the on position
Old 03-21-2014, 11:45 AM   #20
alter_
Member#: 328383
Update - this is the car at idle now. Still not sure if it is reporting correctly. 3k rpms does not sound like 3k rpms to me. Either ej20ks rev high and fast or my gauges are still off.
http://i.imgur.com/m83l3qw.jpg
Old 03-21-2014, 01:55 PM   #21
luka
Member#: 194742
have you tried reattaching the original cluster to see if it's reporting the correct value?
Old 03-21-2014, 02:52 PM   #22
alter_
Member#: 328383
no can do this is a 98 rs and has totally different connectors. I found a local guy we are gonna swap his 99-01 cluster in there to see how it reacts to make sure it is reporting properly. I will report back with our findings
Old 10-08-2014, 11:56 AM   #23
alter_
Member#: 328383
found out the needles were messed up. I since hooked up the ecu to my computer through enduring solutions and moved the needles manually to the zero points when power was applied. I then moved them when the car was running to the proper locations and verified the rpms in the ESL program. Car is 100% and added 4lbs of boost along with larger injectors of course
Old 10-08-2014, 04:24 PM   #24
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
hope your running 93 with octane booster
no694terry is offline   Reply With Quote
Old 10-08-2014, 04:27 PM   #25
alter_
Member#: 328383
93 all the time and octane booster is actually a joke. Don't ever run that **** it is a scam.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
