Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 03-02-2014, 08:31 PM   #1
Galager
Member#: 95198
Default Whiteline KBR15 install?
I am installing the KBR15 braces. Everything on the internet says they are marked R and L for right and left. Their own printed instructions say it also as well as their web site. However, mine are not marked R and L anywhere. One has a groove in it and the other does not, so I'm assuming they changed the design at some point to this method but neglected to change the instructions ANYWHERE. Apparently R and L were too simple. Does anyone know which side the grooved one goes on?
Galager is offline   Reply With Quote
Old 03-02-2014, 10:14 PM   #2
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
check whiteline's web for install directions, mail or call them direct? what does this particular part do?
mhoerath is offline   Reply With Quote
Old 03-02-2014, 10:28 PM   #3
Galager
Member#: 95198
For anyone looking for this info, the bar with grooved band goes on driver's side. I had checked the web site, the info was outdated and only referred to R and L stampings which no longer exist. Found my answer on an Aussie Forester board.
Old 03-02-2014, 10:29 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
These are the 2008-2014 RSB mount braces.
You can figure-out which is L and which is R. On one end is a tube and the other a flat-flange. Those mounting surfaces are not on the same plane as one-another.
Work on one side first. If the brace sits flat against the car mount points, then you're fine. Respectfully, take your time and take a common-sense approach to this.
Old 03-05-2014, 12:01 AM   #5
REDCHARGE
Member#: 187304
I often wonder if the mod needs an alignment .
REDCHARGE is offline   Reply With Quote
