Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 03-28-2014, 01:21 PM   #1
freeman.matt
Member#: 106540
2002 WRX Wagon
Blue blue blue
Default 02 WRX Vacuum/Coolant Hose Install Guide
Warning: This is going to be a lengthy guide with lots of pictures. If I get too verbose and you just want the photos, check out http://imgur.com/a/aqDJt.
Another Warning: I'm no expert, and much of what I've learned about my car has been from this website. I've been running these hoses for about a month now without issue, but something could be lurking under the hood. If you see anything that needs correction in either the writeup or photos, let me know.
Background: My 02 WRX had at least two leaks under the hood. I could smell the coolant leak, and I could hear a vacuum leak (which also made my heater lose heat at idle). Knowing the car is now 12 years old, I decided to go through and replace all of the hoses and hope I remedied the two issues.
Hose Source: I bought a kit off of eBay of silicon hoses from HPSI-Motorsports (their website) which shipped with most of the hoses that I needed. I did have to go back and order a few more, but I think I replaced some hoses that they did not intend or used a slightly different size. Regardless, I liked them and would recommend them to anyone. These are the final lengths/diameters of the hoses that I used.
http://i.imgur.com/RMrvdjE.png
Tools Needed: Nothing specialized. I relied heavily on a beefy pair of needle nose pliers and there are a few nuts that need to come out here and there, so a socket set or wrenches of some sort. Silicon grease was very helpful with getting the new hoses on, use it liberally.
Annotations: In all of the images I've circled the start and stop of the specific hose, labeled some nearby hoses for orientation help, and noted the hose length and diameter (ID) used. I've rounded up on all lengths, so expect to trim to fit. The hose label is alphabetical in the order I replaced them, but the rest of the writeup goes in a more logical sequence designed to minimize intercooler/coolant tank removals.
Begin Writeup
Were I to do this again, I'd pull the intercooler first and get it out of the way. There are numerous writeups on how to do this so I'll leave it to them for the details. I will say that with my brittle 12yo stock hoses, there was a lot of swearing and bloodied knuckles getting it out. This would be a good time to get a silicon IC hose kit and it really goes back in much more easily.
The two hoses below connect to the same fitting which goes into a short thick piece of hose. I did not replace it as it would have probably required pulling the turbo, but if you want to, it's 14mm hose. I believe these are crankcase breather hoses... I ended up having to cut Hose X at the elbow to pull it out as it was too rigid.
Hose E, Passenger Breather: 6" x 12mm
http://i.imgur.com/NAtKD1r.jpg
Hose X, Driver Breather: 6" x 12mm
http://i.imgur.com/WYeglHR.jpg
With the IC still out, go ahead and replace the throttle body coolant hoses. The original Hose V ran through a mesh sleeve which I reused, I'm guessing it's for abrasion resistance or something.
Hose Y, Throttle Coolant Out: 10" x 6mm
http://i.imgur.com/r0Av2nZ.jpg
Hose V, Throttle Coolant In: 12" x 6mm
http://i.imgur.com/Xg1iSHR.jpg
Now you can put your IC back in... it shouldn't get in the way anymore. The next hoses run from the blow off valve. I have the stock boost meter, which is where Hose W goes. It runs through the firewall to the gauge. I replaced the hose all the way to the gauge, but should have only replaced the portion in the engine compartment. The hose in the cabin was still quite supple and it was a pain snaking the new hose up the the gauge. If you don't have a gauge, then you won't have a T fitting in hose U and should just cut a single 12" piece.
Hose U, BOV: 12" x 6mm
http://i.imgur.com/hOrdHf2.jpg
Hose W, Turbo Gauge: 60" x 4mm
http://i.imgur.com/on9WEzR.jpg
Also in this area is the hose running the the brake booster and a vacuum hose running to the gas tank. This hose actually has a check valve in it, so either salvage the one from the original hose (which I did), or get another one. Basically, you want to be able to blow through the hose from the brake booster end into the engine, but not suck anything from it. The tank vacuum hose is in a group of three and it's the one with the simple pinch clamps on it, not the more powerful screw clamps required to contain fuel pressure.
Check valve in original hose
http://i.imgur.com/Bq8MQra.jpg
Hose F, Brake Booster: 16" x 9mm
http://i.imgur.com/yUm3Zk6.jpg
Hose Z, Tank Vacuum: 15" x 6mm
http://i.imgur.com/YvJ1FWT.jpg
More in next post...
freeman.matt is offline   Reply With Quote
Old 03-28-2014, 01:21 PM   #2
freeman.matt
Member#: 106540
2002 WRX Wagon
Blue blue blue
Now to the other side of the car and some coolant hoses. Do the next three hoses as a stack (ie remove A, C, D; install D, C, A). There are two 12mm bolts on top of the coolant tank you need to remove and one 12mm nut on the side that needs to loosen. Also, to get at the bottom of Hose D, remove the top half of the air filter box.
Hose A, Turbo Coolant: 8" x 12mm
http://i.imgur.com/7cCZjBN.jpg
Hose C, Bottom Coolant: 5" x 12mm
http://i.imgur.com/P94HmGq.jpg
Hose D, Back IC Coolant Pipe: 13" x 12mm
http://i.imgur.com/PagJRhI.jpg
Go ahead and reinstall the coolant tank, then go for the two coolant hoses which run to the pipes on the front of the IC.
Hose B, Front IC Coolant Pipe: 13" x 12mm
http://i.imgur.com/nSkBm1O.jpg
Hose G, IC Coolant Pipe In: 7" x 12mm
http://i.imgur.com/Wo7oOnG.jpg
Now pull off the cold air scoop (it's 2 bolts of unknown size) and swap the two hoses running to the radiator.
Hose H, Left Coolant: 27" x 6mm
http://i.imgur.com/pWen09H.jpg
Hose I, Right Coolant: 22" x 6mm
http://i.imgur.com/5o0IVjj.jpg
These two hoses may vary on your car. I had to replace the radiator last year and there were some adapter parts required to fit newer radiators into the 02 WRX. The overflow hose is probably similar, but you'll likely not have the Uturn hose unless you've done a similar replacement.
Hose J, Coolant Overflow: 19" x 6mm
http://i.imgur.com/pnWHVrI.jpg
Hose K, Coolant Uturn: 7" x 6mm
http://i.imgur.com/EI4lKUV.jpg
Before replacing the air scoop, go to the next post and do the rat's nest. Once those 6 hoses are done, replace your air scoop and go replace some hoses in the turbo control circuit. Hose L is made of two hoses joined together by a coupler.
Hose L, Turbo Relay 1: 3" x 6mm & 17" x 4mm
http://i.imgur.com/qg2ZOyM.jpg
Hose M, Turbo Relay 2: 11" x 4mm
http://i.imgur.com/xRjfdhu.jpg
Old 03-28-2014, 01:22 PM   #3
freeman.matt
Member#: 106540
2002 WRX Wagon
Blue blue blue
The last part of the turbo control circuit is made of three pieces around a T fitting. The hose you're replacing also has a restrictor pill in it which needs to be reused.
Restrictor Pill
http://i.imgur.com/oUl5mKw.jpg
Hose N, Turbo Relay 3: (3" x 4mm) x 3
http://i.imgur.com/Wg6Yd0T.jpg
With that done, the last set of hoses is up near the alternator colloquially known as the rat's nest. This should actually be done when you're doing the long coolant hoses (H and I) since the air scoop needs to come out. It consists of 6 hoses. I was able to remove the relay that Hoses P and Q attach to simply pulling one bolt using a ratchet w/ a 3" extender. Go slow and try not to lose your place.
Hose O, Rat's Nest 1: 1" x 4mm
http://i.imgur.com/UUvV2k5.jpg
Hose P, Rat's Nest 2: 9" x 6mm
http://i.imgur.com/84uXooF.jpg
Hose Q and R, Rat's Nest 3 & 4: (3" x 6mm & 2" x 4mm) & (3" x 6mm)
http://i.imgur.com/XqSm1Y7.jpg
Hose S, Rat's Nest 5: 5" x 6mm
http://i.imgur.com/sFemYDx.jpg
Hose T, Rat's Nest 6: 9" x 6mm
http://i.imgur.com/THJ40hE.jpg
And that's all. I ended up having coolant leaks at Hose A and the radiator o-ring, and the vacuum leak was in hose U. Good luck, it's not hard, just somewhat time consuming.
Old 03-28-2014, 01:22 PM   #4
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
That's a lot of words for "unplug the old hose, match up to the new hose, plug in the new hose"
Psychoreo is offline   Reply With Quote
Old 03-28-2014, 01:24 PM   #5
freeman.matt
Member#: 106540
2002 WRX Wagon
Blue blue blue
Indeed it is. The high yield stuff here is the table showing overall lengths and diameters required. The rest is just for thoroughness.
Old 03-29-2014, 01:07 PM   #6
silverstreak02
Member#: 316307
2002 Impreza WRX
Looks really good, was doing some work under the hood this weekend and was going to order a few small hoses to replace, but now I see there's a full kit I can buy..great post
silverstreak02 is offline   Reply With Quote
Old 03-29-2014, 03:34 PM   #7
rdieder
Member#: 257818
2007 STi
CGM
What are the closest sizes in non metric? The AutoZone near me has nearly all bulk hose in standard measurements.
rdieder is offline   Reply With Quote
Old 05-08-2014, 12:04 AM   #8
big_dog35
Member#: 273299
2003 bugeye wrx
Great write up man, gettin at this real soon! Been waitin for a DIY like this for a while. It's nice to be able to see and plan it all out before gettin at.
big_dog35 is offline   Reply With Quote
Old 05-08-2014, 02:56 PM   #9
CJ12
Member#: 202539
02 WRX MBP 6SPD
94 LandCruiser/84 NH 650
I for one appreciate write ups just like this. Plenty of useful information and colorful pictures that show relevant detail. Thanks!
I'm a couple of steps away from buying an ancillary hose kit and will reference this when I do the install.
CJ12 is offline   Reply With Quote
Old 05-10-2014, 04:35 AM   #10
lamby
Member#: 237869
Thank you so much for this. I was looking everywhere. Kind of lost on hose T though. Could you post a better picture?
lamby is offline   Reply With Quote
Old 05-11-2014, 11:55 PM   #11
Garo
Member#: 390554
Nice upgrade to get ride of the old ones and ensure no leaks.
Garo is offline   Reply With Quote
Old 05-12-2014, 03:00 PM   #12
bleuquila
Member#: 31922
03 wrx wagon
78 brat
Amazing post and very timely for me - someone else took all my hoses off, and it's been a real headache getting everything reconnected from the bucket of hoses n' bolts. Like a really expensive 3d jigsaw puzzle. I knew I was going to need to replace your "hose b" to the IC, I trimmed my stock one too short when putting in a new inlet and now it doesn't route the way it should. So now I'm sort of fired up to replace all the hoses while I'm at it!
bleuquila is offline   Reply With Quote
Old 05-12-2014, 05:46 PM   #13
taylor_90
Member#: 389932
2005 WRX STi
2019 WRB WRX
Very helpful thanks. Nice write up
taylor_90 is offline   Reply With Quote
Old 08-08-2014, 12:49 PM   #14
mathiasddr
Member#: 181206
2002 Impreza WRX
I've been thinking about replacing the hoses under the hood for a while now, still not having any issues related to the work you did? Also, thanks for the great write-up, it looks like something I would make.
Since we both have older model bugeyes, I feel I should mention that you should check your trunk seal for rust, if you remove it just get some silicone RTV adhesive for a quick reinstall. If your dashboard clock goes out it's a quick solder job with removal of the clock from the dash being the hardest part, and take care to wash down your engine every once in a while as well as cleaning your MAF sensor (both sides and inside where you can't easily see) to keep a smooth idle. Just some stuff I've had to take care of over time.
mathiasddr is offline   Reply With Quote
Old 08-08-2014, 05:56 PM   #15
kaminaricelica07
Member#: 113042
2012 STi Hatchback
Plasma Blue Pearl
I just order this same set today after seeing your post. Might be ordering more by the foot as I see fit. Thanks for the write-up!
kaminaricelica07 is offline   Reply With Quote
Old 08-10-2014, 02:28 PM   #16
Dn41387
Member#: 202895
2005 Sti,2005 Wrx
2000 Rs coupe
Thanks, great post,will be very helpful pretty soon for me.
Dn41387 is offline   Reply With Quote
Old 08-11-2014, 11:52 PM   #17
kabz
Member#: 351744
2004 WRX Wagon
SRR
Awesome write-up. This'll help when I put my blobeye back together, though I did take pics and save and label all hoses and anything that would fit in a ziploc.
Hoses D and G (I'm fairly sure) are the head breathers that are Y'd together by the IC hard-line, and routed to the turbo inlet via Hose B. I guess they get routed like that so they don't end up heating the inlet air any more than they have to. [You have them labeled as IC coolant lines]
kabz is offline   Reply With Quote
Old 11-09-2014, 05:29 PM   #18
Luuuuukebradley
Member#: 377050
Hey I was wondering if you had to drain the coolant in order to change Hose A: turbo coolant hose.
Thanks,
Lucas
Luuuuukebradley is offline   Reply With Quote
Old 11-10-2014, 12:59 AM   #19
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
Thanks,
Lucas
Nope just suck some out with a turkey baster.
Brother EddieJ. is offline   Reply With Quote
Old 12-03-2014, 11:53 PM   #20
Amiyaku
Member#: 255470
2002 Impreza WRX
OMG just after all the searches.. I found it.. the HOLY GRAIL of hose sizing.. this should be stickied somewhere I swear.
freeman.matt, thank you
Amiyaku is offline   Reply With Quote
Old 12-15-2014, 04:31 PM   #21
02SubiRS
Member#: 362874
2003 WRX Wagon
This is one of the best and most useful DIY posts I have ever found on NASIOC. Thank you very much!
02SubiRS is offline   Reply With Quote
Old 12-16-2014, 11:50 PM   #22
Seekins.223
Member#: 408666
Default Hose L, turbo relay
Amazing DIY, great reference thank you. recently bought a 02 bugeye with some weird (to me anyways, not super familiar with this motor) modifications. The car has a little turbo xs manuel boost controller. My question is, the hose labeled L in your writeup is cut in my car, its cut by the intake tube and sealed with a screw. Is this due to the MBC that is installed. Thanks
Seekins.223 is offline   Reply With Quote
Old 02-03-2015, 02:48 AM   #23
Jackstand Johnny
Member#: 408354
2002 WRX Wagon 4EAT
This is amazing. Thank you so much for taking Tue time to do this write up. I have a coolant leak up top somewhere and this should help me out a lot.
Jackstand Johnny is offline   Reply With Quote
Old 05-11-2015, 04:39 AM   #24
sig
Member#: 318247
good thread but your missing one, and its the one that I need to know where it goes, its a very tiny one (diameter wise) on the passenger side, it comes from what looks like some regulator and my guess is that it goes onto the intake manifold where there is a small metal extrusion where i think it goes. It also has a split in the middle of the hose for a 3 way. with nothing coming out of it Sorry but its hard for me to explain since i have no idea what the exact names are, I even searched on parts.subaru.com on all the detailed parts pictures and its not even on there.
sig is offline   Reply With Quote
Old 05-11-2015, 04:42 AM   #25
Dn41387
Member#: 202895
2005 Sti,2005 Wrx
2000 Rs coupe
evap solenoid is what you're looking for
edit: and you can delete the evap purge valve and reroute the hoses for a cleaner hose setup. ( you get rid of the blue t and small diameter hose)
http://forums.nasioc.com/forums/show....php?t=2485979
edit 2: fill out your profile, different motors have different setups, I have included an example for ej205
