Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 04-10-2014, 11:47 AM   #1
sfreeman422
Member#: 366988
2004 WRX Wagon
Default Best Motor Mounts for DD
Hi All,
So i searched and didn't find anything. I'm sure I'll get flamed anyway but what motor mounts would be "best" for a DD 2004 WRX Wagon? My motor mounts are starting to go. I have a slight shake at idle and it appears that I burned a hole in one of my coolant hoses due to the engine hitting the hose and melting it
I'm looking for something that may be a little stiffer but not solid. I have the Group N Tranny Mounts and the NVH is slightly annoying so I'd prefer something that didn't have much added NVH. Is OEM my only option or can I go stiffer with minimal added NVH?
sfreeman422 is offline   Reply With Quote
Old 04-10-2014, 12:25 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
Group N. Why? Because they are OEM.
But there is no "best." So what should you do? Read CAR PARTS REVIEW forum.
Old 04-10-2014, 01:25 PM   #3
mazdan
Member#: 322018
If your motor mounts are starting to go, then new OEM replacements will be stiffer than your worn OEM. If it's at stock power levels I would just go with OEM.
Even Group N will transmit more NVH.
mazdan is offline   Reply With Quote
Old 04-10-2014, 01:26 PM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Options:
OEM
Group N
Everything else is OMFG rigid.
Old 04-10-2014, 02:00 PM   #5
sfreeman422
Member#: 366988
2004 WRX Wagon
Thank guys. Pretty much what I figured. How long do OEM mounts typically last? My car is at about 117k miles but I bought the car with 105k so I don't really know the expected life. Would Group N last longer than OEM? Or is that not even really a factor.
Old 04-11-2014, 02:09 PM   #6
f3ar0n
Member#: 353137
2002 WRX JDM 207
Group N motor mounts FTW.
One of the first thing I did when I bought my WRX. Had some good rocking on hard accelleration. Bought the Group N mounts and had them installed. Tightened everything right up. Great investment and well worth the $$$
OP: I changed mine immediately when I bought the car with 130k miles. It prob should of been done sooner by the original owner. It's going to be one of those things you'll do now and won't have to worry about again for the rest of the life of the vehicle. So prob won't run into it again unless you keep the car for over 200k in which go you!
f3ar0n is offline   Reply With Quote
Old 04-11-2014, 02:27 PM   #7
mitch808
Member#: 10228
2002 Subaru WRX
Anything around 100k, subjected to engine heat, and made of rubber will fail. It's just natural. You'll have to replace them again in probably another 100k.
May want to check out all your rubber vaccum hoses and such, I had a number replaced as they were hard, almost brittle. Those had around 115k or so on them. Just part of normal maintenance on a high mileage car...
mitch808 is offline   Reply With Quote
Old 04-11-2014, 04:45 PM   #8
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
I have beatrush motor mounts. They are awesome. You get used to the NVH real fast, or turn the radio up. All depends on your comfort level.
Brother EddieJ. is offline   Reply With Quote
