Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 04-14-2014, 01:35 PM   #1
P&L Motorsports Inc.
Member#: 67199
Default FA20t Action. 2015 WRX Baseline!
We're happy to announce that P&L has just picked up a beautiful Crystal White Pearl 2015 WRX with the new FA20 turbo engine! We are very excited to start prototyping our turbo kit and other assorted parts for the new platform in the very near future!
We've already completed a baseline dyno run on it so far, and the car seems to be making great power even in stock form. If it's anything like the FA20 in the BRZ/FRS, we're thinking it's going to be a great improvement over the outgoing EJ series engines.
The 2015 has fantastic handling from the factory, much better than the previous model years. Large anti-sway bars, chassis bracing, and beefier springs/struts make this an incredibly well handling car. With such a strong platform to build upon, we can't wait to see it making some big power!
https://www.youtube.com/watch?v=PP8SkUGZ60k
YouTube Link Above to the Dyno Pull!
Event: Dyno Pull
Ambient Temp: 62deg F
Elevation: ~600 ft
Weather: sunny
Track and Conditions: N/A
Tires: N/A
Car: 2015 WRX
Tuner: N/A
Dyno Info: Dynojet
Transmission: Factory 6 Speed
Gear: 3rd
Peak HP at RPM: 243 @ 5300 RPM - STD CF
Peak Torque at RPM: 245 @ 4900 RPM - STD CF
Baseline hp/tq for a stock on same dyno: N/A
Target Boost: N/A
Target AFR: N/A
Fuel: 93 oct
Engine/Power Modifications: N/A
Driveline Modifications: N/A
Suspension Modifications: N/A
Other Modifications: N/A
Dyno testing with P&L Motorsports catted 3" turbo back exhaust. No other modifications.
More info for P&L 2015+ WRX Downpipe: http://pandlmotorsports.com/shop/pl-...-wrx-downpipe/
P&L Turbo Back Exhaust (catted), 93 octane, 19 psi boost. ~300 whp!
Took the WRX to the track this weekend and clicked off a 12.94 @ 106 mph. I believe this is the first 2015 WRX into the 12's!
Cobb AP
Protune by Jr at P&L
P&L Catted Downpipe
P&L Cat-Back Exhaust
P&L Motorsports Inc. is offline   Reply With Quote
Old 04-14-2014, 01:55 PM   #2
mtskibum16
Member#: 83708
2005 FXT
CGM
Finally a dyno pull that resembles Subaru's torque claims. It will be interesting to watch this platform develop!
mtskibum16 is offline   Reply With Quote
Old 04-14-2014, 01:56 PM   #3
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Can't wait for the performance product to come out
st205wrx is offline   Reply With Quote
Old 04-14-2014, 02:14 PM   #4
MaddMax
Member#: 9264
2016 BMW M235i 6MT
It still doesn't come close to Subaru's claim of full torque by 2000rpms, but it is a little better than what we've seen previously.
I'd be curious to know what stock EJ25's have done on this dyno in 3rd gear.
MaddMax is offline   Reply With Quote
Old 04-14-2014, 02:14 PM   #5
Back Road Runner
Member#: 60082
2004 Forester STI
That's what I was thinking. Although, it looks like they should start the pull at a lower rpm. If this car can do full torque at 2000 rpm, you almost need to start right from idle (almost).
Old 04-14-2014, 02:21 PM   #6
Boxer112
Member#: 78751
2017 Sti
ISM
Yeaaaaaaa. Start the modding...
Boxer112 is offline   Reply With Quote
Old 04-14-2014, 03:24 PM   #7
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Source the brz turbo manifold set up and then open source tune can't wait for them To do something of that nature.
Old 04-15-2014, 12:38 PM   #8
mtskibum16
Member#: 83708
2005 FXT
CGM
Well it would be impressive if it did considering the pull wasn't started until after 2000rpm. I have a feeling that early spool is going to be difficult to achieve on the dyno, but my guess is it will be there on the street.
Old 04-15-2014, 12:48 PM   #9
Member#: 67199
We'll be testing both an upper and lower mount system, and offering whichever works and fits the best. Really excited to start digging into this car.
If we have some free time coming up here, I'll see if we can test what spool is like just off idle. I have a sneaking suspicion it won't change much from what we've seen so far though.
-Ty
Old 04-15-2014, 12:49 PM   #10
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
AFAIK, you'll never see the true torque curve on a dyno vs the street; the resistance/load is different, which affects the boost pressure during spool, so you hit peak boost at a different rpm on the dyno vs the street.
blehhh is offline   Reply With Quote
Old 04-15-2014, 02:15 PM   #11
thuanvinhny
Member#: 288935
What is with all the high read number ? Isnt that like 9-10% drive train losses only ? It can not be...a WRX is pumping out 240+ awhp ? I refuse to believe. I have seen STI pumping 270+ awhp ?
Is it that Subaru is under rating their engine ?
Thanks for the dyno info, and graph. Can not wait for more
thuanvinhny is offline   Reply With Quote
Old 04-15-2014, 02:49 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
Well there is a distinct benefit to having the torque so low. The hp is also very low still meaning the actual ability to spin up the rollers is still very slow.
Old 04-15-2014, 03:26 PM   #13
ToneWrx02
Member#: 239095
2002 Wrx
-Ty
Not trying to offend you at all or call you stupid but i see no way how a upper mounted turbo woulf be better. Unless you are going for a huge turbo that cant fit where its at now then i see no reasom to switch to upper mount.
Lower mount will provide faster spool in everyway.
Lower mount is overall better. Turbo lag
ToneWrx02 is offline   Reply With Quote
Old 04-15-2014, 03:46 PM   #14
Member#: 67199
No offense taken. Like I said, fitment is definitely a concern as well as the added complexity of an oil return system for a turbo at the same level as the oil pan. There is also the concern of water and road debris contacting the turbo and potentially causing damage.
-Ty
Old 04-15-2014, 04:14 PM   #15
tomt5078
Member#: 84619
2013 BRZ
Nice........Can't wait to see the progress, as I've been watch since you picked this thing up!!!!!
tomt5078 is offline   Reply With Quote
Old 04-15-2014, 04:37 PM   #16
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
i wanna see a 20g on it
BroBroBroBroBro is offline   Reply With Quote
Old 04-16-2014, 06:04 AM   #17
ToneWrx02
Member#: 239095
2002 Wrx
-Ty
Ive seen many corvettes with a turbo mounted really low. No issues there.
Old 04-16-2014, 06:10 PM   #18
jawwadh
Member#: 100594
2008 BMW M3
240 whp? That equates to more like 285 crank hp given 20% drive train loss?
jawwadh is offline   Reply With Quote
Old 04-16-2014, 06:34 PM   #19
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
240whp with 20% drivetrain loss would mean 300 at the crank.
(I'm assuming you're mistakenly taking 240 x 1.2 instead of 240/(1-0.2) )
Either way, it's worth remembering that the WRX has always had less drivetrain loss than the STI, with both putting down similar power to the wheels, stock for stock (see cobb dyno database). I'm sure that can play into this here again.
Old 04-16-2014, 07:20 PM   #20
jawwadh
Member#: 100594
2008 BMW M3
I was underestimating .. I think loss with these modern cars is more like 18%.. 300 HP seems too much for a wrx. The wrx is gonna cannabalize sti sales
Old 04-16-2014, 10:24 PM   #21
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Maybe Subaru is trying to be like several European companies and are under rating their engine hp claims.
Old 04-17-2014, 12:43 AM   #22
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
They have been doing that since '09 at minimum.
My '09 and others have put down nearly identical HP numbers as GR STi's on the same dyno.
Back to topic. What a great looking dyno pull! (IMO) That is an impressively huge powerband.
Essentially max TQ from 2700rpm to 5300rpm.
I'm impressed.
Breezio is offline   Reply With Quote
Old 04-17-2014, 01:35 AM   #23
rexblake
Member#: 178426
2010 S4
Gray
They aren't.
I'm impressed.
Ugh, I don't understand this philosophy. You realize the STI and the wrx have a different drivetrain right? One drivetrain seems to have more loss, which makes logical sense since one is beefier.
Until the Subarus are putting down crazy numbers on the dyno (aka, equaling chp) or pulling crazy times at the strip, you can't say they are understating their engine hp ratings.
On a more logical though process, P and L's dyno puts out the higher range of whp. You can see that on all of their dynos in ppb. Take a minute, do some searching. It's not a good or a bad thing, it's just what it reads. From what I can tell, they do great work and have built some seriously fast Subarus, including a record holder or two if I'm not mistaken.
rexblake is offline   Reply With Quote
Old 04-17-2014, 09:05 AM   #24
JohnB35711
Member#: 241617
Originally Posted by rexblake View Post
They aren't.
It's a well accepted fact that the 09 to 14 WRX is underrated at 265hp.
JohnB35711 is offline   Reply With Quote
Old 04-17-2014, 10:29 AM   #25
Breezio
Member#: 234357
2009 WRX
They aren't.
Yes they are. And to think you say I need to do some searching...
I'm sorry sir, but you quite frankly don't know what you are talking about.
Yes the STi has a bit more drivetrain loss. However, when on the EXACT same dyno using the exact same calibration a GR STi puts down ~240whp and a VF52 powered WRX puts down ~240whp that shows that the crank HP for the WRX is nearly as much (though, yes, slightly less) then the STi.
When you look at all the data out there a stock '09-'14 WRX is probably around 290-295 crank HP, whatever it exactly is, it's well over the Subaru rated 265BHP.
You wish to bring up drag strip performance? Are you not aware the '09+ WRX often pulls an equal or faster time in the 1/4mile to the GR STi?
Obviously there are many factors to this.. a little less weight, a little less drivetrain loss, better gearing with the 5-speed and nearly as much engine power.
About P&L's dyno. I don't need to do any searching involving it because I wasn't commenting on the numbers it puts out. The only thing I mentioned in directly relation to their dyno was the length of the TQ peak/curve. Which has nothing to do with the specific TQ number it showed.
