#126 |
Member#: 58668
BAIC
Vehicle:2018 Forester XT Dark Gray Metallic |
![]() I ran it down the driver side interior to a grommet under the dash. It's visible just above the carpet line on the left. There are a couple pipes running through it but managed to squeeze a wire through the side of it. The wire then runs behind the strut tower through the fender and to the battery. I can try and snap pics of it later.
#127 |
Member#: 58668
BAIC
#128 |
Member#: 403980
Vehicle:2017 BRZ PP WRB |
![]() Thanks. I am going to use the routing of the hood release cable in the driver side fender well, and do it with -4ga for future sound needs...
#129 |
Member#: 403980
![]() I just wanted to second the Towready 118581 t-connector light kit. I ran the power through the same grommet as the hood release in the left front fender. Everything else was plug and play.
#130 |
Member#: 58668
BAIC
![]() Awesome...glad it workout for you too! Its a sweet plug-n-play kit that works with our 2015's as well. That and the fit of the TorkLift hidden hitch is a really nice and elegant setup.
#131 |
Member#: 407734
South East
Vehicle:2015 WRX Ice Silver Metallic |
![]() Got my hitch done, it's a Torklift 1 1/4". I have to say it went very smoothly, taking new car fresh plastic apart is nice. Took about 4-5 hours as I was being cautious.
Only thing that made me nervous was pulling the bumper off. http://i.imgur.com/HQ1hTYU.jpg Only thing I would add to instructions is to remove the exhaust hanger in front of the rear diff so that you can drop exhaust far enough down. http://i.imgur.com/6WGPC35.jpg I centered it & torqued it off the car frame, before I put the bumper back on. It centered very nicely. http://i.imgur.com/9PgEhRM.jpg http://i.imgur.com/09pLAVp.jpg And this is why I wanted a hitch. It's a Yakima Holdup rack that I cut short so it holds one bike. Much better when folded up. I've got the bits to make it a 2 bike rack later. http://i.imgur.com/xhE6LN9.jpg http://i.imgur.com/GORDj01.jpg Overall my experience was good, Torklifts design and instructions are good. Even though the amount of parts that come off can be intimidating, the job wasn't difficult. |
#132 |
Member#: 403980
![]() Nice Tranny!
#133 | |
Member#: 58668
BAIC
![]() Quote:
#134 | |
Member#: 407734
South East
![]() Quote:
http://i.imgur.com/dN28e4W.jpg |
#135 | |
Member#: 382630
SCIC
![]() Quote:
#136 | |
Member#: 58668
BAIC
![]() Quote:
#137 |
Member#: 118209
Vehicle:2015 WRX Limitec |
![]() Just got done running 1/0 wire to my amp in my '15... Longest amp/sub install I've ever done! Every step wanted to fight me in one way or another... Anyway, if you are needing to run a power cable, the easiest way is NOT through the firewall... Driver side battery, through the foam cover in the engine bay, down the fender, and then poke a hole through the front of the rubber grommet that seals the wires from the door.
#138 |
Member#: 391935
Vehicle:2015 wrx |
![]() Quote:
#139 | |
Member#: 407734
South East
![]() Quote:
#140 |
Member#: 377946
Vehicle:2015 WRX Silver |
![]() I have a Saris 4 bike rack with the 2" receiver and have no wobble at all with the hitch pin tightened down fully.
#141 |
Member#: 380934
Vehicle:2015 WRX WRB |
![]() Uhaul has a hitch for our cars now. The cost of the trailer, wiring and labor to install everything is less than the just the Torklift hitch.
#142 |
Member#: 412348
#143 |
Member#: 21650
NESIC
Vehicle:2015 STI DGM |
#144 |
Member#: 267543
South East
Vehicle:2015 STI Limited World Rally Blue |
#145 |
Member#: 412343
![]() Does anyone have any experience yet with the Curt hitch that's now available for the 2015 WRX? http://www.etrailer.com/hitch-2015_Subaru_WRX.htm Aside from the obvious aesthetic advantages of the EcoHitch, what are the disadvantages of the Curt? It should be a bit easier to install since the bumper won't need to be removed and it's over $100 less expensive and there shouldn't be issues with accessing the pin. However, it's not clear to me if any clearance would be lost with the Curt.
I'm going to get the 1Up rack so pin access isn't a major issue for me. I'm just trying to decide whether to go with EcoHitch or Curt and also whether to do 1.25" or 2" with the EcoHitch if I go that route. |
#146 |
Member#: 409360
![]() clever very clever.
#147 | |
Member#: 155411
Vehicle:2006 Miata 2015 WRX |
![]() Do you have any close up photos of the hitch?
#148 |
Member#: 267543
South East
#149 |
Member#: 391935
Vehicle:2015 wrx |
![]() The really nice thing about the torklift is that it sits so high up you don't lose any height with regards to departure angle. Bottoming out your hitch with a cargo basket is WAY more difficult to do with the receiver a good 6 inches higher up the rear of the car when compared to the curt/uhaul.
#150 | |
Member#: 317270
Vehicle:GRC, Sienna, GR86 |
![]() Quote:
