![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
![]() I'm wanting to price out a set of 2006 WRX (NON caster adding) front lower control arms, but am having trouble finding a part number.
Are the SPT aluminum front control arms the same as 06 WRX? Again, I cannot use anything other that WRX aluminum front control arms. No STI parts. Thanks!
#2 |
Member#: 147776
NWIC
![]() Or does anyone have the part number for aluminum front control arms for 2006 WRX or WRX-TR
#3 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
![]() Traverse Link RH Assembly: 20202FE820
Traverse Link LH Assembly: 20202FE671 You would have to inquire with a dealer as to whether the SPT kit is effectively the same as the late-2005 through 2006 aluminum WRX pieces listed above. Verify above part numbers with a dealer. |
#4 | |||
Member#: 147776
NWIC
![]() To answer my own question, Subaru only made two versions of the GD chassis Aluminum control arm.
Easy differences can been seen below: Quote:
#5 |
Member#: 493859
TXIC
Vehicle:06 WRX TD Swapped sorta black-ish |
![]() I know this is an old thread, but posting for anyone looking for this info, like I was.
V7 V8 V9 JDM WRX/STI (Non Spec-C) / MY06 WRX / MY07 USDM STI [Non-Caster Adding] V8 V9 Spec-C STI / MY04 MY05 MY06 USDM STI [Caster Adding] The 2007 V9 JDM STI (Non Spec C) came with the caster adding LCA's but apparently the USDM version did not. |
