Welcome to the North American Subaru Impreza Owners Club Monday April 22, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 05-29-2014, 09:25 PM   #1
6mt.sauce
Member Sales Rating: (7)
Member#: 271795
. Miata
neo chrome
Default CT: 2001 B5 S4 All Documented Maintenance
SOLDDDDDDDDDDDDDDDDDDDDDDDDDDD
2001 Audi B5 S4 in Santorin Blue with black leather interior. Extremely clean inside and out. 147,xxx miles on it with clean title in hand. Maintenance is all up to date and very extensive. Service records date to 2002 with window sticker. Timing belt has 5k on it, k03's have 45k on them.
Aftermarket:
APR R1 diverter Valves
APR Stage 2 tune
JHM Front Mount
Samco Throttle Body Boot
Short throw shifter
VHO boost gauge in vent location
Poly stub mount
H&R Coilovers
Drilled and slotted rotors
SSAC Downpipes
AutoSpeed catback exhaust
O2 Spacers
Cleared out headlights
HID headlight conversion
HID fog lights (not installed)
OEM rubber mats
Maintenance:
5/23/02 - disc braes x2, 20k service, oil +filter
11/20/02 - Replaced windshield washer tank; replaced washer fluid pump
9/5/03 - throttle body boot replaced
11/21/03 - Mobil 1 oil change and filter
12/26/03 - snow tires mounted and balanced (32k)
2/17/04 - driver seat heater replaced
8/18/04 - 40k mile service; plugs replaced, cabin filter, oil change and filter ((38k)
9/23/04 - bumper washer cover replaced
10/1/04 - tie rod end replaced, front and rear alignment, headlight washer cyl installed (43k)
10/1/04 - 50k mile service, oil change and filter, upper control arm replaced (43k)
12/2/04 - toyo proxes 225/45 mounted and balanced
12/9/04 - overhead interior light replaced, right front speaker replaced (46k)
7/31/05 - hawk hps brake pads replaced
8/18/05 - fight front upper control arm replaced, left front cv boot replaced (54k)
12/28-05 - temp sender replaced, seal replaced
5/10/06 - lube oil filter, repair heater +controls; re route boost gauge line
6/9/06 - diagnosed boost noise, tightened all plumbing and fittings
6/15/06 - installed poly stub mount
7/17/06 - cv boot replaced (65k)
7/18/06 - install battery, replaced throttle adapter
9/7/06 - samco throttle body boot installed
9/8/06 - oil service
12/27/06 - mount balance 2 tires (79k)
1/19/07 - replace boost hose, PS fluid topped off
1/30/07 - rotors and pads replaced
7/10/07 - remove and install new timing belt, tensioner, relay roller, coolant reservoir replaced (94k)
9/13/07 - wheel bearing replaced
9/22/07 - tie rod end replaced
2/26/09 - installed new k03 turbos, replaced right side tie rod end, manifold to turbo gasket x2, chain tensioner gasket x2, valve cover gasket x2, sec cool down pump x1, clutch kit x1, motor mounts x2, oil chane, intake gasket x2, oil return gasket x2, oil cooler seal x1, tie rod end x1, seal washers and clamps, battery changed (97k)
8/6/09 - left and right cv joint installed
1/29/10 - intoxalock recalibration (108k)
2/25/10 - 02 sensor bank 1 replaced
4/6/10 - oil change and filter, oil pan replaced; oil pan gasket, power steering pump, sealing washer, steering rack, alignment
6/23/10 - plugs changed, 2 coil packs replaced (113k)
7/7/10 - paintless dent repair; entire car
11/16/10 - fuel pump changed (118k)
12/29/10 - rubber winter mats
1/17/11 - control arm assy installed
2/8/11 - rotors and brake pads replaced
2/9/11 - 1 spark plug replaced
2/14/11 - APR Diverter valves installed
2/25/11 - replaced output module (120k)
3/26/13 - front bumper replaced; truck backed into with tow hitch
11/5/13 - SSAC downpipes and Autospeed exhaust installed, TIMING BELT replaced, clutch slave cyl replaced, thermostat, water pump gasket, camshaft seals, valve cover gaskets, coolant reservoir cap, shifter box assy and adjust shifter linkages, (143k)
12/3/13 - driver side rear wheel bearing installed (144k)
12/11/13 - replace headlight ballast 6k HID's installed
4/26/14 - installed downpipe O2 spacers (146k)
5/3/14 - install new bosch crank position sensor (147k)
5/24/14 - installed all new Denso iridium plugs (147k)
Car needs nothing at this point besides an alignment. Brake pads at 90% front 50% rear. Rotors will need to be replaced next brake change. front tire tread at 7/32 rear at 3/32 (should be good through summer). AC works great, ice cold. Starts and runs strong. Car is in amazing condition and is a must see.
6mt.sauce is offline   Reply With Quote
Old 05-29-2014, 09:39 PM   #2
YouFoundDonon
Member Sales Rating: (3)
Member#: 379907
2010 WRX
World Rally Blue Sedan
Have interior pics?
YouFoundDonon is offline   Reply With Quote
Old 05-29-2014, 09:43 PM   #3
6mt.sauce
Member#: 271795
. Miata
neo chrome
Originally Posted by YouFoundDonon View Post
Have interior pics?
that would help huh. I'll snap some tomorrow in the daylight. Seats have no rips, and there is no fading on the dash or any plastic trim pieces.
Old 05-30-2014, 02:45 PM   #4
6mt.sauce
Member#: 271795
. Miata
neo chrome
Will hopefully have interior pics tonight.
Old 06-01-2014, 10:22 AM   #5
6mt.sauce
Member#: 271795
. Miata
neo chrome
DSLR Shots:
Old 06-02-2014, 10:43 AM   #6
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top
Old 06-02-2014, 04:58 PM   #7
6mt.sauce
Member#: 271795
. Miata
neo chrome
Maintenance updated. I recently did all the plugs Denso Iridium.
Old 06-02-2014, 05:52 PM   #8
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
just have to ask, what's this?
Mr.Chow is offline   Reply With Quote
Old 06-02-2014, 05:52 PM   #9
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
very clean s4 btw...best color, best interior and got 150k miles it's stupid clean.
Old 06-02-2014, 08:48 PM   #10
6mt.sauce
Member#: 271795
. Miata
neo chrome
probably has something to do with the flux capacitor.
i honestly dont know i just went line for line on all receipts. id google it.
and thank you for the kind words
Old 06-03-2014, 05:32 PM   #11
6mt.sauce
Member#: 271795
. Miata
neo chrome
bump
Old 06-04-2014, 12:19 PM   #12
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top
Old 06-05-2014, 02:55 PM   #13
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top
Old 06-06-2014, 03:10 PM   #14
6mt.sauce
Member#: 271795
. Miata
neo chrome
euro bump
Old 06-07-2014, 11:24 AM   #15
smooth_ej20
Member#: 84671
2007 LegGT(dead)
Its a lock out device for people with DUI's.
and dammit if i wouldnt have just bought a new impreza i would be all over this. GLWS OP
smooth_ej20 is offline   Reply With Quote
Old 06-07-2014, 01:03 PM   #16
6mt.sauce
Member#: 271795
. Miata
neo chrome
HAHA really?! thats crazy. And thank you!
Old 06-08-2014, 10:07 PM   #17
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top
Old 06-09-2014, 01:31 PM   #18
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top .
Old 06-12-2014, 12:17 AM   #19
6mt.sauce
Member#: 271795
. Miata
neo chrome
to the top
Old 06-13-2014, 04:21 PM   #20
6mt.sauce
Member#: 271795
. Miata
neo chrome
Sold. Please close
