Welcome to the North American Subaru Impreza Owners Club Friday April 3, 2020
Old 06-04-2014, 04:25 PM   #1
DisoDisp
Member#: 187648
2007 WRX
Default Absolute Performance 07 WRX Full Race EFR 8374 TS
Continuation from my thread in the Members Gallery:
http://forums.nasioc.com/forums/show....php?t=2575283
Specs:
2007 WRX
Benson Sleeved EJ257
ARP Case Bolts
H11 Headstuds
Calico Coated ACL Bearings
Manley 9.8:1 CR Pistons
MPS +2mm H-Tuff Rods
Manley 79mm billet crank
Cosworth Intake Manifold
Navalinea 1.0mm Headgaskets
Tigwerks Oil Pickup
Cosworth Baffle Plate
Composite TGV Housings
Cosworth Timing Belt
Torque Solutions Timing Belt Guide
Fluidampr Crank Pulley
Koyorad Radiator
Okada Project Plasma Direct Coils
NGK ILFR7AIX Plugs
D25 Heads
GSC +1mm Intake Valves
Ferrea +1mm Exhaust Valves
Manley Single Springs And Retainers
GSC Valve Seals
GSC Bronze Valve Guides
Custom Race Cams
Radius Valve Jobs and Port Deshroud.
Drivertrain
2005 STi Gearbox + R180 Rear End
ACT XT-SS Clutch Kit
ACT Streetlite Flywheel
Crank Pulley
Turbo
Full Race TS EFR Turbo Kit (Manifold, Up-pipe + Downpipe)
Borg Warner EFR8374 TS 1.04A/R EWG Turbo
2x Tial MVS Wastegates
All Wrapped in DEI Titanium
Fueling
In Tank Walbro 450 E85 Pump
Radium Automotive Dual Walbro 255 Swirl Tank
1780cc Denso Injectors
Custom Fuel Rails
Fuelab Mini AFR running 3.2bar base pressure
Car is back on the road with a new set of "race" cams, power down low is pretty much non existent, but up top it sings nicely.
Its still pig rich too, so a little more power should be available once we get the AFR's spot on.
VD graphs as follows @ 34psi peak boost.
DynoJet VD calibartion, SAE corrected for outside temp.
uusinusand by DisoDisp, on Flickr
Virtualdyno 1.2 CF for approximate crank output.
uusinmetric by DisoDisp, on Flickr
Link G4+ ECU should be here in the next few days, after it's tuned on that it's gonna go on the DynoDynamics dyno for a "real" power pull.
RPM limit will also be raised to 8500rpm instead of the 8000rpm it's at now.
DisoDisp is offline   Reply With Quote
Old 06-04-2014, 05:27 PM   #2
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
Which intake manifold? Willing to provide any more details on the cams?
Th3Franz is offline   Reply With Quote
Old 06-04-2014, 05:40 PM   #3
DisoDisp
Member#: 187648
2007 WRX
Cosworth Manifold.
As for cams I'm not able to give exact specs atm, but they are 288's.
Old 06-04-2014, 06:14 PM   #4
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
Ok. BIG cams lol
Old 06-04-2014, 07:24 PM   #5
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
good power for that turbo but spools really late
why go with cams so big with that turbo?? do you have plans to go bigger down the road? GSC STG2 cams would have been all thats needed with that snail ...
Old 06-05-2014, 06:39 AM   #6
DisoDisp
Member#: 187648
2007 WRX
We had GSC S2 cams, they failed after 600 miles, and the customer service side was atrocious, so we won't be buying or recommending any GSC products to any of our customers ever again.
Same goes for any other companies that aren't straight up about their products.
As for the cams, we're looking to front mount something like a 9180 down the line
Old 06-05-2014, 07:38 AM   #7
2000subie
Member#: 207638
2004 WRX
Yellow
ARP 2000 or ca625+ rod bolts?
2000subie is offline   Reply With Quote
Old 06-05-2014, 07:43 AM   #8
DisoDisp
Member#: 187648
2007 WRX
Arp 2000
Old 06-05-2014, 08:24 AM   #9
Paul
Member#: 56203
00 RSTI Coupe
Sorry to hear about that failure.
Can you mention the company that made these cams for you
Front mounted 9180 will be sick with that motor
Old 06-05-2014, 10:58 AM   #10
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
deng this turbo is no joke, is it like garret 40R ?
Bariga is offline   Reply With Quote
Old 06-05-2014, 11:05 AM   #11
DisoDisp
Member#: 187648
2007 WRX
It's a pretty big turbo for sure, 79lbs/min
Link ECU's arrived today, so once we get that tuned and the afr's at 12.0:1 instead of 9.6:1 I suspect it should be over 740whp on the VD.
Old 09-18-2014, 02:12 PM   #12
DisoDisp
Member#: 187648
2007 WRX
dyno-absoluteperformance by DisoDisp, on Flickr
DynoDynamics dyno numbers, started pushing coolant at 30psi even with 14mm headstuds, so had to stop it there.
And on the Dynocom running 0.1bar more boost.
harinendynolappu by DisoDisp, on Flickr
Old 09-18-2014, 07:24 PM   #13
2000subie
Member#: 207638
2004 WRX
Yellow
Have the heads been re-torqued sense assembly?
Old 10-30-2014, 01:26 PM   #14
DisoDisp
Member#: 187648
2007 WRX
Game Over...
Gudgeon Pin Circlip decided to go walk about, engine is toast.
DSC_0002 by DisoDisp, on Flickr
DSC_0003 by DisoDisp, on Flickr
DSC_0008 by DisoDisp, on Flickr
DSC_0013 by DisoDisp, on Flickr
DSC_0021 by DisoDisp, on Flickr
DSC_0020 by DisoDisp, on Flickr
IMG-20141028-WA0001
Time to decide what to do next, EJ22, EJ25, EG33, EZ30, EZ36 or something else entirely.
Old 10-30-2014, 06:09 PM   #15
Paul
Member#: 56203
00 RSTI Coupe
Damn that sucks sorry to hear bro
you can't save anything?...not even heads?
Old 10-30-2014, 08:13 PM   #16
DisoDisp
Member#: 187648
2007 WRX
The heads will be going to the headshop next week to see if they can be salvaged, both exhaust valves are bent and there are a few dents on the head deck surface. Will have to see if they are too deep to be skimmed.
The valves can be changed and valve seats swapped out if need be.
Old 11-11-2014, 04:06 PM   #17
DisoDisp
Member#: 187648
2007 WRX
Heads are salvageable, new EX and Intake valves, new valve guides, new valve seals, some head work and a skim.
All the rest of it needs to be replaced.
New Crank, New Pistons, New Rods, New Bearings, New Oilpump, New Oil Cooler, New Block.
Time to get saving ;P
Old 11-14-2014, 04:46 PM   #18
DisoDisp
Member#: 187648
2007 WRX
OK, new parts purchased.
So this is going in my spare closed deck converted EJ25 (similar to outfront closed decks) which will be sleeved by us.
JE FSR 9.5:1 Pistons
Manely I beams with CA625+ bolts
King XPG Main Bearings
Cosworth Rod Bearings
Manley Billet Crank
Now its a waiting game, block is going to be sleeved once the dartons arrive from the US.
Old 11-14-2014, 06:44 PM   #19
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Manley Billet Crank
Glad you went with I beams this time
freddy121389 is offline   Reply With Quote
Old 11-16-2014, 10:31 AM   #20
DisoDisp
Member#: 187648
2007 WRX
The Failure wasn't caused by the MPS +2mm H Tuff rods, as you can see from the pics they are plenty strong.
If I had the money, I would've gone for some Custom 131.6mm Carillo or Arrow H beams.
They've been tried and tested in the time attack world in high power Subarus over and over.
Personally I much prefer the H beam design over I beams, but beggars can't be choosers
Old 11-20-2014, 01:05 PM   #21
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
That sucks man, I hope you can bring it back to life. I'm in the middle of the same sort of build but with a little craziness to it.
JdMS13 is offline   Reply With Quote
Old 11-21-2014, 04:05 PM   #22
DisoDisp
Member#: 187648
2007 WRX
Finally got around to editing the Dyno Vid, excuse my crappy editing
Old 12-25-2014, 02:15 PM   #23
DisoDisp
Member#: 187648
2007 WRX
New parts are finally here, time to machine to block and get assembling.
JE 99.5mm 9.5:1 CR Pistons
JE Tool Steel Upgraded Wrist Pins
Manley Turbo Tuff I Beams /w ARP CA625+ Rod Bolts
Darton Sleeves
King XPG Bearings
Head Repair items:
GSC Valve Guides
GSC Valve Seals
Can't wait
DSC_0011~2 by DisoDisp, on Flickr
DSC_0012~2 by DisoDisp, on Flickr
DSC_0013~2 by DisoDisp, on Flickr
DSC_0012~3 by DisoDisp, on Flickr
DSC_0013~3 by DisoDisp, on Flickr
DSC_0021~2 by DisoDisp, on Flickr
Old 01-23-2015, 05:47 PM   #24
DisoDisp
Member#: 187648
2007 WRX
Block work is still ongoing, but we've had a few parts done in the meantime.
Pistons coated with CBX and Cermalube:
männät by DisoDisp, on Flickr
12mm Oil Pump inner rotor coated with TLML:
ratas by DisoDisp, on Flickr
Manley Billet Crank, gas nitrided and polished.
Journals buffed with PKSX.
10310096_785874768134084_5110654053257358581_n by DisoDisp, on Flickr
DSC_9820-1 by DisoDisp, on Flickr
Blocks should be finished soon, more data to come once we get this rolling.
Old 08-25-2015, 07:28 PM   #25
DisoDisp
Member#: 187648
2007 WRX
Block testing and machining is taking a lot longer than initially planned, so we went for something different in the time being:
EJ22T CDB block.
14mm Studs.
RCMS 1.1mm Headgaskets.
Manley 79mm Billet Crank.
Custom Wiseco 97.5mm Pistons.
Custom Carillo 131.6mm Pro H Rods.
front mounted Borg Warner EFR 9180 1.05AR
Should be ready in a few weeks hopefully.
