Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 07-22-2014, 06:24 PM   #1
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
Default DIY: 2015 sti blinkers on wrx.
For detailed install instructions and harness purchase for this mod visit defroy.org, most of the info from this post is there and more.
Figured I would see if it were possible to put the sti blinker and caps on my wrx, well they fit, though there is no wiring for the blinkers.
Parts you will need to order:
Lamp assy turn sdlh 84401aj010
Lamp assy turn sdrh 84401aj000
Cover cap repair lh 91059va030
Cover cap repair rh 91059va020
Will also need screws 4 of them, I'll add part numbers when they come in.
First you will need to pry your stock mirror apart.
Take a pry tool and wiggle it between the upper and lower side part of mirror.
Pull the bottom trim off carefully then peel up the painted part till it snaps off.
Mirror is apart, can take a peek inside but I didn't see anything to connect the led signal to.
Video picks up after this point, Don't make fun of me im still learning GoPro studio. Also sorry for the no music or anything, could not figure that part out.
https://www.youtube.com/watch?v=iqtSpJerlIY
this is where it stops for now, will finish once all parts and I figured out wiring. Here's some pics as a tease.
clamsjager is offline   Reply With Quote
Old 07-22-2014, 06:27 PM   #2
Jason2015wrx
Member#: 392507
2015 WRX
CBS
I have been wondering if this will be available on the WRX, That stinks there are no wires for the blinker
Jason2015wrx is offline   Reply With Quote
Old 07-22-2014, 06:30 PM   #3
Valerio159
Member#: 392930
2015 WRX Limited
How much did u spend on these?
Valerio159 is offline   Reply With Quote
Old 07-22-2014, 06:33 PM   #4
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
$256.00 for everything, no paint.
Old 07-22-2014, 06:34 PM   #5
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
Should be easy enough to integrate.
Old 07-22-2014, 06:35 PM   #6
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
Now to pay $100 to have caps painted or attempt myself.
Old 07-22-2014, 06:37 PM   #7
Jason2015wrx
Member#: 392507
2015 WRX
CBS
I would be interested in knowing how to wire this up as this is something I would like on my car when I get it. Nice Post!
Old 07-22-2014, 06:41 PM   #8
CT2015WRX
Member#: 392220
2015 WRX Limited 6MT
ISM
Thank you! I was wondering if this was possible.
Does the factory mirror harness has any extra wires that aren't being used? Id assume all cars would come pre-wired bit then again WRX prob had a different harness than the STI.
CT2015WRX is offline   Reply With Quote
Old 07-22-2014, 06:52 PM   #9
Nmullin11
Member#: 353683
2015 Wrx limited
Wrb
350-400 for this is really not that bad, I may do it.
Nmullin11 is offline   Reply With Quote
Old 07-22-2014, 06:52 PM   #10
Valerio159
Member#: 392930
2015 WRX Limited
Just wrap it with vinyl for 20 bucks
Old 07-22-2014, 06:54 PM   #11
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
No $254 total for both sides.
Old 07-22-2014, 07:03 PM   #12
moosejaw42
Member#: 381747
2015 WRX Limited
Galaxy Blue
It would be nice if we could find someone with an STI to take apart their mirror and see where the wiring is coming from. This is cool though. $254 is well worth it.
moosejaw42 is offline   Reply With Quote
Old 07-22-2014, 07:44 PM   #13
noTe
Member#: 87332
2001 WRXed L Coupe
2007 Toyota 4Runner
Thanks for creating this. I don't know why Subaru would leave a safety option off the WRX but do it for the STi.
noTe is offline   Reply With Quote
Old 07-22-2014, 07:53 PM   #14
junktribe
Member#: 396364
2015 WRX
CWP
So aside from wiring, it looks like you just need the top half of the mirror and the light itself?
junktribe is offline   Reply With Quote
Old 07-22-2014, 08:16 PM   #15
graphicture
Member#: 390342
Ausie WRXs have these as standard. I wonder if they would actually make the wiring so differently for USDM models...
graphicture is offline   Reply With Quote
Old 07-22-2014, 08:20 PM   #16
graphicture
Member#: 390342
I guess impreza version of the mirror wiring isn't same as WRX's?
http://forums.nasioc.com/forums/show....php?t=2468495
Old 07-22-2014, 08:41 PM   #17
clamsjager
Member#: 172787
2008 Impreza wrx
Dark Grey
Good find! Still will have to get wire to the door and splice into that pos wire
Old 07-22-2014, 08:59 PM   #18
WRX_02_227
Member#: 12434
2002 WRX #332
2016 Audi S3
Yeah it is pretty damn dumb.
WRX_02_227 is offline   Reply With Quote
Old 07-22-2014, 09:03 PM   #19
Jonnyfive
Member#: 395731
2015 WRX Premium
It is very easy to custom wire into your existing turn signals, as I've already done it (just in a different location on the side body, hidden behind the fake wheel vents). There are only two wires, + and -, so it's impossible to screw up practically. I'll be putting amber lenses on this at some point since the overwhelming majority of people think the white is too obnoxious.
http://i.imgur.com/JZ9EFMa.jpg
http://i.imgur.com/Vrke3OG.jpg
Jonnyfive is offline   Reply With Quote
Old 07-22-2014, 10:47 PM   #20
speedrye
Member#: 395992
2015 WRX Premium
ISM
This might help. I already had my door panel off, so I figured I'd take a few pics. This is the harness from the main door harness to the mirror harness. As you can see, there are more wires on the door that don't extend to the mirror. You can probably add the harness and have a functional mirror light, but I haven't tested voltages.
Door side:
Mirror side:
Door side innards:
Mirror side innards:
speedrye is offline   Reply With Quote
Old 07-22-2014, 11:01 PM   #21
CT2015WRX
Member#: 392220
ISM
Thank you for the photos!
Old 07-22-2014, 11:29 PM   #22
DDS4
Member#: 391676
2018 Tesla Model 3
2012 Infiniti G37x
According to the service manual it is pin 1 and 5 which is at the end of that connector. Gray and Black wires for passenger side and White with Red stripe and Black for drivers side. Black is ground.
Can you buy the sti mirror assembly wiring harness? It should have the same connector but have the extra wires and the end connector for the turn signal lamp.
DDS4 is offline   Reply With Quote
Old 07-22-2014, 11:58 PM   #23
quantum13
Member#: 389143
2015 WRX Limited
this is great info; it'd be fantastic if this were as easy as swapping a harness and popping on the STI parts
quantum13 is offline   Reply With Quote
Old 07-23-2014, 06:38 AM   #24
speedrye
Member#: 395992
2015 WRX Premium
ISM
This seems legit since my picture is of the passenger side and you can clearly see the gray and black wires that are unused. Any chance you can post a picture from the manual of the connector with pin numbers shown? I can't see how 1 and 5 pins correspond with the unused gray and black I'm seeing unless the black you're referencing is the common ground for the mirror. That would leave an extra black wire for something else. Beyond that, there are two other wires that are unused as well and I'm wondering if they're for the power folding or what. Now, we just need a part number for the harness...
Old 07-23-2014, 07:31 AM   #25
DDS4
Member#: 391676
2018 Tesla Model 3
2012 Infiniti G37x
http://legacygt.com/forums/showpost....55&postcount=1 The 10 pin connector listed here has the same pin-out numbers as the side mirror connector. Pin 5 is the black ground wire and pin 1 is the left or right signal.
If you are looking at the service manual it is under the "Turn Signal Light and Hazard Light System" "Wiring Diagram".
I started researching this a month ago because I want to make the same change. I ordered my car in May and will not receive it until August.
