Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 12-29-2014, 06:12 PM   #1
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
Default AZ: 1980 Subaru "Hatch-Brat" $3500
Hey Subaru Fans
Due to financial issues I have to sell my Hatch-Brat. It started life as an 1980 Hatchback, the previous owner cut off the whole rear roof and welded in a rear wall and window from a Brat ( hence the name "Hatch-Brat"). I bought it for rallycross(and because it's AWESOME), but it doesn't do as well as I had hoped. Odo says 294,651, but with the bigger tires its not accurate.
Features include:
EJ22E converted to use 4 barrel Holly carb, uses Subaru distributor imported from New Zealand.
Duel exhaust running to duel stacks (Its loud but sounds AWESOME!)
EA82 D/R 5 Speed and 3.9 rear LSD
4" custom lift kit (just blocks to go between the chassis and front/rear crossmembers, blocks for between struts and knuckles, and longer rear shocks)
Custom 14" wheels (made by previous owner) with 27" General Grabber A/T tires (the rears rub a little but only at full compression)
Roll bar
Brush bar
Custom bumbers with a trailer hitch attachment on both front and rear
Headlight guards
A/C compressor converted to air, with a storage tank and coupler for an air hose
Peterbuilt air horns
CB radio AGM Battery
Now for the issues:
Biggest issue is the rear wall leaks into the interior whenever water gets in the bed. I'll look into getting it fixed before I sell the vehicle.
Paint is original, so there's some surface rust but nothing structural.
Holly carb is a little big for the 2.2 so it is a bit tricky to tune right, although it's been running pretty good.
Mufflers have a few holes in them
The High beams don't work because they're not wired. Shouldn't be too hard to fix, but I never got around to it.
The pilot bearing or throw out bearing is making noise, I'll be including a new clutch kit.
The bushing for the front mount of the rear diff is warn a bit and contacts the sub-frame on hard launches
The radio is a old stock GM unit and doesn't like cassette adapters, sometimes it wont play at all and other times will only play 1 channel.
Oil pressure gauge only sometimes works.
Have done the following maintenance in the past 10 mouths:
Replaced tranny fluid
Replaced rear shocks
Replaced tie rods
Replaced ball joints
Replaced front axles
Converted front springs/struts to EA82 units.
Cleaned fuel tank
Cleaned carb and replaced its seals
Cleaned and repacked front wheel bearings
Replaced alternator
More pics here: http://s376.photobucket.com/user/Man...?sort=3&page=1
Asking $3500 obo. Only trades I might consider would be '87 to '90 Subaru RX, EA82 body coupe (with preferably an EJ swap) or 90-94 Legacy wagon. Located in Sierra Vista, AZ.
Thanks for Looking!
ManYaiK is offline   Reply With Quote
Old 12-30-2014, 05:34 PM   #2
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
bump.
Old 01-01-2015, 06:12 PM   #3
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
le bump
Old 01-03-2015, 01:20 AM   #4
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
bump, will consider any reasonable offer....
Old 01-12-2015, 04:22 PM   #5
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
bumpo
Old 01-23-2015, 07:19 PM   #6
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
bumpness
Old 02-04-2015, 01:13 AM   #7
ManYaiK
Member#: 170588
1980 Hatch-Brat
Mellow Yellow
bump-a-reeno
Old 02-04-2015, 02:00 AM   #8
mattwho
Member Sales Rating: (4)
Member#: 156202
02 WRX sedan
This thing is sheer quirky Subaru awesomeness. Glws. You should post this on the SWIC Classifieds group on Facebook.
Sent from my LGLS990 using NASIOC mobile app
mattwho is offline   Reply With Quote
Old 02-11-2015, 09:55 AM   #9
Matt A
NASIOC Vendor Manager
Administrator
Member Sales Rating: (6)
Member#: 15382
. 2005 OBXT LTD
hey look at you all making to Daily Turismo!
http://www.dailyturismo.com/2015/02/...dl-camino.html
GLWS
Matt A is offline   Reply With Quote
