Welcome to the North American Subaru Impreza Owners Club Sunday October 21, 2018
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 03-30-2015, 10:35 PM   #1
GraffitiWRX
Member#: 305967
2011 Impreza WRX
Default Cam Cage
My wife's Legacy recently went into a dealer for an oil leak. What resulted was them keeping the car in order to replace the cam cage(s) which leak in 13' models. I apologize if this isn't the right place for this question but I cant seem to find an answer to what a cam cage is and why exactly thinner oil would cause the issue.
GraffitiWRX is offline   Reply With Quote
Old 03-31-2015, 03:08 PM   #2
Wrxtuner251
Member#: 135150
2006 WRX Sedan
When they say cam cage they are most likely referring to the cam carrier.
2nd picture down the RED image is the "cage"
http://drive2.subaru.com/Win11/itsWhatMakes.htm
If you are using the a oil within your vehicle specifications "found in your manual" Thinner oil should have nothing to do with a leak. A leak in that area could be a gasket problem, a machining issue with the carrier it self, or faulty oil seal around the camshafts.
Wrxtuner251 is offline   Reply With Quote
Old 03-31-2015, 09:18 PM   #3
GraffitiWRX
Member#: 305967
2011 Impreza WRX
Thanks for the answer, Ill know what specifically what went wrong when the car is returned.
Old 10-19-2015, 03:56 PM   #4
2015Forester
Member#: 432046
My left side cam carrier leaked after my short block was replaced. Currently in for repairs but I assume it was the gasket.
2015Forester is offline   Reply With Quote
Old 10-20-2015, 02:00 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
There is no gasket, just 3 bond and a couple of o-rings.
On early FB motors there may be a leaky threaded boss (unused) on the left front cam cap. I think they stopped drilling and tapping it by 2013 though.
CosmoTheCat is offline   Reply With Quote
