#1 |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
![]() I'm starting to forget what I've even done to my car, so I'm starting a log for my WRX.
The Car: 2010 Subaru Impreza WRX Hatchback Lightning Red 137,000 149,000 miles (as of 8/1/2016) 155,000 miles (as of 8/1/2017) 158,000 miles at rebuild (4/13/2018) 173,000 miles (10/18/19) Here she sat before I left the dealer lot. A grand total of 6 miles on the odometer: ![]() And here's how she sits now, five years and counting: ![]() As of 10/15/19: ![]() The Mod List: Engine & Performance: - IAG Stage 2 block (as of 4/13/2018) Pistons - Manley 99.5mm Platinum Forged Pistons, Ringset, Tool Steel Pins, Clips, (Coated Skirts and Offset Wrist Pin) Connecting Rods - IAG-Spec H-Beam Rods with ARP2000 rod bolts Rod / Main Bearings - ACL or King Race Bearings Crankshaft - Standard New Subaru Nitride Treated 2017+ STI Crankshaft Case / Main Bolts - Standard FHI Subaru case bolts - ARP Head Studs (ARP #260-4701) - Blouch 440xt (10cm, HPD Turbine Wheel) - ID 1050 Injectors - IAG v3 Fuel Rails - IAG Fuel Lines - Aeromotive Fuel Regulator (Gen-II A1000) - Radium Liquid Filled FP Gauge - AEM 320lph Fuel Pump (#50-1215) - Koyo Radiator - Cobb Intake w/ Box - Perrin 2.5" Inlet - GetADomTune Coolant mod - Perrin Turbo Heat Shield - Mishimoto Radiator Hoses - Killer B Oil Pickup - Killer B Oil Windage Tray - Grimmspeed EBCS - TGVs Deleted - Air Pump Deleted - Evap Deleted - Cobb Accessport v3 (sub003) - Process West TMIC (Black) - Grimmspeed Catted Downpipe - Limited - Grimmspeed AOS - Black (switching to ??? soon) - Grimmspeed Alternator Cover - Black - Remark (r.m.k. designs) 3.5" single exit catback - Custom Battery Tie Down - Turbosmart Kompact BPV (TS-0203-1209) - ACT HD Clutch (ACT SB11-HDSS) - Group N Engine Mounts - Group N 5sp Transmission Mount - Cobb Pitch Stop Mount (68A firewall / 85A motor) Interior, Exterior & Misc: - Crawford Carbon Fiber Spoiler - BaysonR CS Style Lip - "Chargespeed" grille (this one is definitely a fake) - 6ocrallysport Carbon Mirror Blinker Deletes - Primitive Racing Front Skid Plate - Custom Engraved Billetworkz Front Plate Delete - Carbon Fiber Rear Plate Frame - OEM Short Shifter - OEM Boost Gauge - Anarchy Motive (Black Asphalt) Mammoth Shift Knob - Circuit Motorsport Clutch Brace - Whiteline Steering Rack Bushings (KSR207) - OEM Foglight Kit - Hella Horns (painted flat black) w/ Subimods Bracket & Harness - Auto Ventshade visors - Subtle Solutions Black Radiator Cover - 'Red-out' Tail lights - Matte Black 2015+ 'WRX' Emblem (3M Gloss Dragon Fire Red [1080-G363] is a close match to lightning red. Not exactly, but close enough.) Suspension: - Koni Inserts (86101453 & 80101055) - Epic Engineering Lowering Springs - Super Pro 24mm Front Swaybar - Whiteline 22mm Rear Swaybar - Whiteline Rear Sway Braces (KBR15) - Kartboy Endlinks (Front & Rear) - Whiteline Front Lower Control Arm Brace (KSB723) - Whiteline ALK (KCA334) - Whiteline Control Arm Bushings (W0506) - Whiteline Front Roll Center Kit (KCA313) Brakes: - 2005 STi Front Brembos (TIC rebuilt) - 2011 STi Rear Brembos (TIC rebuilt) - Stoptech stainless brake lines - Hawk HPS Pads - DBA T2 Slotted Rotors - Grimmspeed MC Brace Wheels & Tires: - r.m.k. design R5 (Ark Design) - 18x8.5, +32 (05-1885Y-B32A) - Continental ExtremeContact DW - 235/40/18 Rebuilt by: Brown's Performance in Gainesville, FL. Tune Custom dyno tune by Graham @ Boosted Performance Tuning Previous Wheel Set-ups:
I'm about 90% sure that's everything. ![]()
#2 |
Member#: 177337
South East
Vehicle:2002 WRB Bugeye Pilot and Xterra |
![]() Jeebus dude. I just hit 140,000 on my 2002. Do you commute across the state for work.
#3 | |
Member#: 239822
South East
![]() Quote:
About 25 miles each way to work. Add another 20 or so if I need to pick my kid up from his mom's. All over the place on the weekends. A lot of road trips. It adds up quick... |
#4 |
Member#: 361468
Vehicle:2010 outback |
![]() Wooow, thats good for you. Do you have any major issue on racking up 140k miles? I hope mine could hit 140k like yours without any issue.
#5 | |
Member#: 239822
South East
![]() Quote:
- Leaky slave cylinder left me by the side of the road. Wound up needing a replacement, but other than the scare, no issues. - Snapped the intercooler bolt from the turbo housing, without access to my drill. My fault; another tow to the mechanic... - Leaky steering rack my mechanic found while repairing the broken bolt. Thankfully didn't fail on the road. That's why I had the whiteline bushings put in. - I just recently had to refill the coolant on my AC. Has been fine for a few weeks since, so I don't think anything's busted. Otherwise, she's been really good to me. Which is great since I plan to keep this car until the wheels fall off... |
#6 |
Member#: 259184
Vehicle:2008 Subaru WRX Silver |
![]() That's the cutest list I have ever seen for 5 years of ownership.
#7 |
Member#: 239822
South East
#8 |
Member#: 311911
SCIC
Vehicle:2012 WRX Limited Sdn SWP (TP Stg 2) |
![]() Curious...how long have you been on cobbs ots tune?
#9 |
Member#: 239822
South East
#10 |
Member#: 259184
![]() Doesnt look like you took my comment as something rude, hard to convey my playful nature over text.
What I would personally do it get a fuel pump and an ebcs with a torque performance tune. That would be my stopping point if I was a manual. And if you don't mind the lost of the rumble, an ELH setup would be great as well. any more than that would be going overboard unless you like to do that. Just some things I've learned on my journey with my car. |
#11 | |
Member#: 239822
South East
![]() Quote:
In the worst case, if I spin a bearing I'm just going to replace with a new OEM block, but she's done for now. Earlier this year, I was feeling the pull to go bigger but it's not the time right now. I went so far as to impulse buy a BNR turbo, which is sitting as a paper weight on my desk at work. It's not even the direction I'd go if I WERE going to upgrade today... Otherwise, I have some interior stuff that I want to do and I have to paint the Crawford spoiler before I install it. Maybe consider replacing the hood, which has taken the brunt of the road debris, but still deciding. And that's it. Thanks though... |
#12 |
Member#: 301037
Vehicle:2004 Forester XT Aspen White |
![]() I know a thing or three about impulse buys, I've got a basement full of them
![]() -Art |
#13 |
Member#: 311911
SCIC
![]() I would just like to reiterate what TrustKevin said about gettting a TP tune. Running that IC on the OTS tune might not be such a good idea. I'm not saying your car is going to blow up tomorrow, but you've increased your chances a lil bit. You aren't heavily modified but heed the warnings haha And if you do end up rebuilding, best thing to do is not throw in the same crappy pistons and bearings. At least go forged for those to prevent it from happening again
#14 | ||
Member#: 239822
South East
![]() Quote:
![]() Quote:
![]() Regarding a rebuild; it's always a give & take. Sure a forged set-up would be stronger, but longevity is going to be worse. I drive this thing a LOT and I don't want to have to rebuild every few years. Well maintained and at stage 2 levels, I don't see a reason why a stock 255/257 would be an issue. Not totally decided, but I don't have to make that decision yet. Thanks guys... |
#15 | |
Member#: 301037
![]() Quote:
![]() -Art |
#16 |
Member#: 272471
TXIC
Vehicle:2010 WRX FlareObody Red |
![]() ![]() Can't wait to see the Crawford wing, been wanting to pull the trigger on that one myself. |
#17 |
Member#: 239822
South East
#18 |
Member#: 239822
South East
![]() So, post rebuild and finishing out the break in miles, but everything is running great! Took some updated cell pics:
Post rebuild and wash: https://i.imgur.com/nQ75nhq.jpg The clear coat on the hood scoop was severely failed, so I had that and the rear spoiler wrapped to match: https://i.imgur.com/0a4B0Se.jpg I had the underside of the spoiler left naked, so the carbon fiber shows through: https://i.imgur.com/NBsypvS.jpg |
#19 |
Member#: 239822
South East
![]() Sort of quietly, I crossed the 9 year ownership mark in September. Had a couple of months chasing a random boost leak, which has finally been tracked down and eliminated. Bonus is that I have a bunch of new hoses and claps everywhere!
![]() Spent some time repolishing the headlights recently, which made a friggen huge difference. Some mods are also waiting in the wings (intake, new AOS & turbo heat shield) and I'm contemplating some others, but she's driving marvelous right now. Just in time for boost weather. Here's a pic from this week, dirty as ever: ![]() Last edited by Stretch18; 12-10-2019 at 12:33 PM. |
#20 |
Member#: 137959
SCIC
Vehicle:2008 WRX Silver |
![]() Nice build! Good to see you putting the miles on!
