Welcome to the North American Subaru Impreza Owners Club Sunday July 23, 2017
Old 11-18-2002, 01:56 PM   #1
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Default Injector Pulse Width to Injector Duty Cycle
Is there a conversion? With my nearly stock WRX, I see 2.30 ms at idle and a steady 20.73 ms at WOT in 2nd gear. There is talk in other threads about the high IDCs that even mildly modified cars can attain and I'm wondering where I baseline before I start raising boost.
Thanks!
Mitch
SonicWRX is online now   Reply With Quote
Old 11-18-2002, 04:07 PM   #2
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Re: Injector Pulse Width to Injector Duty Cycle
Thanks!
Mitch
There are a number of means, but here's what I've used:
Maximum permissible pulse width:
M * 60,000
rpm
where M= inj duty cycle, and rpm = max rpm / 2 (for seq. firing injection)
The rule of thumb I've read is never exceed 16msec (that means you're either running the injectors too hot, or your test equip. is wrong )
To calculate (approx) fuel flow per cylinder on petroleum:
HP * K
C
where HP is max hp, K= 4.6 for n/a, 5.6 for blown/turbo, C= number of cylinders So, for ex. if you wanted 400hp from our engine, the above ans. would be 560cc per cylinder (100% duty cycle)
What size injector (cc) based on prev formula:
TF * 100
N * M
where TF = theorical flow, N= number of inj per cyl, M injector duty cycle. Again using the previous data, the answer (assuming a max duty cuycle of 80%) is 448cc.
HTH
n2xlr8n is offline   Reply With Quote
Old 11-19-2002, 08:54 AM   #3
Z1 Performance
Member#: 9327
Z1 Performance is offline   Reply With Quote
Old 11-19-2002, 09:36 AM   #4
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Great thread. Thanks Adam. Makes me doubt what my Techtom is reporting. I am definitely getting consistent injector pulse width readings of over 20ms which in a nearly stock condition as I am makes no sense.
Mitch
Need help with injector pulse width settings LiquidForce Commercial ECU Reflashes 2 08-13-2006 02:21 PM
Injector Pulse Width Change qhatherly Engine Management & Tuning 1 06-11-2005 12:16 PM
How to extend the injector pulse widths by cylinder john banks Engine Management & Tuning 16 09-16-2003 01:16 PM
Need injector pulse width help... 8Complex Engine Management & Tuning 10 05-12-2003 03:23 PM
Tapping Injector to measure Duty Cycle Xeno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2002 03:56 PM
