Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 02-03-2016, 04:15 PM   #1
SpicyPeaNut
Member#: 43310
1978 Brat
Default GR STI to GR WRX suspension
In my quest to make the STI a more comfortable daily driver I've read posts from 3 different forums and all that people want to tell me is to either deal with the ride (you bought an STI, what did you expect) is the typical response I get. Or spend $3000+ on a set of high end coil-overs. Which may or may not give me a softer ride.
So in my quest to get more enjoyment out of the STI and after reading hundreds of posts online a new thought occurred to me. If I am happy with the ride of a GR WRX (or even the base GR Impreza), why can't I just swap the entire strut assembly.
Well, you can't because the housing on the strut is different between the WRX and STI.
Then I saw a thread of how the strut assembly was taken apart (don't remember if it was an STI or WRX), the spring, and insert were removed completely. Which leads me to my actual question.
Can I take the STI strut apart, and swap the WRX insert and WRX spring into the STI strut housing?
That way I will have a more compliant ride for driving to and from work on the awful 405 freeway everyday.
SpicyPeaNut is offline   Reply With Quote
Old 02-03-2016, 04:30 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I would talk to the guys a Feal. They can probably revalve your current struts and get you a "softer" ride.
http://forums.nasioc.com/forums/show....php?t=1930672
Old 02-03-2016, 04:42 PM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
No you can't, different dimensions and the STI fronts are inverted. Talk to Racecomp Engineering about their Bilstein struts. They now offer a "comfort" valving option which would be very comfortable with stock springs.
boost junkie is offline   Reply With Quote
Old 02-03-2016, 05:15 PM   #4
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Comfort comes from softer springs.
Softer dampers just mean more boingy.
chimchimm5 is offline   Reply With Quote
Old 02-03-2016, 05:52 PM   #5
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Nope. It's not quite that straightforward.
AndyRoo is offline   Reply With Quote
Old 02-03-2016, 06:30 PM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Yeah no.
Old 02-03-2016, 06:38 PM   #7
SpicyPeaNut
Member#: 43310
1978 Brat
I completely forgot about Feal. I was hoping to just swap the inserts but it sounds like that will not be an option.
That is another great option but I think this would be more expensive than having Feal re-valve the stock shocks.
Yeah no.
If I had Feal re-valve the STI inserts, would a softer spring (WRX vs STI) give a non-bouncy softer ride than using the STI springs?
Old 02-04-2016, 10:46 AM   #8
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
When properly damped, the STI springs should be plenty soft. WRX rates will be too low for the car's weight and could actually give you worse ride quality by sending the dampers into the bump stops too often. This chassis is pretty travel challenged in the rear so you need a bit of spring rate to keep you off the stops.
Old 02-04-2016, 02:05 PM   #9
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Just for clarification, so you can make a 10k spring "comfortable" just by changing the valving to a "softer" profile?
Old 02-04-2016, 02:09 PM   #10
Waddlz
Member#: 395275
2012 STi
I didn't realize the stock GR STi suspension was uncomfortable. I guess driving around a previous car that was lowered has made me think its luxury lol
Waddlz is offline   Reply With Quote
Old 02-04-2016, 02:31 PM   #11
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
If you have a car with 10k springs, you can usually make it more comfortable with a "different" valving profile. This might mean a compromise with handling, but many coilovers out there aren't valved very well to begin with so it's certainly possible to improve both with either a revalve or different shocks.
Changing to softer springs might also make it more comfortable. Sometimes this is the way to go (as long as the car has the travel and valving to match).
FWIW I've ridden/driven many cars with 10k springs that rode better than stock STIs.
Old 02-04-2016, 03:16 PM   #12
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I see what you're saying.
So while magic God-damper valving can make a stiffly sprung care "comfortable", isn't it easier, cheaper, and less trial&error prone to just go with a softer spring and more readily available dampers?
Old 02-04-2016, 03:25 PM   #13
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
They don't have to be magic dampers but it helps if they don't completely suck.
An example is the current 2016 WRX. The springs are much stiffer than a 2004 STI and yet it rides so much better. The 2016 shocks aren't amazing, but they're okay enough.
BUT yes with a softer spring you can get away with a more average shock. Stiffer springs require IMO a good quality shock.
- Andrew
Old 02-04-2016, 04:21 PM   #14
jamal
Member#: 71875
I have been in some really stiffly sprung cars that actually rode nicely because the shock were set up well.
One was a lancer ralliart with some revalved kw clubsports, I think the front springs were something like 16k, and it was low. Was one of those loaner cars mitsu gave out years ago and was being daily driven by the shop owner's wife, a middle-aged school teacher.
I think a big part is having a more digressive curve, so good low speed control and then keeping the high speed forces from getting excessive, and also having a shock that works at low speeds and displacements. Cheaper shocks just tend to not have that. If you read the jrz guy's wierd, rambling, typo-filled book (vehicle dynamics and damping), he spends a lot of time on that.
jamal is online now   Reply With Quote
Old 12-06-2018, 02:48 PM   #15
mattagaffer
Member#: 177888
2002 Bugeye
Wagon
Did you ever find a solution to your problem? I'm in the same boat.
If you did go with Feal, what's your impression and did you also change springs?
I was thinking of adding the new king springs that raise the chassis an inch. They're 20% stiffer overall but they're progressive. I was thinking this, combined with extra height and softer shock might create a softer ride despite the stiffer overall spring.
mattagaffer is online now   Reply With Quote
Old 12-06-2018, 03:07 PM   #16
jamal
Member#: 71875
Do you have a GR or an 02 wrx? The suspension options are different depending on which and this thread was about the newer cars. Racecomp Engineering's Bilsteins would be a good option for an 08+
If you have an 02, just new shocks would be a good start, even if they're not fancy. KYB excel-gs for example or AGXes if you want something adjustable. Or tokico d-specs if you can find a set. They've been on clearance for awhile and my source just ran out. Oakos might have a couple left?
Old 12-06-2018, 03:12 PM   #17
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Here's an idea: Go with 1" smaller rims but go with a tire that'll keep your overall diameter the same. Thus, more sidewall. More sidewall = more cushion.
Might take some of the edge off of the ride.
SirBrass is offline   Reply With Quote
Old 12-06-2018, 03:19 PM   #18
mattagaffer
Member#: 177888
2002 Bugeye
Wagon
Mine is a GR - 2013 hatch...
I was thinking that as well, especially for the smaller undulations. I may go both routes but I figured I'd start here.
Old 12-06-2018, 07:07 PM   #19
SpicyPeaNut
Member#: 43310
1978 Brat
Thanks for the reply. I actually never did. I went so far as to buy another stock sti set of springs/struts but sold them rather than having them re valved. Please keep us posted on the thread should you decide to go with any of the suggestions found here & how it works out.
Old Today, 09:51 PM   #20
mattagaffer
Member#: 177888
2002 Bugeye
Wagon
Turns out Feal doesn't revalve GR struts anymore. They suggested their 441 max travel coilover but with 6k springs I can't imagine the ride will be smoother than stock, especially with a pillowball top mount. So back to square one...
Anyone tried the cusco struts?
