Welcome to the North American Subaru Impreza Owners Club Friday February 21, 2020
Old 02-09-2016, 03:37 PM   #1
Sammythebugeye
Member#: 421533
Default $600 big brake kit for 5x100 subarus
http://www.ctsvbrakeswap.com/frs-brz...er-bracket-kit bracket for the kit
https://www.facebook.com/photo.php?f...eater&refid=12
Parts list for the kit.
Uses 2015 ATS brembos, seems legit. Anyone tried this yet?
Sammythebugeye is offline   Reply With Quote
Old 02-09-2016, 04:04 PM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
been wondering myself.
rexworx is offline   Reply With Quote
Old 02-09-2016, 04:09 PM   #3
jamal
Member#: 71875
It would be important to know the piston sizes for those calipers. If they are wrong it could completely ruin brake feel and bias and maybe make the ebd system not work properly.
jamal is offline   Reply With Quote
Old 02-09-2016, 05:33 PM   #4
CZDeaver
Member#: 329938
2013 WRX
So interested in this. If you can get more information this would be an amazing upgrade for my stock brakes
CZDeaver is offline   Reply With Quote
Old 02-09-2016, 05:35 PM   #5
vicious_fishes
Member#: 158864
2003 SOHC destroker
this.
though the cheapest big brake upgrade is the LGT brakes, followed by the Z32 calipers with kns adapters/LGT rotors.
vicious_fishes is offline   Reply With Quote
Old 02-09-2016, 08:35 PM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by vicious_fishes View Post
this.
but the calipers arent included
subaru_gc8 is offline   Reply With Quote
Old 02-09-2016, 10:28 PM   #7
WRX boarder
Member#: 328399
2012 WRX Limited
From what I have been able to find the ats piston diameter is 4x42mm and sti is 4x46
WRX boarder is offline   Reply With Quote
Old 02-09-2016, 11:08 PM   #8
Sammythebugeye
Member#: 421533
I think these with lgt rears would be a rad combo
Old 02-09-2016, 11:18 PM   #9
vicious_fishes
Member#: 158864
2003 SOHC destroker
that's good if true - just need to know the position (so leverage) of the pistons now.
Old 02-09-2016, 11:43 PM   #10
jamal
Member#: 71875
Sti calipers use two different sized pistons. 40mm and 46 I think?
If the ats pistons are also staggered, you'd need to make sure they end up in the right direction.
Old 02-09-2016, 11:49 PM   #11
Sammythebugeye
Member#: 421533
There's a picture on the websites Facebook page of the calipers on an 06. It's crazy you can buy those calipers for $124, I wonder how long those will last if the subaru community starts scooping them up.
Old 02-10-2016, 04:46 PM   #12
Sammythebugeye
Member#: 421533
some stolen pics off FB, getting more tempting everyday to rack up the credit card with these bad boys
Old 02-10-2016, 07:51 PM   #13
CZDeaver
Member#: 329938
2013 WRX
So much want!
Do we know if guys running a 18 x 9.5 +38 or +40 will need a spacer with this set up?
Also are any of the steel braided lines we use for our cars ok with the ATS calipers?
Old 02-10-2016, 10:08 PM   #14
Sammythebugeye
Member#: 421533
Contact that FB page, the guys are super responsive but as far as I know, anything the sti brembos will fit these will.
Old 02-11-2016, 12:27 AM   #15
sc00by4life
Member#: 97135
So much want!
Brake clearance depends on the individual wheel design. Offset and width mean nothing.
Old 02-11-2016, 04:43 PM   #16
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
that is a nice set up for a budget build for sure..
bmxhotsauce is offline   Reply With Quote
Old 02-16-2016, 09:12 PM   #17
BrennanOwn
Member#: 426379
16 Legacy
steel blue
Question? Why would you do this over other break applications? The fact that it's cheap or something?
BrennanOwn is offline   Reply With Quote
Old 02-16-2016, 10:53 PM   #18
AZP Installs
Member#: 40160
I've asked those guys several times in several of their threads if they've been tested. Haven't heard anything about them actually being tested. For instance are they like the STi Brembos that have pad-knockback on 5x100 hubs? That's the biggest thing I would be worried about.
-Mike Paisan
AZP Installs is offline   Reply With Quote
Old 02-17-2016, 12:18 AM   #19
JarHarms
Member#: 138994
06 WRX Ltd
resist the AG/VS
Interesting. I'm guessing from their description they are using the ATS-V rear 4pot calipers with this mount design. As far as I could find (not a lot of good info that I could find) for piston sizes:
ATS non-V front 4pot fixed Brembo (4) 42mm pistons.
ATS non-V rear 1pot slider (1) 43mm piston.
2016 ATS-V front 6pot fixed Brembo (2) 30mm, (2) 34mm, (2) 38mm pistons.
2016 ATS-V rear 4pot fixed Brembo (4) 30mm pistons.
STI front Brembo caliper (2) 40mm and (2) 46mm pistons. 46mm pistons on the top (nearest bleeder) I am pretty sure.
BRZ front 2pot slider (2) 40mm 38mm pistons.
If my maths still holds up (per caliper): whoops, I messed that up
STI 40/46 = 23235.21 mm2
FHI 40/40 = 20106.19 mm2
BRZ 40/40 slider = 5026.54 mm2
- sizes probably not correct
ATS-V rear 30/30 = 11309.73 mm2
ATS 42/42 = 22167.07 mm2
Corrected (per caliper):
STI 40/46 = 5837.08 mm2
FHI 40/40 = 5026.56 mm2
ATS-V rear 30/30 = 2827.40 mm2
ATS 42/42 = 5541.76 mm2
Not sure how those would exactly compare between each other. Staggered pistons -vs- not staggered. Total surface area difference and what not. Seems like the ATS non-V front caliper is a better match, not sure if it mounts up the same or not. I'm betting their kit has little to none actual braking testing involved at this point. It is more or less a way to bolt up relatively larger and fancy looking fixed 4pot calipers...on the super cheap.
In the end they would have the same limitations as STI Brembos so I expect this is fine for most people installing them for looks. For anyone focused on any serious track braking advantage.....they are looking at entirely different (and more spendy) brake options. Time will tell.
Last edited by JarHarms; 03-01-2016 at 03:20 PM. Reason: corrections, additional detail
JarHarms is offline   Reply With Quote
Old 02-17-2016, 02:02 AM   #20
WRX boarder
Member#: 328399
2012 WRX Limited
I went ahead and ordered everything today. All told I'm into it for about 630 which got me two: calipers, ss brake lines, pads, pin kit, rotors and mounting brackets. For this price I was only finding beat up STI calipers in various states of load likely needing rebuild/paint and would still need rotors and various small parts. I'm hoping for better pedal feel and heat handling from this kit for light track duty and that I can fit it with my stock 17s. I'll report back after I finish install and get some miles on it
Old 02-17-2016, 02:57 AM   #21
sc00by4life
Member#: 97135
I would doubt it. For the 2005 year, Subaru added a simple 2-point brace/harmonic damper behind the caliper mounting points which fixed the knock back problem. In 2006, they added more material between the caliper mounting points on the actual knuckle. Thats why 2005 sti has longer caliper bolts than 2004, 2006-07.
The bracket for this kit looks like it would perform a similar function.
Old 02-17-2016, 05:55 PM   #22
jamal
Member#: 71875
uh, no, a little extra bracket behind the caliper bolts or a lump sticking off the upright aren't going to do anything to prevent knockback. Those were more of an anti vibration and squeal thing as far as I know.
What DID reduce/eliminate pad knockback for 05 was the bigger hubs and bearings.
So, if you put this kit on a wrx you could definitely run into knockback. A floating 2-piece rotor could help.
Old 02-17-2016, 06:05 PM   #23
JarHarms
Member#: 138994
06 WRX Ltd
resist the AG/VS
Indeed the STI knuckle brace and nub are nothing more than NVH features. And a stretch even at that. As said, knock back was decreased with the switch to hub unit bearings.
WRX Boarder, Which exact calipers are you using? The 4pot 30mm pistons or the 42mm pistons?
Old 02-17-2016, 08:49 PM   #24
WRX boarder
Member#: 328399
2012 WRX Limited
I got the caddy brembos
Old 02-17-2016, 11:00 PM   #25
JarHarms
Member#: 138994
06 WRX Ltd
resist the AG/VS
"Caddy Brembos" as in ATS non-V front 4pot fixed Brembo (4) 42mm pistons?
