Welcome to the North American Subaru Impreza Owners Club Wednesday May 23, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-21-2016, 02:17 PM   #1
PRL Motorsports
Member#: 420981
Default PRL Motorsports 2015+ WRX FMIC Install Instructions
The test subject
Unboxing our FMIC kit with all of its contents
Take one last look at this clustered engine bay, because you won’t be seeing this anymore
Disconnect the negative battery cable from the battery to avoid electric shock
Remove the plastic clips that hold the cover down on the factory top mount intercooler
Remove the plastic clips that hold down the intake air duct
Remove the clip holding down the windshield washer fluid filler neck so that we can relocate using our supplied billet piece.
Pop the windshield washer fluid filler neck out. Please note that this is held in with an O-ring.
Loosen the factory charge pipe clamp on the passenger side of the intercooler
PRL Motorsports is offline   Reply With Quote
Old 07-21-2016, 02:18 PM   #2
PRL Motorsports
Member#: 420981
Repeat the same process for the driver’s side throttle body hose clamp
Remove the 12mm intercooler mounting bolts
Your engine bay should now look like this
Let’s move onto removing the bumper:
Old 07-21-2016, 02:18 PM   #3
PRL Motorsports
Member#: 420981
Remove the clips and bolts that hold the factory splash shields in place underneath of the car
Remove the clips on the top of the bumper cover
Remove the bolts holding the top of the bumper cover pieces on
Press in the upper bumper tabs going into the inner fender lining
Disconnect fog lights from the harness
Pull out on the sides of the bumper covers
Old 07-21-2016, 02:19 PM   #4
PRL Motorsports
Member#: 420981
The bumper cover should come off like this
Your car should now look like this
Remove the 14mm bolts holding down the bumper bar
Remove the bumper bar and put it aside
Remove bolt that holds the horn down
Remove the intake bracket bolts
2018+ models Require the removal of the added passenger brace that the 2015-2017 models don't have.
Old 07-21-2016, 02:20 PM   #5
PRL Motorsports
Member#: 420981
Disconnect the fan from the wiring harness
Remove the 10mm bolts that hold down the fan so that it can be removed
Remove the fan
Remove the hose clamps on the lines coming off of the bypass valve and boost source lines near the base of the charge pipe
Remove the two 12mm bolts at the base of the charge pipe to compressor inlet to remove the charge pipe
Old 07-21-2016, 02:21 PM   #6
PRL Motorsports
Member#: 420981
Take one good look at this heap and call it bad names because this is what has been holding you back from making all of that sweet power you’ve been wanting
Install the steel brackets to the sides of the front mount intercooler using the supplied hardware. Keep all bolts / connections loose for the time being so that adjustments can be made for optimal fitment.
Old 07-21-2016, 02:21 PM   #7
PRL Motorsports
Member#: 420981
Disconnect the wiring loom clip, loosen the 14mm bolts and remove the bumper bar brace
Loosen the clamp on the throttle body to remove the throttle body coupler
Install our supplied 2.75”-2.5” reducing coupler to the throttle body using our supplied T-bolt clamps. Please note that clamps are numbered according to size.
Old 07-21-2016, 02:22 PM   #8
PRL Motorsports
Member#: 420981
Assemble the two passenger intercooler pipes, keeping connections loose. The hump hose should be placed at the connection beside the battery.
Remove the O-ring from the windshield washer fluid filler neck
Install the factory O-ring on the supplied billet filler neck, as well as the factory filler neck cap
Install the windshield washer fluid reservoir the same way in which it was removed
Slide our supplied billet filler neck into the reservoir
Install the existing charge pipe O-ring gasket off of the factory piece onto our supplied compressor outlet pipe. Please note that version 2 pipes no longer require the use of the tab, customers are to cut this tab off
Install our supplied compressor outlet pipe reusing the factory 12mm bolts, keep loose for adjusments
Old 07-21-2016, 02:22 PM   #9
PRL Motorsports
Member#: 420981
Install our supplied intake mounting bracket reusing the factory bolts
This customer decided to utilize our option of the Tial QRJ bypass valve. We supply Tial BOV / BPV components with all of our turbo / intercooler kits because of the quality and price point. The QRJ piece allows customers the ability of recalculating or venting to the atmosphere by interchanging threaded adapter pieces!
Assemble the BPV hose with the shorter hose connecting to it. Here is a side-by-side comparison of the OEM valve compared to the Tial QRJ… Yes, that little metal piece is the valve on the factory piece. No wonder they ALWAYS leak! We strongly recommend upgrading the BPV when installing charge pipe or intercooler kits.
Assemble the passenger side intercooler pipes keeping connections loose
Assemble the supplied recirculation hose with the single bead-rolled aluminum piece facing in towards the short end (closest to the bend) of the longest hose. QRJ applications feature a longer hose than OEM fitment BPVs
Old 07-21-2016, 02:23 PM   #10
PRL Motorsports
Member#: 420981
Attach the BPV, connecting the two supplied 90 degree recirculation hoses with the double bead-rolled aluminum tube. Reinstall all boost / vacuum lines, tighten down all connections, torque compressor outlet pipe to 16NM or 11.8 ft/lbs
Old 07-21-2016, 02:23 PM   #11
PRL Motorsports
Member#: 420981
Make sure that all piping and components are rotated and positioned in desired, comfortable positions. Once happy with fitment, tighten down the intercooler mounting brackets and T-bolt clamps.
Customers will need to modify this portion of the splash shield due to pipe routing. We suggest measuring twice, marking the cut, and trimming to fit
Reassemble the fog lights, bumper cover, splash shields and inner fender liners in reverse of the way they were removed. Your car should now look like this!
Old 07-21-2016, 03:14 PM   #12
tank the ek
Member#: 295911
2015 WRX
LR
I do not personally have this kit, but reading through this nicely presented installation puts this clean and complete kit on a nice display. The various aftermarket companies investing into products for the FA platform at the same time has made for some very nice products, and alot of tough decisions for the enthusiasts in this market to make.
Kit and installation instructions look great guys. Keep crushing it!
tank the ek is offline   Reply With Quote
Old 07-21-2016, 03:50 PM   #13
TheTurboFD
Member#: 418461
2016 WRX
Red
Nice write up!
TheTurboFD is offline   Reply With Quote
Old 07-21-2016, 04:09 PM   #14
ArmyOfSkittles
Member#: 410629
2015 WRX
Looks like a good write up
ArmyOfSkittles is offline   Reply With Quote
Old 07-21-2016, 04:15 PM   #15
anjuna
Member#: 401977
IDFK Wat
bish whet
fabworks makes some beautiful stuff
anjuna is offline   Reply With Quote
Old 07-21-2016, 04:20 PM   #16
PRL Motorsports
Member#: 420981
Thanks guys, keep us posted if anyone has any questions!
Old 12-28-2017, 05:08 PM   #17
PRL Motorsports
Member#: 420981
2018 model fitment confirmed!
Old 02-01-2018, 11:42 AM   #18
DonDonDon
Member#: 476596
2015 WRX
Great write up! One question. Is it me or does the BPV look to be installed backwards? On the OEM charge pipe, the head of the BPV sticks out away but on the hot side pipe of the intercooler the Tial BPV head points in the same direction as the piping.
DonDonDon is offline   Reply With Quote
