Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 10-16-2016, 11:00 AM   #1
blackbird984
Member#: 436074
2012 Impreza Base
Default Oil Leak around Filter
Hi All,
Im new to Subaru but not new to changing my own oil. I have performed three oil changes on my '12 Impreza and I've noticed something I have never seen before. There is oil in the tray around the filter. I took some pictures for you all to see. Is this normal? The filter is WIX, oiled seal with new oil and turned past contact to make sure it good and tight on.
If this is not normal, how do I prevent this?
PS. I re-posted this in the Maintenance section, I think this belongs there. Can an admin help me with this?
Last edited by blackbird984; 10-16-2016 at 11:15 AM. Reason: trying to switch sections
blackbird984 is offline   Reply With Quote
Old 10-16-2016, 03:13 PM   #2
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
Are you sure this didn't spill out of the old filter? After draining the oil (I installed one of these: http://www.fumotousa.com/), if you just barely loosen the old filter to crack the seal, and wait 5 minutes, no oil will spill.
If your new filter is really leaking, time for a new filter. Lots of debate on that, but I use a Pureone PL14610, mostly cause the color matches the filler cap (!)
Rymar is offline   Reply With Quote
Old 10-16-2016, 08:25 PM   #3
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
drain the pan first,then crack the filter a little. it will drain back down. then wipe that housing down and install the new filter. like rymar said,fumoto valves are great. i have them in all 3 subarus we own. no tools needed and no splashing oil and mess.
424wrx is offline   Reply With Quote
Old 10-17-2016, 03:04 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I'm pretty sure the OP is referring to this is now leaking AFTER they already completed an oil change.
Samurai Jack is offline   Reply With Quote
Old 10-18-2016, 08:25 PM   #5
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
no sure maybe a bad O ring on the filter if you have your warranty you might as well take it in.
bmxhotsauce is offline   Reply With Quote
Old 10-21-2016, 01:35 PM   #6
Kuros
Member#: 328669
2017 STI
Red. Duh
Happens all the time. Most leak a little. Some don't.
Most do.
Kuros is offline   Reply With Quote
Old 10-21-2016, 03:50 PM   #7
Rymar
Member#: 310672
Dark Gray Metallic
In decades of changing oil and replacing filters, I have never seen a new oil filter leak. Fram, WIX, Purolator, Honda, Subaru, Toyota, whatever....
Old 10-23-2016, 01:37 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
In decades of changing oil and replacing filters, I have seen multiple brand filters leak.
Either there was an issue with the way the rubber seal was installed at the manufacturer or the seam where the filter cap was installed to the filter body.
Mainly Fram and Wix, which is why I primarily only use Subaru now.
And there was a time not so long ago when Subaru had issues with their black filters
Old 10-24-2016, 02:25 AM   #9
drpoop
Member#: 421858
2012 Impreza
Most do.
Not even remotely true. Get out of here with your bullcrap lies. Filters are not supposed to leak when they're correctly tightened. And 99% of them don't. There's not a chance in hell over 50% of filters on all vehicles leak.
drpoop is offline   Reply With Quote
Old 10-25-2016, 08:55 AM   #10
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Absolutely agree
