Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 11-04-2016, 12:03 PM   #1
grindMARC
Member#: 23547
13 Focus ST
Blurple
Default 2011 Forrester with oil all over engine bay
A friend just called me up saying he took his car in for an oil change at NTB and the tech told him there was oil all over the engine bay. It's not that cap, not the dip stick. He's bringing it by after work for me to have a look at it. He said there have been no leaks under the car at all. Funny thing, when he called me from the store, I didn't realize he was at an oil change shop. I asked him to ask the "mechanic" where the oil was leaking from. No lie, he says, "its coming from the engine."
Anyone have any theories of what might be the cause? I think it has 100k on the clock.
grindMARC is offline   Reply With Quote
Old 11-04-2016, 07:18 PM   #2
grindMARC
Member#: 23547
13 Focus ST
Blurple
There's oil under the air conditioner compressor coming from the front of the motor. Is that a cam seal or a main seal?
Old 11-05-2016, 04:51 PM   #3
MikeWRX90
Member#: 367671
2013 WRX Sedan
Ice Silver Metallic
Its either coming from the front timing cover, or from one of the cam carriers. My bet is the front cover since they are notorious for leaking after a while. Ive done a ton of them at work, and requires a re seal. Hope this helps.
MikeWRX90 is offline   Reply With Quote
Old 11-05-2016, 05:17 PM   #4
grindMARC
Member#: 23547
13 Focus ST
Blurple
I had a better look at it today in the sunlight. It's definitely coming from the bottom of the timing cover on both sides. Since he has 90k on the clock does this repair add much to the cost of a timing belt job?
Old 11-06-2016, 04:38 PM   #5
MikeWRX90
Member#: 367671
2013 WRX Sedan
Ice Silver Metallic
No timing belt, timing chain, and it all depends. If both cam carriers are leaking the engine will need to come out for them to be resealed, and the front timing cover will need to be removed anyway to perform that. If its just the front timing cover, it can be re sealed with the engine in the car.
Old 11-06-2016, 05:56 PM   #6
grindMARC
Member#: 23547
13 Focus ST
Blurple
Thanks, man. This info is really helpful. It sounds like he's going to trade it as is.
Old 11-07-2016, 02:08 AM   #7
MikeWRX90
Member#: 367671
2013 WRX Sedan
Ice Silver Metallic
Glad I could help!
Old 11-07-2016, 03:43 AM   #8
CLL_OBP
Member#: 310435
'12 Sport Limited
Mobil 1 0W20 141,012 mi
This happened on my FB20 engine as well. First the timing chain cover was resealed in Oct 2014 and then the engine pulled to reseal the cam carrier in Jan 2015. I was under powertrain warranty, so no charge.
MikeWRX90, what's the cost in labor hours for this? Even though it was no charge, the first time took 8 hours and the second time pulling the engine took four days.
It's been 48,000 miles since the repair and the bottom of my engine is all dry under the cam carriers, rocker covers and timing chain cover. If this is all that's wrong with your friends forester, it might be worthwhile to fix.
http://forums.nasioc.com/forums/show....php?t=2671822
CLL_OBP is offline   Reply With Quote
Old 11-07-2016, 04:45 PM   #9
grindMARC
Member#: 23547
13 Focus ST
Blurple
You'd better knock on wood! There are a lot of people with recurring leaks after the cam carriers swap and resealing the cover!
After talking with him more this morning, I think he's going to take it to the Subbie store for an estimate on the cover. Of course, he won't know if it needs carriers until the cover is off. But, if it does need carriers, I think he's going to just have them reseal the cover and hopefully stop the leaks long enough for him to trade it. If the carriers look ok, he'll probably keep driving it for a while.
