Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2022
Old 11-19-2016, 11:30 AM   #1
Motion Lab Tuning
Member#: 228856
Default Motion lab Tuned 2014 STi 511WHP/519WTQ GTX3071r tuned with Cobb Flex Fuel
Shop: Motion Lab Tuning
Dyno Type: DynoCom FX5000-AWD
Temp: 74F
Boost: 27psi
Fuel: E85
Target AFR: 12:1
SAE Corrections: Default Corrections
Peak HP at RPM: 511whp @ 5550 RPMs
Peak Torque at RPM: 519wtq @ 4850 RPMs
Transmission: Stock 6 speed
Gear: 4th
Engine Management: Cobb AP V3 w/ Speed density + Flex Fuel
Engine/Power Modifications:
This is a customer that came to us from Tennessee after making some big changes over his last turbo set-up that we tuned with Flex Fuel. He opted for the ETS rotated turbo kit with a Garrett GTX 3071r turbocharger and their 4" FMIC kit. Upgraded to the ID 2200cc fuel injectors and hardwired the existing AEM 320LPH fuel pump kit. The fuel pump was ultimately what limited us, although the customer didn't want to go much higher than this with the stock rods still in the bottom end. Heads were stock as well, this set-up would benefit greatly from a better set of cams. Tune came out super smooth and the Flex Fuel software is a dream to tune with!
Final HP/TQ w/ Boost:
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
[email protected]
MotionLabTuning.com - Engineering Performance
Motion Lab on Instagram
Motion Lab Tuning is offline   Reply With Quote
Old 11-19-2016, 06:49 PM   #2
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
great results on a 3071 at that! any pump numbers for us in non-cornfuel world to compare to?
bluemax189 is offline   Reply With Quote
Old 11-21-2016, 09:06 AM   #3
Motion Lab Tuning
Member#: 228856
Yeah the spool was a lot more fun than the 3076r too. It came out exactly as expected power wise with the Cobb flex fuel software. Final power on 93OCT pump gas was low 400's at about 24PSI.
Thanks,
Alex
Old 02-17-2017, 01:26 PM   #4
Concretebone
Member#: 367503
2008 WRX Sedan
what kind of fuel pump setup is this running? looking for similar numbers but not sure i can feed the beast
*EDIT* nevermind i looked right over what you had written xD
Concretebone is offline   Reply With Quote
Old 02-17-2017, 02:03 PM   #5
Motion Lab Tuning
Member#: 228856
No problem! Any of the 340LPH pumps with a hardwire kit should get you around 500WHP on a dynojet style dyno with E85 in our experience. We have been using the AEM fuel pumps with good results.
Thanks,
Alex
Old 02-17-2017, 05:15 PM   #6
subrex16
Member#: 323531
was there any specific reason the customer opted for a 3071 compared to a 76?
subrex16 is offline   Reply With Quote
Old 02-17-2017, 09:33 PM   #7
Concretebone
Member#: 367503
2008 WRX Sedan
I've got a dw300c currently, similar flow rate but time will tell. Not sure what to do for higher power lol I was thinking a surge tank and run the 300c to that and then a 044 to the injectors
Old 02-18-2017, 10:27 AM   #8
Motion Lab Tuning
Member#: 228856
Better spool and still make the target power. Honestly with the new Gen II compressors as well I feel the sweet spot is either the 3071R or 3576R for a good responsive street turbo on the 2.5L AVCS motor.
Thanks,
Alex
[email protected]
Old 02-18-2017, 11:32 AM   #9
Motion Lab Tuning
Member#: 228856
Just make sure its hardwired for now for the most flow.
You could consider a AEM 380LPH fuel pump, same size as Bosch but about 80LPH more flow. Similar flow curve as well. For customers making 650+WHP on E85 we will typically run a Fuelab 1000HP, 1300HP, or 1500HP pumps with the build in speed regulators and a 1.5L Forge motorsport surge tank.
Thanks,
Alex
[email protected]
Old 02-21-2017, 09:50 AM   #10
Concretebone
Member#: 367503
2008 WRX Sedan
Not hard wired currently, is that a necessity I'm not exactly sure how to go about that. Is it just running a solid power wire from 12v?
Old 02-21-2017, 09:54 AM   #11
Motion Lab Tuning
Member#: 228856
Yes sir, thats pretty much it. We will typically use a DW or AEM hardwire kit (DW FPHW or AEM 30-2062). This will provide constant voltage to the pump and increase flow over running off the factory fuel pump controller.
Thanks,
Alex
Old 02-21-2017, 10:07 AM   #12
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Thanks,
Alex
[email protected]
If you have the choice when it comes to the og 11 blade gtx turbos on a 2.5ltr EJ. Do you feel the gtx3076r has its place? I know it can make power. Plenty of e85 cams right around 500whp. Would you really suggest the gtx3071r or right too the gtx3576r it sounds though?
rexworx is offline   Reply With Quote
Old 02-21-2017, 10:23 AM   #13
Motion Lab Tuning
Member#: 228856
Yeah honestly I feel the GTX3076r has always led to slight disappointment in terms of power output versus spool. This turbo did exactly what we wanted it to do and did it spooling about 300-400RPM sooner than a 3076r. So especially with the new Gen II stuff I would say 3071r otherwise jump to 3576r if you want more power than the 3071 can offer.
I think the GTX3076R works great on other engines with more displacement or in a twin turbo configuration on a v6 or v8, but not a very exciting turbo on these cars in my opinion.
Thanks,
Alex
Old 02-21-2017, 02:04 PM   #14
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
Is the turbo used/shown here in this thread the gen1 or gen2? its a bit unclear. I cant tell if you're saying that this car is using gen2, or that it would be even better with gen2.
What Inj DC and fuel pressure are you running on that setup? ID2200s seems like way overkill.
gsrcrxsi is offline   Reply With Quote
Old 02-23-2017, 04:33 PM   #15
Motion Lab Tuning
Member#: 228856
Sorry, to clarify this is a Gen 1 GTX3071R turbocharger with the TiAL .82A/R v-band turbine housing. It would be even better with the Gen II as the flow would be increased another 20% over the Gen I stuff, effectively making it put out the same power as the Gen I GTX3076R.
The ID 2200cc injectors run so amazing at low pulse width it wasn't much of a concern going overkill in this instance. The car was limited by the fuel pump which was a hardwire 320LPH AEM pump. Also engine was on stock rods, only upgraded pistons and bearings, so not looking to go any further at this time.
Thanks,
Alex
Old 02-23-2017, 06:01 PM   #16
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Does the GXT3071R it currently has have anything more in it? Or is it out of steam?
Old 02-23-2017, 06:14 PM   #17
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Thanks,
Alex
Thanks for the reply! It was very helpful.
Old 02-24-2017, 08:41 AM   #18
Motion Lab Tuning
Member#: 228856
Turbo had more in it, not a whole lot more but im sure we could have gotten up to 30PSI and seen some gains. It is a 60LB/Min compressor if I remember correctly. Cams and rods would be a big benefit to push further to increase safety and efficiency over current engine.
Thanks,
Alex
[email protected]
Old 02-24-2017, 08:42 AM   #19
Motion Lab Tuning
Member#: 228856
Sure thing, never a problem to help with a few questions!
Thanks,
Alex
[email protected]
Old 03-02-2017, 11:23 PM   #20
Harey
Member#: 270569
'15 Foz XT & GT86
I like this setup, great response and mid range! Well done
Harey is offline   Reply With Quote
Old 03-04-2017, 08:14 AM   #21
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Thanks,
Alex
[email protected]
So how late are your 3076 builds making boost?
Scuby04STi is offline   Reply With Quote
Old 03-04-2017, 08:58 AM   #22
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Sounds like 300-400 rpm better spool. Better response, more trq. It sounds like the 30r turbine wheel, of the gtx3076r just cant flow enough for the 76mm compressor. The gtx3076r seems to only make about 50whp more tapped out. Going to the 35r turbine really lets the gtx76mm compressor flow to its potential.
Old 05-11-2021, 12:47 PM   #23
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
i understand i'm bumping an old thread
this has to be one of the best looking graphs ive ever seen.
motion lab, if youre still on here....do you have experience with the new g series as compared to this? ive been bouncing between the 3071 and the 3576 constantly and just cant decide what exactly i want lol
Karlot is offline   Reply With Quote
Old 05-11-2021, 01:10 PM   #24
K3rm1tth3fr0g
Member#: 508105
Link tuned 02 WRX
EJ205 20G-XTR JDM 6MT E85
Last time they were active was Jan 2018 :/
But this seems like a fairly standard 3071 dyno chart unless I'm missing something. I saw an EJ207 that spooled a 20G by 3K and made ~400WHP, now that was an insane graph.
I have a GTX3576 Gen 2 spoolinator kit set aside for my built motor, and every dyno sheet I looked at before choosing, along with every conversation I had with my tuner really pointed me to the conclusion of the 3576 being one of, if not the overall best turbo for the 2.5L engines.
If you go in the Killer B Spoolinator thread, the dyno sheet they have there shows nearly stock spool on a 3576 (note that it was a Gen 1 so your results will be better) and it made 450 WHP on a low reading dyno on an otherwise mostly stock STI.
The 3071 will of course spool a bit faster and drop off a bit sooner in the higher RPM but it also really depends what you're after.
I vote 3576 if you are running a 2.5L. The spool difference between the 3071 and 3576 isn't as big as you'd think and is more than made up for by the power you get up top.
K3rm1tth3fr0g is offline   Reply With Quote
Old 05-11-2021, 03:18 PM   #25
Karlot
Member#: 339923
grey
I have a GTX3576 Gen 2 spoolinator kit set aside for my built motor, and every dyno sheet I looked at before choosing, along with every conversation I had with my tuner really pointed me to the conclusion of the 3576 being one of if not the overall best turbo for the 2.5L engines.
dang i didnt look at when they were active lol. i just came across this and hoped. and yeah i do have a 2.5, the car is an 06 sti. i'm currently on a 20g, I would like to retain some spool characteristics but be able to make in the low to mid 500s. which i get either turbo could do. i'm also looking for real world info on the g30-770. it seems to be something that could do really well with the 2.5. i guess time will tell. mind if i pm you about y our setup
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
