Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 02-19-2017, 07:49 AM   #1
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
Default 04 WRB STI Catastrophic engine failure May 13, 2017, 3rd build Outfront V3 CD
2004 WRB STI, purchased June 2004 .
Original motor spun a rod bearing due to cracked oil pickup @ 43K
1st engine build (never trust John Edwards @ Costa Mesa R & D machine shop), motor builder was a Subaru Master technician.
2nd engine builder Prolific Autosports had my car for 2 years. Had a partner falling out so some parts where missing but got replaced by Frank. Very bad on updating the customer and I only asked monthly (acted like I was harassing him and got teste several times), till he couldn't give me an estimated time of completion (kept on taking other jobs though) I decided that was enough so I towed the car home incomplete although the motor was built and assembled. I've been wrenching on my car till October 2015 since I towed it home in June.
Over all the car has been down since 2008. 53K on odometer.
Car down again, Prolific auto motor didn't last a year and never ran right. Picked up my car in Oct 2016 from Outfront motorsports after being down since May 2016, from a seized motor, spun rod bearing after tear down.
Build #3, all work done by Outfront including R&R: V3 closed deck, 1/2" head studs, replaced 1 Manley TT rod and balanced to the remaining rods. Replaced nitrided crank with a new OEM induction hardened crankshaft 12200AA330, reused case halves as there were new from the previous build, bore to 99.75mm as required for the V3 closed deck, extra clearance Kings racing bearings, JE FSR 99.75mm pistons, replaced stock windage tray with KB tray, JE Proseal head gasket. Will be replacing the discontinued Koyo R2704 (R core 53mm) with the newer Koyo VH091672 (Hyper V core 36mm) which I purchased at from Jeremy of Outfront today. Replacing due to a leak that developed today in the Koyo R2704 which actually expanded from over pressure from the previous build. The replacement VH091672 as slimmed back down to oem thickness.
Engine:
  • Case halves from last build for Outfront V3 CD block
  • new OEM induction hardened crankshaft 12200AA330
  • Manley Turbo Tuff Rods replaced one from spun bearing damage
  • JE Billet FSR standard size pistons 8.8:1 99.75 for OFCD block with JE Pro Seal Piston Rings
  • ATI dampener
  • JE Pro Seal head gasket
  • 1/2" Outfront custom ARP head studs previously ARP 2000 head studs
  • jdm 12mm oil pump
  • Cosworth timing belt guide
  • Gates Racing timing, alternator, a/c belts
  • Canton oil sandwich adapter
  • Canton billet oil filter nixed due to unreliability of collapsing so went back to factory Subaru filters
  • -4AN steel braided turbo oil feed/avcs oil feed (forgot who makes these)
  • Covert performance -12AN fitting to block turbo oil return adapter
  • Killer B billet oil pan, KB oil pickup, KB windage tray
  • Motul beak in oil with Redline break in additive
  • previously under hood scoop mounted external 38 row TRU cool oil cooler moved to passenger side front of wheel well with dedicated oil cooler fan which turns on when rad fans kick on
  • Cusco engine / transmission mounts
  • DC Power Engineering 270 amp alternator 200amps @ idle
  • Started with AEM 3.5 bar stainless steel map sensor but just upgraded to 5 bar ss map sensor
Heads, work by Tom @ Portflow:
  • blending of bowl area
  • 5 angle valve job
  • Supertech std size inconel exhaust valves, std size black nitride intake valves to retain velocity and didn't want to move the power band too far to the right, Super tech springs
  • Brian Crower 272 avcs cams
Turbo/exhaust system:
  • Full Race twinscroll header, up pipe, down pipe, vta dump tubes
  • BW8374 twinscroll EFR ext wg
  • dual Tial MVS 38mm wg, originally ordered with 1.1 bar springs but changing to .3 bar springs
  • Mac 4 port boost solenoid
  • Turbosmart Kompact shortie plumb back bpv replaces the plastic bpv assembly
  • JIC Spartan DE type 2 ti 3" catback with revised 3" thoughout ti piping (no bottle neck at flange or no resonator), Kart Boy long exhaust hangers
Intake/Intercooler/cooling system:
  • JDM V9 Spec C long runner tgvless manifold reverse mount
  • 4" diameter 8" length K&N universal cone filter directly on turbo inlet
  • Borg Warner EFR built in FR billet cover changed to Turbo Smart plumb back BPV
  • AMR 04-07 FMIC 5" thick core 3" inlet and outlet
  • Full Race reverse mount 2.5" aluminum ic piping modified by Jason Noren Fabrications to clear stock fans, retains A/C
  • Mikalor W2 Stainless Supra heavy duty hose clamps throughout
  • KS Tech 19mm phenolic spacers
  • KS Tech custom dbw to dbc throttle body spacer
  • replaced discontinued Koyo R2704 (R core 53mm) and cheap slim fans with the newer Koyo VH091672 (Hyper V core 36mm) with oem 2 speed radiator fans, Samco radiator hoses
  • Relocated custom Covert Performance turbo reservoir
  • Mishimoto 60 deg racing thermostat, Redline water wetter, 20% coolant, Subaru coolant additive, the rest is deionized water, recently added a higher percentage of Subaru coolant due to too much water causing mix to boil and causing over pressurizing the cooling system
Fuel:
  • Full Blown billet dual pump hanger, removed bottom half to accommodate wider bases of Walbro 450lph pumps
  • Added Holly Performance Hydromat to primary in tank pump to address fuel starvation on turns and works great
  • dual Walbro 450lph in tank pumps, (one dedicated, 2nd as auxilary to be activated by AEM S2 @ 14psi of boost), 8 gauge wired to power pumps and Fuel Pro fpc
  • -8 Fragola black covered ptfe lined feed fuel line, -6 Fragola black covered ptfe lined fuel return line, Fragola/Aeromotive hose ends and fittings configured in reverse series order (4231)
  • Radium JDM long runner top feed fuel rail adapters
  • IAG top feed fuel rails/ rail mounted fuel dampeners
  • Fuel Injector Development 2000cc Bosch Ev14 based High Impedance injectors
  • Continental long pipe flow through flex fuel sensor on return line
  • AEM series 2 Engine management (supports Flex Fuel)
  • Aeromotive FPR, Aeromotive shut off valve fuel filter
  • Fuel pro fpc with computer fan mounted on circuit box turns on with ignition
  • Auminati o-ringed fuel injector seal buckets
Clutch:
ACT Xtreme clutch with high performance organic disc rated to 550 hp and still holding since I don't do launches from a dig, just rolling starts.
PVC, purge valve deleted, pvc solenoid retained dedicated crank case (3/4"hose) and (5/8" hose) T'd valve cover Radium catch cans with outlets Y'd to a hose routed near the exhaust exit vta.
methaddict is offline   Reply With Quote
Old 02-19-2017, 11:21 AM   #2
Squirtledasuby
Member#: 463182
Default Squirtledasuby
How is the car running?
Squirtledasuby is offline   Reply With Quote
Old 02-19-2017, 11:33 AM   #3
sc00ter
Member#: 117767
2014 Audi S4
DP Stage 2 (~420whp)
Wow!
sc00ter is offline   Reply With Quote
Old 02-19-2017, 09:11 PM   #4
methaddict
Member#: 159738
Drives like stock around town. Organic disc with Extreme clutch engages like stock although works out my left leg in traffic. Smooth power curve with early spool up like stock with vertually no lag, early torque on tap, accelerates very quick, no misfires, no backfiring. Boost is easy to regulate off the throttle, but when I drop the hammer things get intense but still manageable. Some wheel spin @ full boost but I installed an AEM 12 position trim pot to incrimentally set my boost which Shawn setup in the AEM S2.
Old 02-20-2017, 05:10 PM   #5
wantsti
Member#: 134764
04 sti
java black pearl
Do you have any info on your holly hydromat install?
wantsti is offline   Reply With Quote
Old 02-20-2017, 09:09 PM   #6
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
Love your build. Glad you stuck with it.
stu is offline   Reply With Quote
Old 02-20-2017, 09:31 PM   #7
methaddict
Member#: 159738
Thanks, this one better last because I don't think I have another build in me. If it does I'll be upgrading to the 9174 EFR with the lighter aluminum chra.
More info is in Fuel systems thread. Very easy to install it just slips on the inlet of the primary 450lph Walbro and can be orientated in several incremental positions 360 degrees . I sits on top of the slosh tray longer side hanging over the tray on the left side under the filler neck. The second 450lph Walbro has the original sock filter but sits on top of the Hydromat siphoning off of it. The pumps are diagonally staggered on the hanger legs to accommodate the wide bottoms of these pumps and held on by stainless worm gear clamps. I had to remove the Fullblown hanger fuel pump clamps to fit the wide bottom 450s. The 1st pump is controlled by a relay with 8 gauge power and ground to the Fuelpro fuel pump controller, second pump is hard wired with 8 gauge power and ground. AEM S2 sends a ground signal to a relay to turn on @ 14psi. The Full blow hanger has two barb fittings under the base and internally Ys the fuel output to one -8AN male fitting.
Old 02-20-2017, 10:52 PM   #8
wantsti
Member#: 134764
04 sti
java black pearl
Thanks did you attach the mat using magnates in the tank or is it just sit in there connected to the pump?
What size is the mat?
Old 02-20-2017, 10:59 PM   #9
methaddict
Member#: 159738
For now there is only one Hydromat 11mm outlet with 6 lock pin position that connects directly to The TI 450 LPH (F90000267), 400 LPH (F90000262) & GSS342. It's literally sandwiched between the slosh tray and the fuel pump so it's not going to move. 3" X 15" off set.
Old 05-04-2017, 12:08 AM   #10
methaddict
Member#: 159738
Fuelpro fuel controller was removed due to a circuit board failure so I just hardwired the primary Walbro 450lph pump. Change all rubber hoses, which will eventually expand and crack, to Flex tech reinforced heater hoses. I had a small leak with the turbo return line that I used 90 degree -10 an fittings, steel braided hose, and the Tigwerks -10AN male to o-ringed fitting into the block so I bought a 45 degree -10AN to barb for the return from a flange fitting with a gasket to the chra and a 90 degree -10AN to barb to the Tigwerks fitting and Flex tech silicone hose with some ss worm gear clamps.
To move the K&N filter away from direct heat soak from the turbo I added a 45 degree elbow and I cut up the stock air intake duct to get air to the filter. Also covered the ic piping with some aluminum 2.5" sleeves. I also had to get a new 4 port boost solenoid due to the original one failing.
I also extended the fuel pressure sensor to keep it away from heat soak and engine vibration.
Still using the Radium catch cans which I have to empty after doing any wot pulls on the freeway onramps. I still don't trust air oil separators. This also keeps my regiment of checking the oil levels frequently.
Old 05-04-2017, 08:59 AM   #11
STiSomeday
Member#: 265430
2005 OBP WRX STi
IG/FB - seriousblacksti
Glad you've stuck with it, love the build man. Sucks that you've had so many bad experiences but the current setup should treat you well. My 05 was down for about 3 years due to issues with a shop similar to the second one you worked with.
I'm going to regret asking for this but, do you have any sound clips (especially under load) of the Spartan? I sold the one I snagged without ever running it and will always regret it.
STiSomeday is offline   Reply With Quote
Old 05-11-2017, 02:40 AM   #12
methaddict
Member#: 159738
Thanks, when I get a chance I'll record a sound clip. I can do it from my iphone 6 from inside the cabin with the windows down. Something like a wot on the fwy onramp?
Old 05-11-2017, 10:23 AM   #13
STiSomeday
Member#: 265430
2005 OBP WRX STi
Whatever you can come up with, no biggie. Just want to hear what I could have had haha.
Old 05-11-2017, 10:40 PM   #14
oh.pig
Member#: 467517
Very nice, can't wait to get myself an STI
oh.pig is offline   Reply With Quote
Old 05-15-2017, 01:35 AM   #15
methaddict
Member#: 159738
deleted
Old 05-15-2017, 06:19 AM   #16
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Sorry to hear about your continued troubles mate. That wild fuel set up looks complicated enough to give you troubles maybe? Also you'll need to go back and change the header on your thread.
A-man07 is offline   Reply With Quote
Old 05-15-2017, 07:48 PM   #17
methaddict
Member#: 159738
Fuel setup has worked great. It's now @ Outfront and tear down will determine the failure and hopefully under warranty. It's only been a little over six months. Tune from Shawn Church has been solid, last time he checked the tune I went to adjust the idle he said it was on the rich safer side throughout the boost rpm range. I had to agree to $1500 for tear down.
Old 05-18-2017, 11:38 PM   #18
methaddict
Member#: 159738
I gave them a call yesterday and Ozzy told me a valve broke off into one of the combustion chambers possibly taking out the block and one of the heads. That's all the info they gave me. Other than that I'm waiting for a more detailed report. They still need to tear the short block down. OF sent the heads out for an inspection and came back as good to go, obviously they were not. If they recommended new valves I would have purchased them. Supertech inconel exhaust valves and black nitride intake valves are what were in the heads.
Old 05-20-2017, 12:09 PM   #19
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
I have seen quite a few threads on here regarding the heads snapping off super tech valves in EJ applications.
181stLeader is offline   Reply With Quote
Old 06-04-2017, 04:53 PM   #20
methaddict
Member#: 159738
As of now the owner John has not contacted me which I did request to have him contact me on the last phone conversation, but did get another estimate via email for approx. $8500. The original engine build they performed cost me $7500 in Sept of 2016. It hasn't even been a year. In the new estimate has the Supertech valve train. Why would I use the same brand valve train that failed? How often is it that a valve train fails? It's a daily driver. I don't road race or drag race on the track or street. From the time I picked the car up last year till now I still haven't gone over 10k miles, in fact my odometer hasn't gone past 70k. I did take a pic of of the odo when I picked it up.
Old 06-05-2017, 03:40 PM   #21
STiSomeday
Member#: 265430
2005 OBP WRX STi
Sorry to see this man. If you opt to rebuild it, demand Manley valvetrain all the way.
Old 06-14-2017, 08:43 PM   #22
Squirtledasuby
Member#: 463182
Any updates on your car?
Hope it's running soon
Old 07-01-2017, 07:10 PM   #23
methaddict
Member#: 159738
Still no contact from the owner. I filed a complaint with BAR and already spoke with BAR agent regarding this. Car is still at the shop with no communication other than an emailed estimate for $8500.
Old 07-05-2017, 02:07 PM   #24
methaddict
Member#: 159738
OF sent me an email stating they are going to start charging storage fees of $20 per day starting July 1, 2017 even before I received this email. That is in addition to charging me $1500 for the engine tear down for the engine failure result after all work had been done by them. Looks like they're going to fee me to death till they can put a lien on my car and end up owning it. Still no call from the owner. BAR rep may have visited them already.
Old 07-07-2017, 11:21 PM   #25
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Lawyer up
user1029 is offline   Reply With Quote
