03-15-2017, 05:59 PM | #1 |
Member#: 419075
TXIC
Vehicle:2006 Wrx Sti Matte white |
TX: 2006 Subaru WRX STI 135k 14.5k
2006 Subaru Wrx Sti
Garland, Tx 14.5k 135k miles chassis 6spd transmission loosing motivation on it as more and more **** comes up. Here's what it's got. "I WILL NOT BE RESPONSIBLE TRANSPORTING YOU THE CAR, YOU COME PICK IT UP" **all you literally need is an act monolock collar and that's it** Mods: 04 sti longblock 160k miles (cold compression 130-135)(yes proof) New shaeffers 5-40 oil New andrewtech 6sp cocktail(had not be put in yet, still in bottles) 2 redline shockproof 2 motul 300 New iag black tgvs New iag fuel lines New cosworth fuel rails New fic 1100cc injectors New battery New axle shaft inner boot -not installed-axle is off New starter New cc stage 4 clutch and flywheel New tigwerks oil pick up New ap-002 w/ Dotson tuning 93 base map Agency uel headers Grimmspeed up pipe Ks tech 73mm intake Avo big red inlet Stock fpr 13' Vf48 32k miles no wastegate crack 13' oem big sti Intercooler New Cobb bpv New Cobb ebcs Straight 3" Midpipe/catback careless 3" catted downpipe that was going to be cut from the cat and replaced with 3"catless cutout Could use a paint job if your picky about it hood needs to be finished sanded 09 sti wheels 18x8.5 Slotted/drilled rotors/pads-2500 miles Defi boost gauge-red Aem lambda ratio 3 gauge 52mm cluster Possibly forgetting more atm Cons: Motor will need to be pulled out again and have the collar throwout bearing clip re aligned. It somehow came off during instillation hence why the clutch pedal won't adjust because it won't grab at the fork Does not inlcude front bumper,and fmic Clean title second owner I do still owe. Pm for more details. Serious inquiry's only please. Pm offers
04-10-2017, 12:53 AM | #2 |
Member#: 419075
TXIC
Bump - Fixed monoloc drives and everything installed new cv boot needs replacing now lol, slipped off clamp and I'm sure it was the wrong size in the first place. Trans axle seal leaking slighty
