#1 |
Member#: 454359
NESIC
Vehicle:2013 wrx hatchback ISM |
![]() Hi guys, I am a new subaru owner and have heard many horrific stories about the "Knocking" on the EJ motors. I have a 2012 WRX with Cobb stage 1 + sf with stage 1 map for a while, car was running fine no problem. FBKC and FKL values were always 0.0 according to Cobb AP. Just recently, I've noticed that the FBKC changed everytime i drove the car (it hit 8.6 or 6.5), and went back down to 0. even FKL also changed sometimes as well. I did a lot of research and watched/listened to all the videos i could find regarding rod knock issues, and my car does not sound as severe compared to those videos. have not been driving the car much or hard since i want to avoid the potential damage to the engine. car is over 60k miles, so no more warranty. i took the sound clip of my car. can someone with experience check it out and see if the car sound normal? or am i just scaring myself over nothing? in the video, i revved the engine up between 2500 to 3000.
thanks.
#2 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 Stage 2 (418whp/398ft-lb) |
![]() Sounds completely normal to me.
Trust me, if it was truly rod knock, you'd know. Last edited by sc00ter; 03-20-2017 at 07:27 PM. |
#3 |
Member#: 454359
NESIC
![]() what worries me is that, FBKC and FKL never changed before, and there was few times that FKL stayed on constant at -1.4 for the whole drive. planning to have the tuner look at my car soon, but before that, i just want to figure out whether there is any mechanical issue with the car going on, or i just simply need a custom tune.
#4 |
Member#: 427632
![]() Sounds normal. Sounded like a high idle at first. Check your oil level by the way. Also don't base your numbers when you're parked and idling. You have to be driving. Datalog a 3rd gear pull at full throttle from like 3 -3500 rpm till redline and post it here.
#5 | |
Member#: 135150
South East
Vehicle:2006 WRX Sedan Blue |
![]() Quote:
#6 | |
Member#: 454359
NESIC
![]() Quote:
#7 | |
Member#: 427632
![]() Quote:
This is rod knock: |
#8 |
Member#: 454359
NESIC
![]() past couple days i've been watching every vids i could find regarding the noises coming from the engine from rod knock, spun bearing, timing belt tensioner, ect. will try to take a look at the timing belt tensioner this weekend, and check to see the condition of the oil. and will try to data log and report back.
#9 |
Member#: 454359
NESIC
![]() update, i tried to do some data logging this Saturday. didn't want to get ticket so this is all i got.
this is WOT in 3rd gear. https://docs.google.com/spreadsheets...61&single=true right after the WOT pull, at crusing speed, then this happened. https://docs.google.com/spreadsheets...jhgVoQ/pubhtml https://docs.google.com/spreadsheets...PX6jRk/pubhtml |
#10 | |
Member#: 465158
Vehicle:2016 Subaru WRX STi Pure Red |
![]() Quote:
#11 |
Member#: 268310
SCIC
Vehicle:2011 SSM STI saloon Church! |
![]() All I hear is typical EJ injector tick and accessory noises. Nothing resembling rod knock or anything else abnormal.
Enjoy your car. |
#12 |
Member#: 454359
NESIC
![]() Yea the noise from the engine does not concerned me too much, since EJ engines are typically noisy. Just that the FBKC and FKL on cobb ap values are not stable after i got the cobb dp installed. Changed back to stock dp with stage 1 map and the issue didn't go away completely.
#13 |
Member#: 412207
SCIC
Vehicle:2014 WRX Ice Silver Metallic |
![]() Motor sounds fine in the video. Check around your engine bay for anything loose that could be rattling around. Specifically the heat shields around the turbo/up pipe, they tend to come loose and rattle around causing false knock. From your logs I'd guess that is the problem
#14 |
Member#: 454359
NESIC
![]() for the first time today when the car was idling, i heard a noise from under the engine sounded like a loose heatshield that was never there before. hopefully that was the culprit for the crazy FBKC values.
#15 |
Member#: 454359
NESIC
![]() an update for anyone interested: cleaned my MAF sensor and cleaned + re-oiled my air filter, and the condition improved alot. didn't see any high fbkc values above -1.4. made an appt with tuner to get the car tuned next week, hope that will eliminate the issue.
