Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 03-29-2017, 08:22 AM   #1
AVANTI R5
Member#: 73805
Arrow 2018 Volkswagen Golf R
2018 Volkswagen Golf R first drive review: no juvenile delinquent
Apr 23, 2018
Automaker family portraits are like most of ours. See that mohawk in the back? That’s the Honda Civic Type R. The blue-face scoundrel flipping the bird? Hello, Ford Focus RS.
Every family has someone bound for the pokey—even short stretches, but the 2018 Volkswagen Golf R skips hard time because it’s effectively the VW GTI’s twin. Sure, the Golf R hits the gym—not the yard—compared to the GTI, and it could be more fun.
But in a world of wild wings and drift modes, the Golf R stands out because it doesn't go too far. It’s familiar and familial, so does it matter that it’s not VW’s wild child?
Twinsies
We're not kidding around about that twins business.
The Golf R's only visual differences are its 19-inch wheels, slightly lower ride height, an exhaust outlet for each cylinder, and silver accents in place of the GTI's red. It all feels underwhelming––Volkswagen doesn't need to go crazy with how its hottest hatchback looks. Still, we'd like the visual gulf between Golfs to be a little wider.
Changes to the cabin are similarly restrained, aside from one important detail: the Golf R is the first member of the family to adopt Volkswagen Digital Cockpit as standard. The all-digital display spans 12.3 inches and while it's not as reconfigurable as Audi's system, Digital Cockpit is a beautiful and comprehensive way to view driving, multimedia, communications, and navigation data.
Digital Cockpit's interface is more intuitive than Virtual Cockpit, and its controls––limited to just one side of the steering wheel––are simple to operate. While it retains the same page format that Audi's system uses, the reconfigurable options in the VW get their own page, while the side tabs from Virtual Cockpit are missing all together. There's still a learning curve, but the centralized and clearly marked customization options make VW’s the better of the two systems.
Digital Cockpit aside, the Golf R's cabin is virtually identical to the GTI’s. This is good for the business of driving––the leather seats are as snug as a good pair of lederhosen, with huge side bolsters that bearhug the driver and front passenger. The black cow hides are standard and that's a mark against the Golf R––the GTI's standard tartan cloth is far cooler.
Page 2 of 3
Like the GTI, there's a flat-bottomed steering wheel with soft leather and ample padding and a manual shift lever that feels like an extension of the driver's right arm. Sightlines are excellent in every direction, even with the sport seat in its lowest position (where your 6-foot-1 author likes it). It’s an improvement from past Golfs, which occasionally suffered with the seat set too low.
One Heart
The similarities between the Golf R and the GTI are evident under the hood, where a 2.0-liter, turbo-4 sits in both cars. The R's engine is much more powerful, though (although its not as stout as its newly enhanced European cousin). With 292 horsepower and 280 pound-feet of torque crammed into a space the size of a New York City microstudio, acceleration is relentless from a standstill and nearly as impressive at speed.
But the performance is approachable, just like in the GTI. The Golf R doesn't feel frantic like the more powerful Focus RS, and with its standard all-wheel-drive system, acceleration requires much less thought than the front-wheel-drive Civic Type R––just grab the appropriate gear and mash the gas pedal.
But do so, and our biggest complaint about the Golf R's powertrain rears its head: it sounds remarkably artificial.
Like a lot of vehicles, the Golf R features a sound actuator, or as the VW enthusiast community calls it, the soundaktor (German for, you guessed it, “sound actuator”).
Search “Golf R soundaktor” and there are a number of threads on VW enthusiast forums, posts on Reddit, and videos on YouTube detailing the general dislike for the system. There are nearly as many explaining how to disable it. You should.
Volkswagen sells the Golf R with a standard 6-speed manual or a 7-speed dual-clutch automatic, an $1,100 option that's up a gear from last year's model. While we'd like to try the new 7-speed, our tester had the standard option and it's excellent.
The clutch has a wide and predictable catchpoint, and we'd be happy with the pedal in heavy traffic—rev-matched downshifts are easy thanks to the predictable clutch and attentive throttle. The shift lever has short throws and welcomes changes to any of its forward gears.
The Golf R distances itself from the GTI with a standard all-wheel drive system. Along with no-slip acceleration, the Golf R's 4Motion system can send up to 50 percent of the engine's torque to the rear axle via a multi-plate clutch. An electronic differential manages lateral power transfer and brakes a slipping wheel to send power to the opposite side.
Page 3 of 3
Family Traits
The Golf R's tossability is only partially down to the 4Motion all-wheel-drive system. Like the GTI, there's a multi-link suspension in back and a pair of struts with coil springs in front––adaptive dampers sit at all four corners. The ride is 0.2 inches lower than the GTI, although any difference from that is hard to spot. The Golf R's stance is certainly better, though.
But ride height changes (and all-wheel drive) aside, this is mostly the same suspension found in the GTI. That means handling is sharp and predictable, with very little body roll. The GTI feels confident, but the all-wheel-drive Golf R has bedrock-like stability and poise through the corners, which is a particular pleasure compared to the understeer-prone Civic Type R and the Wheeeeee-I-have-Drift-Mode antics of the Focus RS.
DON'T MISS: Next-gen Volkswagen Golf GTI and R to be more powerful, lighter
But it's the way the Golf R manages everyday conditions, coping with bad roads without brutalizing the driver. Detroit's roads (where we tested the Golf R) are notoriously rough, but the ride is far from spine-crushing, even with the standard 19-inch wheels. The suspension is soft enough that it soaks up the pockmarked surface without transmitting too much to the driver's seat, but firm enough that the car rarely feels disconnected. This is a refreshingly balanced performance car from a ride/handling perspective.
And it's that balance that permeates every facet of the Golf R. This is a high-performance hot hatch that doesn't bludgeon its driver every time they get behind the wheel.
While we'd appreciate some of the histrionics that help the Focus RS and Civic Type R stand out in our memories, it's easy to forget that those character-building imperfections get worse the farther you drive from a track.
The Golf R is as exciting as it needs to be and never at the expense of its everyday usability. It's not the most dynamic hot hatchback on the market, but just like its baby brother, it's almost certainly the best.
https://www.motorauthority.com/news/...ile-delinquent
Old 03-29-2017, 11:51 AM   #2
dwf137
Member#: 161333
'18 Golf R
'14 Outback
Is this coming to the US for 2018? I thought VW models were typically one year behind in the US.
Since I'm currently eyeing one of these as my wrx replacement in a few years, I am glad the manual remains, and hoping that the manual keeps those "electric driver aids" at bay.
Old 03-29-2017, 12:03 PM   #3
Xandernfs
Member#: 275795
In a way, I'm surprised that the R isn't taking sales away from the GTI. But then again, the R is more of a niche car.
Xandernfs is offline   Reply With Quote
Old 03-29-2017, 12:08 PM   #4
4S-TURBO
Member#: 67807
1980 Ferrari Turbo
Pando Periwinkle Pearl
Old 03-29-2017, 12:52 PM   #5
gandapanda
Member#: 51476
2005 Forester XT
2018 BMW M2
In Canada, it probably does. The R is priced very competitively up here.
S
gandapanda is offline   Reply With Quote
Old 03-29-2017, 12:54 PM   #6
Sid03SVT
Member#: 183032
OLD Family Wagon
There is a significant price gap between the GTI & the R, and most people aren't hung up on AWD; I think it comes down to different strokes for different folks - Personally I have no interest in an FF car, so the GTI is just automotive background noise, hanging out with (in my mind) the focus ST, MS3 (rip) and believe it or not, corolla, civic and everyotherffeconoboxoutthere, because I have no interest in them. I know some of these FF cars can be/are quick around a track, I just have no interest in FF.
Sid03SVT is offline   Reply With Quote
Old 03-29-2017, 01:58 PM   #7
industrial
Member#: 7250
2018 Honda Accord
Completely different price points in the US. The GTI you can get for thousands off MRSP and have your pick of many sitting on the lot. I could've gotten a nicely equipped GTI with the old PP for $24k. They were asking 42k for a loaded R or I could special order one. VW dealers treat the R like their own GT350 and play up how rare and special it is while charging you MSRP to order one from Germany. If the R was as easy to get as the GTI, it would be a completely different story. I'd definitely be driving one today.
industrial is offline   Reply With Quote
Old 03-29-2017, 02:05 PM   #8
Skylab
n00b Moderator
Member#: 4263
Question
You can order one from the factory now?
For 2016, the dealers had no idea when they'd get an allocation.
So if you put a deposit down, you'd get notified when an R was inbound, but it was totally random what the trim level and color would be.
If this has changed for 2017, that's a good thing. Is there still no base model?
They're all coming in with 19" Pretorias w/DCC, etc?
Skylab is offline   Reply With Quote
Old 03-29-2017, 04:38 PM   #9
Xandernfs
Member#: 275795
I get what you're saying. I didn't know there were that many incentives for the GTI. I got my R AT MSRP. Some claim to get it below on the interwebs, but Most got theirs a MSRP or higher (which I wouldn't pay for).
Old 03-29-2017, 05:07 PM   #10
industrial
Member#: 7250
2018 Honda Accord
Well, if you call signing a contract and putting down a deposit for the car at MSRP and waiting 3-5 months "ordering" then yes, you could special order the 2017 R. Or you could get the ridiculously loaded car on the lot.
Paying MSRP on a VW product vs. buying a Subaru well below invoice is such a no-brainer fiscally that it becomes really difficult to rationalize the R. Then you have these dealership games on top of that. The R is a really nice car but, it ain't that nice in my eyes. Nothing turns me off faster than dealing with douchey dealerships telling me how the car I'm looking at is some kind of snowflake. These aren't freaking Ferraris.
Old 03-29-2017, 05:16 PM   #11
Pre
Member#: 139693
Then why are you in a Golf R thread? it's not nice in your eyes, but you'll take the time to read a thread about something that isn't nice in your eyes, and waste your time?
I know why, because it competes with booby's STI.
Old 03-29-2017, 05:19 PM   #12
industrial
Member#: 7250
2018 Honda Accord
I don't know. It's like a girl you dated and considered marrying but there was some serious dealbreaker. Every once and a while you creep a little and check in.
Competes with the STI? No, the STI is dead to me. Was never in the running.
Old 03-29-2017, 06:50 PM   #13
Pre
Member#: 139693
Go drive the R man. It's nice.
Old 03-29-2017, 08:06 PM   #14
john_knoxville
Member#: 109568
Rumored speculation in car mag articles last summer re 305hp / 295 lb ft plus new 7A dct transmission for US 2017 S3 = 292hp / 280 lb ft 6A 2017 S3 sitting on US dealer lots
Rumored speculation in car mag articles this spring re 305hp / 295 lb ft plus new 7A dct transmission for US 2017 golf r = ???? it is a mystery
john_knoxville is offline   Reply With Quote
Old 03-29-2017, 08:41 PM   #15
industrial
Member#: 7250
2018 Honda Accord
I've driven them, they are nice. Not $21,000 (12k price difference + 9k depreciation difference) nicer than a WRX limited. Even at that, if it wasn't for the dealer circle jerk with these cars... this really would've been the perfect car for me at this point in my life.
Old 03-29-2017, 10:04 PM   #16
Bluestreak2006
Member#: 140536
93 MR2 Turbo
Turq Pearl
If for some reason VW really wants to do me a solid, they would sell me an R wagon right meow.
Bluestreak2006 is offline   Reply With Quote
Old 03-29-2017, 11:12 PM   #17
heavyD
Member#: 194216
2018 M2 LCI
It's a great car. I really like mine a lot more than I thought I would as I typically burn through cars but I'm very satisfied with this car. It ticks more boxes than most cars I've owned and does almost everything very well.
heavyD is offline   Reply With Quote
Old 03-29-2017, 11:24 PM   #18
Skylab
n00b Moderator
Member#: 4263
Default 2018 Volkswagen Golf R to get 305 horsepower?
If the STi hatchback was still produced, that's the only car I would have considered. I didn't cross shop anything, not even a GTI. I wanted a Golf R.
I take the cynical approach to possessions. It's a car. Don't like it? Time to sell.
Old 03-30-2017, 05:27 AM   #19
JRodrigues
Member#: 149337
It's a Golf. That's what they do
JRodrigues is offline   Reply With Quote
Old 03-30-2017, 05:54 AM   #20
bunda4th
Member#: 314503
2012 WRX Sedan
I am currently waiting for more info on the 2018 model. I do hope we get most of the stuff that was revealed at Geneva. Also curious what type of Performance Package the US will get.
Will be buying a car this year, the Golf R and Civic Type R are the two cars I am waiting for and hoping to test drive.
bunda4th is offline   Reply With Quote
Old 03-30-2017, 08:27 AM   #21
cannedtuna
Member#: 286661
2016 GTI & CRV
The circle jerk has happened to me on the R and STI for me....while for the GTI and WRX they behaved alright. I eventually settled on the GTI because of the incentives and out the door price. Depreciation will come back to bite me I know but for now I'm enjoying the car.
cannedtuna is offline   Reply With Quote
Old 03-30-2017, 11:53 AM   #22
Pre
Member#: 139693
You bought with incentives. You should be fine on resale. No incentives you be getting f'd.
Old 03-30-2017, 02:09 PM   #23
woody06967
Member#: 110330
2004 996TT
2015 Q5 TDI
Don't blame the R specifically for your dealership experience, buying mine was not a problem and it was a first allotment 2016 (it's gotten easier and more flexible since.) The only thing I'm bitter about was selling my 2012 Golf TDI to a friend of mine one day before the settlement cutoff date.
I won't argue on absolute value but it's a significantly more refined vehicle and better driver experience than any of the current Impreza variants.
If it weren't for production volume of GTI vs R the Golf pricing would be in line all the way through. The MSRP on a loaded up GTI is not far off from a base R. Honestly these days the STI's premium over the WRX is harder to justify than the R's premium over the GTI.
woody06967 is offline   Reply With Quote
Old 03-30-2017, 03:04 PM   #24
SoapBox
Member#: 204578
My wife said she'd
buy me a Lotus, AKA REX8
+1
SoapBox is offline   Reply With Quote
Old 03-30-2017, 05:06 PM   #25
dsn112
Member#: 332561
2015 GTI Autobahn
That would be accurate if the base R existed anymore. They force everything down your throat now and put the starting price at like $39,500. Loaded Autobahn GTI with discounts can be had just under 30k in most markets. Still talking about a 10k difference for AWD, and a tad more power. Interiors are virtually identical on the autobahn and R.
dsn112 is offline   Reply With Quote
