Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 04-05-2017, 10:37 AM   #1
ATMINSIDE
Member#: 455092
2015 WRX Limited 6MT
ISM
Default 2015 WRX - Swapping Dual Climate Control
Hey All,
I'm researching how to install a dual zone climate control system into the 2015 WRX. There isn't much info I could find on NASIOC, except in this thread.
https://forums.nasioc.com/forums/sho....php?t=2811383
The good: the MFD detects it as dual zone once you swap the control.
The bad: you need parts besides just the control.
The unconfirmed: exactly what parts you need besides the control.
Here's all the parts I've found that differ from single climate to dual climate thus far:
  • Dual Zone Climate Control Unit - 72311VA020
  • Second Door Actuator Motor - 72131YC021
  • Door Actuator Motor Spring - 72121YC010
  • Door Actuator Lever - 72122YC070
  • Door Actuator Rod - 72125YC040
  • Door Actuator Clip - 72666FA030
  • (2) M4 Tap Screws - 904500026
After putting together this list I still cannot determine one thing; the air mix shutter inside the heater system. On the single climate system is this one door or two?
On this page there are three parts listed for the air mix shutter: http://parts.subaru.com/a/Subaru_201...10-720-04.html
Has anyone taken the heater system apart on these forums?
Does anyone know if the wiring for the second door actuator is already in the cars with single climate control?
ATMINSIDE is offline   Reply With Quote
Old 04-08-2017, 01:54 AM   #2
emu1342
Member#: 419426
2015 WRX
Would like to know if this is possible too! Bump
emu1342 is offline   Reply With Quote
Old 04-10-2017, 10:06 AM   #3
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
Good luck. I stopped at the dual climate control unit. At least that works. You will most likely have to take the dash apart to get to the internals of the hvac. I thought it was just the motors. Ill have to take a look at my cousin's sti when I get the chance to see what moves.
amiexploited is offline   Reply With Quote
Old 04-10-2017, 11:07 AM   #4
ATMINSIDE
Member#: 455092
ISM
I need to look under my dash and see if the wiring for the additional actuator exists.
If that is there, and the actuator mounts to the outside of the HVAC unit, I really think this could be doable with minimal work.
Old 07-04-2017, 08:37 AM   #5
15SubieSC
Member#: 440587
Anyone done this? I don't have a problem ordering all the parts, just need to know if the list above is everything. Should I get all three shutter doors?
15SubieSC is offline   Reply With Quote
Old 07-04-2017, 09:31 AM   #6
15SubieSC
Member#: 440587
Looking through the parts diagrams, it seems the 2016 wrx has all three shutter doors that the sti has. Is it just a matter of controlling these doors?
Old 07-08-2017, 11:46 AM   #7
15SubieSC
Member#: 440587
Well everything is on order, I have the wiring diagram, install location. I even have a set of '17 vents to update my '15 so we will see if it works. I will update when everything is in. From my own research, the parts that I ordered match those above btw.
Old 07-08-2017, 11:49 AM   #8
emu1342
Member#: 419426
2015 WRX
Can't wait. Keep us in the loop!
Old 07-08-2017, 12:12 PM   #9
Infinite0180
Member#: 410716
2016 WRX
CBS
I too am curious.. i dont really need this but i always wondered how hard it would be to add the feature! Take pictures for us!
Infinite0180 is offline   Reply With Quote
Old 07-08-2017, 03:42 PM   #10
notorious9i6
Member#: 433974
yeah i did this awhile back.
Some people on facebook said it depends on what model/trim you got. The guy on facebook was pretty much full of **** and said it worked with his 2015 premium model.
notorious9i6 is offline   Reply With Quote
Old 07-08-2017, 08:27 PM   #11
15SubieSC
Member#: 440587
Yes, thank you for posting that... You do realize I have the wiring diagrams with pin-outs to the motor which I will be adding to the car. I understand this is not a plug and play and I will be doing some tweaking. If all you have to say is that it won't work, keep that to yourself and let those who want to help, help.
Old 07-10-2017, 08:03 AM   #12
ATMINSIDE
Member#: 455092
ISM
If you get it figured out, do you mind posting a step-by-step with all the parts you needed?
Still interested in doing it, but haven't had time to devote to this.
Old 07-13-2017, 06:41 PM   #13
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
I am in the process of doing this swap myself. I got a set of STI controls on eBay, as well as a 72131YC001 motor. Looking at the parts diagram, I now think that this is the wrong motor. Looks like it's the motor for the WRX. Also, do you not think we need the STI motor on the RH side? Part number 72131YC011. Not sure what the difference is between the C001 and C011?
Lastly, I have a '17 Limited. You said you have a '15. Is the wiring for the second motor not present on your car? Are you adding wiring into your harness? I think I need to return my motor and get the correct LH dual motor, the 72131YC021. This looks like a bit more of a headache than was explained to me, but it will be worth it. The GF is always cold.... when I'm sweating. Haha.
ilarson007 is offline   Reply With Quote
Old 07-13-2017, 06:45 PM   #14
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
Also, for reference, parts.subaru.com shows the exact same parts diagram and list for '17 Base STI and '17 Limited WRX. So I am not sure whether or not the 72131YC011 and 72131YC001 interchange, as I mentioned in my previous post.
Old 07-13-2017, 07:43 PM   #15
15SubieSC
Member#: 440587
I found in the shop manual where the wiring diagram does not specify separate diagrams for single vs dual for the RH (*1 indicates single).
http://imgur.com/uqxTxJE
This leads me to believe that the motors should interchange for the right hand side. I have not verified this, but I do not think LH/RH would swap as the mounting should be different, but I also found installation/checking procedures for the motors and from those, they do look identical...
LH:
http://imgur.com/FUpVHBY
RH:
http://imgur.com/dAHZuRu
I am waiting on the motor and a few more parts to come in before I take apart my dash. I'm also going to install a head unit too so I wanted to knock all that out at the same time.
Old 07-13-2017, 07:48 PM   #16
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
LH:
RH:
Okay keep me posted! I have the motor I indicated, but I don't want to open it if I need to return or exchange it.
Old 07-13-2017, 08:23 PM   #17
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
72131YC001: Motor - Actuator Mode
Fits:
Subaru Crosstrek 2.0L 5MT Limited 2017
Subaru Crosstrek 2.0L 5MT Premium 2013, 2014, 2015, 2016, 2017
Subaru Crosstrek 2.0L CVT Limited 2013, 2014, 2015, 2016, 2017
Subaru Crosstrek 2.0L CVT Limited w/EyeSight 2015, 2016, 2017
Subaru Crosstrek 2.0L CVT Premium 2013, 2014, 2015, 2016, 2017
Subaru Crosstrek 2.0L CVT Premium w/Eyesight 2015, 2016, 2017
Subaru Crosstrek 2.0L HYBRID CVT Limited 2014, 2015, 2016, 2017
Subaru Crosstrek 2.0L HYBRID CVT Premium 2014, 2015, 2016, 2017
Subaru Forester 2.0L CVT XT Premium 2015, 2016, 2017, 2018
Subaru Forester 2.0L CVT XT Premium w/EyeSight 2018
Subaru Forester 2.0L CVT XT Touring 2014, 2015, 2016, 2017, 2018
Subaru Forester 2.0L CVT XT Touring w/EyeSight 2014, 2015, 2016, 2017, 2018
Subaru Forester 2.5L 6MT Base Premium 2017, 2018
Subaru Forester 2.5L 6MT Limited 2017, 2018
Subaru Forester 2.5L CVT Base Premium 2017, 2018
Subaru Forester 2.5L CVT Limited 2014, 2015, 2016, 2017, 2018
Subaru Forester 2.5L CVT Limited w/EyeSight 2015, 2016, 2017, 2018
Subaru Forester 2.5L CVT Premium w/EyeSight 2017, 2018
Subaru Forester 2.5L CVT Touring 2014, 2015, 2016, 2017, 2018
Subaru Forester 2.5L CVT Touring w/EyeSight 2014, 2015, 2016, 2017, 2018
Subaru Impreza 2.0L 5MT 4WD Premium Plus 2012, 2013
Subaru Impreza 2.0L CVT 4WD Limited 2012, 2013, 2014, 2015, 2016
Subaru Impreza 2.0L CVT 4WD Limited w/EyeSight 2015, 2016
Subaru Impreza 2.0L CVT 4WD Premium Plus 2012, 2013, 2014
Subaru Impreza 2.0L CVT 4WD Sport Limited 2012, 2013, 2014, 2015, 2016
Subaru Impreza 2.0L CVT 4WD Sport Limited w/EyeSight 2015, 2016
Subaru STI 2015
Subaru STI 2.5L TURBO 6MT Premium 2017, 2018
Subaru STI 2.5L TURBO 6MT STI 2015, 2016, 2017, 2018
Subaru STI 2.5L TURBO 6MT STI Limited 2015, 2016, 2017, 2018
Subaru WRX 2015
Subaru WRX 2.0L 6MT Base 2016, 2017, 2018
Subaru WRX 2.0L 6MT Limited 2015, 2016, 2017, 2018
Subaru WRX 2.0L 6MT Premium 2015, 2016, 2017, 2018
Subaru WRX 2.0L CVT Base 2016, 2017, 2018
Subaru WRX 2.0L CVT Limited 2015, 2016, 2017, 2018
Subaru WRX 2.0L CVT Limited w/EyeSight 2017, 2018
Subaru WRX 2.0L CVT Premium 2015, 2016, 2017, 2018
Subaru WRX 2.5L TURBO 6MT STI w/Spoiler 2017, 2018
Subaru WRX 2.5L TURBO 6MT WRX STI 2017, 2018
Subaru WRX 2.5L TURBO 6MT WRX STI Limited w/Spoiler 2017, 2018
Subaru WRX 2.5L TURBO 6MT WRX STI Premium w/Spoiler 2018
72131YC011: Motor - Actuator Mix
Fits:
Subaru STI 2015
Subaru WRX 2015
Old 07-13-2017, 08:35 PM   #18
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
Yes, I saw that, but it doesn't say what the difference is and they are listed for the same spot in the diagram.
Old 07-14-2017, 11:37 AM   #19
Big-E
Member#: 123843
2016 STI LTD CWP
Depending on the model (options), there is a difference:
[72143] 72131YC001: Motor - Actuator Mode [attaches to the left-side]
[72143B*A] 72131YC011: Motor - Actuator Mix [attaches to the right-side]
Old 07-14-2017, 03:12 PM   #20
15SubieSC
Member#: 440587
From what I found 72131YC011 is the right side and 72131YC021 is the left side (I have 72131YC021 planned to install).
Old 07-14-2017, 04:21 PM   #21
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
Okay, but "do WRX's come equipped with 72131YC0011 or 72131YC0001?" is what I'm getting at. Both of these part numbers are shown in the RH position.
Old 07-14-2017, 05:46 PM   #22
Big-E
Member#: 123843
2016 STI LTD CWP
From my follow-up post above:
They are different parts with different functions and do not occupy the same position.
Old 07-14-2017, 05:50 PM   #23
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
So again. What part was installed on what model? You just posted exactly what you already did. This doesn't tell me what's in my car or if the parts interchange.
Old 07-14-2017, 05:59 PM   #24
Big-E
Member#: 123843
2016 STI LTD CWP
My intent is not to get into an argument. My intent was to clarify that these two items do not occupy the same position on the heater/air-conditioning case when you state that they do occupy the same position.
None-the-less, my suggestion is to download the factory service manual and go through it to understand the differences between the models.
Old 07-14-2017, 06:22 PM   #25
ilarson007
Member#: 340470
2017 WRX Limited
Crystal White Pearl
They are both 72143...
http://parts.subaru.com/a/Subaru_201...10-720-03.html
