Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Normally Aspirated Powertrain
Old 04-13-2017, 08:08 PM   #1
d0rkiishchris
Member#: 463740
Default NA 2017 Impreza clutch pedal vibration
So I found another forum discussing slight vibration upshifting in the clutch pedal. It seems to have started now on mine. I noticed it about 200 miles ago. Basically as you push the clutch pedal it slightly vibrates while upshifting 2nd to 3rd or most noticeably 3rd to forth. Again it happens only under load. It's a very very minor vibration and it does not do it at idle or with the engine off. But 40% power acceleration and you can feel it in the clutch pedal itself. Only barely though. I found a lot of posts about this with the WRX guys and their push style clutch, which is what I believe mine is like.
Again it's a 2017 Impreza manual with less than 3000 miles.
d0rkiishchris is offline   Reply With Quote
