Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
Old 05-20-2017, 04:19 PM   #1
rictd
Member#: 338626
2011 WRX
Default 2013 Forester Post-Swap Help
I recently swapped/installed a used FB25 long block in a 2013 Forester 2.5 Forester X M/T. It starts and idles reliably, but seems to idle a little low. On throttle it just bogs down, and eventually stall. It does not seem to want to rev at all yet does not throw any codes. I have verified visually that the throttle body is opening and closing.
The used long block that I found had 45000KM and came from 2012 Forester with an A/T and came complete with plugs, injectors, rails, intake manifold, throttle body, map sensor. I did change the flywheel
It is the first time that I swap a motor, but I am confident about having restored all vacuum/fuel/electrical connections. Oil changed and subaru super coolant replaced too.
If I pull the MAF sensor the car stalls and throws a code
Not sure what to check next guys, please give me some advice
PS - my original motor spun a rod bearing at 190000KM
rictd is offline   Reply With Quote
Old 05-24-2017, 04:33 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
When you swapped the flex plate over to the flywheel did you get the crankshaft position plate (tone wheel) indexed properly on the crankshaft? It has a small pin to align it and is real easy to assemble it incorrectly.
Elbert Bass is offline   Reply With Quote
Old 06-04-2017, 09:57 AM   #3
rictd
Member#: 338626
2011 WRX
This.
This is exactly what the problem was
It is possible for the toning wheel/pin to become unaligned when placing and aligning the flywheel bolt holes
Do not rush this step - it cost me dearly
