Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 07-15-2017, 02:27 PM   #1
Donfather
Member#: 355814
2002 Impreza WRX
Question 2002 OEM Key Fob destroyed, security system not allowing engine start, aftermarket k.
My 2002 OEM Key fob for my WRX has been destroyed and my security system isn't allowing me to start my car. On top of this I do have a after market key fob but it hasn't been programmed yet can someone help me get back to Baltimore from North Carolina?
Donfather is offline   Reply With Quote
Old 07-15-2017, 05:19 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I believe programming a new fob requires your key and instructions in the owners manual, may also be a supplement with the manual.
I'm pretty sure it s posted on here as well.
Old 07-15-2017, 07:18 PM   #3
Donfather
Member#: 355814
2002 Impreza WRX
Unless I can deactivate the security system I can't program the after market key fob. All threads I've seen on here have not worked for canceling out the code that is preventing me from programming my aftermarket fob so far. Thanks though still looking for help
Old 07-16-2017, 12:59 AM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
The 2002 WRX does not have a chipped key - only the key fob.
If you don't have a keyfob, disarming the alarm is described in the owners manual
Emergency disarming
If you cannot disarm the system using the transmitter (i.e. the transmitter is lost, broken or the transmitter battery is too weak), you can disarm the system without using the transmitter.
To disarm the system:
1. Unlock the door with the key and then open the door.
2. The alarm will sound.
3. Insert the key into the ignition switch and cycle itfrom the “LOCK” to the “ON” position three (3) times within 5 seconds.
then you can program your new transmitter
Old 07-16-2017, 10:51 PM   #5
Donfather
Member#: 355814
2002 Impreza WRX
Thank you for the info really appreciate it now getting it to actually work is my issue I have had no luck with that procedure thus far.
Old 07-17-2017, 08:44 AM   #6
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Unfortunately, whatever is in the manual should be correct and is the best info we can offer.
Loyale93 is offline   Reply With Quote
Old 08-18-2017, 10:10 AM   #7
Blightarrow
Member#: 472866
Default I had the same issue
Ok so all the posts on here are not helpful. I have a 2003 wrx that I bought without the key fob and everything worked for about two months. Then all of a sudden the alarm went off, for three days I could figure out how to reset the system or disable it. No YouTube video helped and no forum did. So after a few hours of tinkering with electronics, I found that the ticking was coming from three places, the engine fuse box, the cab fuse box and by the e-brake. Well the first two were useless to me, I tried taking out the hazard horn fuses and the door lock fuses and it didn't work. But when I opened the middle compartment I found the security box, the little devil that made all my problems, all I did was unhook it and blam all fixed
Blightarrow is offline   Reply With Quote
