Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 11-14-2017, 03:30 AM   #1
revlimit408
Member#: 407008
02 jdm ej205 9.0:1
16gxt e85 v9 sti 6speed
Default manley h-tuff rods on a 2.1 stroker question
Anyone running manley h-tuff with a 2.1 stroker? I am not sure how much grinding I need to do on the block . I was using sti rods on my last build so no clearance issue . Let me know please . thanks
revlimit408 is offline   Reply With Quote
Old 11-14-2017, 02:46 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
what grinding are you talking about?
subaru_gc8 is offline   Reply With Quote
Old 11-14-2017, 05:59 PM   #3
revlimit408
Member#: 407008
02 jdm ej205 9.0:1
the rod cap when is on compression the clearance on the other side of the case , and from my previous stroker build the sti crank was hitting the case , i might need to upload some picture , its hard to explain. I did some research and i cant find anyone running with the h-tuff with 2.1 stroker ,ive seen only the regular h/beam , the h tuff is wider than the h beam.
Old 11-14-2017, 09:30 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
that sounds like it would be a question for the manufacturer. as it is a wierd thing to deal with. I have a 2.1 stroker but I used Tomei rods and had no problems like that at all. Im running about 400 on 91 and 450 on E with a gtx 3067
Old 11-14-2017, 11:10 PM   #5
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
I never had an issue with rods in a 2.1 stroker. Do you already have the Manley rods?
Old 11-15-2017, 01:35 AM   #6
stu
Member#: 25768
2003 GEN 2 GTX35R
OFCD Bugeye Slowbaru
Yah that seem weird. Pics would help for sure...
stu is online now   Reply With Quote
Old 11-15-2017, 01:44 AM   #7
revlimit408
Member#: 407008
02 jdm ej205 9.0:1
not yet still debating what to get, the h tuff is my first choice , but I haven't seen anyone using it on a 2.0 liter with 79 crank . Talked to Manley and told me I need to do some block clearance work with stroker set up.
Old 11-15-2017, 02:21 AM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
can I ask what your HP goals are?
Old 11-15-2017, 02:37 AM   #9
revlimit408
Member#: 407008
02 jdm ej205 9.0:1
400-500 whp . I have a fully build head supertech valves , manley spings with retainers ,sti cams and shimeless buckets . For fuel dw300 hardwire , id1300 and e85 fuel. for turbo Fp green htz and supporting mods. speed density tune.
Old 11-15-2017, 11:41 AM   #10
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Did you ask them specifically what needs to be clearanced and by how much?
That would have been my 2nd question to Manley
Samurai Jack is online now   Reply With Quote
