Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 04-25-2018, 10:55 PM   #1
etsola
Member#: 484839
Default Cosworth rods same as Carrillo !?
Hi there, I came accross a fact where it seems that Cosworth rods would be the same as Carrillo ?
They do look quite the same... Even the laser imprint is very similar.
Cosworth Part#: 20002587 :
Carrillo Pro-H SB-2LTR>-65137S:
Anyone has info on that ?
I've seen in another post where the compare rod specs that they had the same weight ... so might there be something there ?
If they are the same. anyone advises against using a Carillo to complete a set since 1 Cosworth burned ?
etsola is offline   Reply With Quote
Old 04-25-2018, 11:10 PM   #2
jamal
Member#: 71875
I'm not going to say completely identical, but yes cosworth does outsource some of their manufacturing and it is my impression that cp/carillo makes their rods, and that arrow does the cranks.
jamal is offline   Reply With Quote
Old 04-26-2018, 12:33 AM   #3
Bram
Member#: 292653
And ACL do thier bearings.
And if you look at thier online website description for the head gaskets, it is word for word identicle to that of RCM description. But RCM gaskets look different. Perhaps both made on order by the same manufacturer.
Bram is offline   Reply With Quote
Old 04-26-2018, 11:03 AM   #4
anjuna
Member#: 401977
IDFK Wat
bish whet
sometimes things in this world are all manufactured to one drawing/specification.
More expensive companies tend to accept and sell things based on higher quality requirements and/or additional testing
Less expensive companies have lesser acceptance criteria.
So, you could be getting the same "thing" but more acceptable/consistent/conforming to quality standards.
anjuna is offline   Reply With Quote
Old 04-26-2018, 11:04 PM   #5
wantsti
Member#: 134764
04 sti
java black pearl
I talked to the guys at cp Carrillo at sema about this and they said that they are made by them. Cosworth sets the specs and Carrillo makes them. He said the cosworth ones are better.
I’m in the same boat and need 1 cosworth rod too.
wantsti is offline   Reply With Quote
Old 04-27-2018, 01:51 PM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
I don't know how cosworth is better than Carrillo, but I won't be using cosworth rods again, they bend too easy
if you need a single rod, call Rallispec, Dave helped me out when I bent a rod
Hyper is offline   Reply With Quote
Old 04-27-2018, 02:16 PM   #7
anjuna
Member#: 401977
IDFK Wat
bish whet
Iím in the same boat and need 1 cosworth rod too.
More than likely, cosworth has an agreement that they want the conrods in a certain spec, balanced, matched, etc... Then, Carrillo can sell the "out of spec" parts (which are probably just fine, they just don't meet cosworth spec) and sell them in their name.
This is fairly common in manufacturing.
Old 04-27-2018, 02:52 PM   #8
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
what I meant, is that I have seen less failures with Carrillo rods than with Cosworth
make me wonder, who do they outsource cam manufacturing to...
Old 05-10-2018, 11:13 AM   #9
etsola
Member#: 484839
Default Interesting
Thanks for the replies guys... Sorry I hadn't set the automatic subscription for thread I create... :/
I'll try rallispec.
Cheers
Old 05-15-2018, 03:42 PM   #10
etsola
Member#: 484839
Default Quick question
Hey guys any counter indications on using a single new Cosworth rod to complete my used set?
Thanks
Old 05-15-2018, 05:08 PM   #11
Bram
Member#: 292653
If you can get a single cosworth rod, that should be fine. Although from what i hear, its pretty hard to buy a single rod from cosworth. I know a guy thqt did it with an engine over here. Cant remember where he got the rod from in the end though.
Old 05-15-2018, 06:12 PM   #12
stevieturbo
Member#: 20366
Looking at them even from photos, they are clearly different all over.
And I'd sooner be buying Carrillo than Cosworth, no matter what claims Cosworth are making.
I'd be sceptical that those Cosworth rods are made by Carrillo.
Interestingly I see Callies are now starting to offer Subaru stuff for those who like US made parts.
stevieturbo is offline   Reply With Quote
Old 05-16-2018, 01:30 PM   #13
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Carrillo did make the Cosworth rods. I'd spoken directly with them about several years back.
As for Callies coming in, yeah, seen that too. Turn In Concepts got them to come on board and then ****...also their H-beam +2 rods crash on some forgings crown.
Old 05-18-2018, 01:10 AM   #14
ItalianGuy
Member#: 60685
2005 STi
Just to play devil's advocate, how many more people buy Cosworth rods than Carrillo? From a percentage standpoint what's the number of failures to purchases for each company? Clearly we don't know, but also take into account Cosworth is a big-name company, so if a Cosy rod fails the buyer is more likely to complain about it than with a Carrillo rod.
That being said I went with Cosworth pistons but Manley turbo-tuff I beam rods. They might be a bit heavier but they're definitely not going to bend.
ItalianGuy is offline   Reply With Quote
Old 05-18-2018, 01:37 AM   #15
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I'm more curious to what will fail first? The rods or the open desk? If closed desk what's the next failure point?
Fierysun is offline   Reply With Quote
Old 05-18-2018, 09:18 AM   #16
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Carrillo was widely used in UK, so I am getting my data from there
Cosworth sold more stuff in the States (which is clearly a bigger market, I have to agree with you here) however I have personally bent a cosworth rod, so did my friend, I've seen other issues with them too.... their pistons are overpriced junk that take much less timing in an identical build (swapped from Diamonds to Cosworth with everything else left the same)
The only Cosworth part I owned that I love is the billet crank... but then again, its not made by them
don't get my wrong - I have much respect for cosworth engineering, they have done outstanding things, just no in the mass market field
