05-15-2018, 07:16 AM | #1 |
Member Sales Rating: (1)
Member#: 259778
BAIC
Vehicle:2002 WRX MBP |
NY: 2002 WRX w 6 speed swap and ton of extras
2004 sti trans, diff, brembos
DW 1000cc injectors with rail 340LPH e85 Fuel pump PTFE braded fuel lines Perrin FMIC with blow through MAF Perrin catless divorced wastegate dp Fujitsubo rm01a exhaust Perrin equal length headers Perrin catless up pipe VF30 turbo Enkei RPF1 17x8 Black rims (some rash) Spare set of sparco rims with almost new Blizzaks TGV deletes DCCDPro Perrin engine mounts Perrin transmission mount Perrin coolant overflow tank Perrin pitch stop mount Yellow top battery White line sway bar mounts Perrin adjustable short shifter Perrin shift bushings Stoptech stainless brake lines Perrin master cylinder brace Yakima roof rack Flatout 3-way adjustable coilover suspension Runs on e85, can switch back to gas by flashing ecu If you want, I also have bunch of other stuff I amassed in preparing to build a 2.5L engine to swap. If you buy this car you can have all this stuff: EJ257 long block (fully dismantled, but complete) All the used accessories from the long block (alternator, AC, oil pump, power steering, water pump) Brand new in box oem oil pump Brand new in box oem water pump New gates timing belt New oem idler pulley ARP head studs td04 turbo Gt35 turbo (stock location, forgot the brand, no markings) 2005 STI Ecu 2005 STI Wiring harness Perrin regular inter cooler pipe (if you want to switch back from blow through) STI top mount inter cooler The spare STI engine worked when it was pulled, but I was planning to put the gt35 on there and wanted to build it first. You could just put it back together and swap it in with all the new accessories and call it a day if you wanted. Body of the car is in ok shape but there are some surface rust bubbles over the left wheel well. There's a dent in the front of the hood from someone backing into it parallel parking. Another dent over the rear corner of the back seat passenger door. It's definitely not a show car. It's got almost 200,000 miles on the body but everything else has pretty much been replaced. I'm leaving to be a pilot in the Air Force very soon and don't have room for all this. I could obviously do much better with a part out but no time. Car is in NYC, rest of the spare stuff is in Ithaca, NY. $8000 for everything Photos: https://photos.app.goo.gl/Ef4kjybTBnMrCpPp1
