Welcome to the North American Subaru Impreza Owners Club Sunday September 20, 2020
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 05-22-2018, 06:51 PM   #1
zagwyn
Member Sales Rating: (6)
Member#: 199850
2005 STI
Default MA: 2005 Subaru STI Refreshed Motor ETC
I have recently purchased a 2005 Subaru STI from another NASIOC member, I purchased the vehicle in February and have daily driven the vehicle since. My intentions for this vehicle were to slowly bring it back to life and eventually weekend/track it. Circumstances have came up and therefore, if the right buyer comes around, I am open to selling this vehicle. As of right now there are zero issues and it is a fun, reliable, daily driver. Within the last few months this vehicle has had quite a bit of work for which i will explain in full detail below. The vehicle was at Rallispec in New Jersey for an extended period of time and received an engine rebuild along with several maintenance and wear and tear items. Rallispec work completed at 136,000 miles, 141,700 on the vehicle today. Motor was run on break-in oil until 1,000 miles and was then changed with Motul 8100 5W-40, oil recently changed again yesterday. This vehicle does shows signs of it's age with numerous scratches, dings, dents around the body, interior is also aged with the usual stains ETC, no tears in any cloth.
EJ25 Engine Disassembled and Rebuilt
o EJ25 Head Rebuild
♣ Supertech Valve Set (NEW)
♣ GSC Valve Guides (NEW)
♣ Valve Seals (NEW)
o Cylinder Heads Decked
o Cylinder Block Honed/Deglazed
o Engine Gasket Kit EJ257 MY04-06 (NEW)
o King XPG Rod Bearing Set 4cyl EJ Series 52mm Journal (STD) (NEW)
o King Subaru STi EJ25 Flange #3 Position (STD) Performance Main Bearing Set (NEW)
o OEM Pistons (NEW)
o ARP Head Stud Kit (NEW)
o Checked OEM Subaru Turbo (No Shaft Play as per RalliSpec)
- Replaced K&N Air Filter
- Replaced Motul 8100 5w40 Oil
- Replaced OEM Subaru Oil Filter (NEW)
- Replaced NGK Spark Plugs (NEW)
- Replaced OEM Fuel Sending Unit (NEW)
- Replaced OEM In-tank Fuel Filter (NEW)
- Replaced OEM Timing Belt (NEW)
- Replaced OEM Water Pump (NEW)
- Replaced OEM Subaru Coolant Flush
- Mishimoto Radiator (< 5,000 Miles)
- Replaced Miscellaneous Engine/Vacuum hoses (NEW)
o H & RH Vacuum Hose - Cylinder Head Pressure Equalization Hose
o LH & RH PCV Hose (RH Hose used)
o PCV Fresh Air Hose
o PCV Hose Assembly
o Cannister Purge Hose Assembly
o Oil Cooler Water Hose
o Cannister Purge One-Way Valve (used)
o Cannister Purge Solenoid
o 3" Exhaust Gasket
o Downpipe Hardware
- Replaced OEM Turbo Side Oil Feed Pipe (NEW)
- Replaced OEM Power Steering Hose Suction(NEW)
- Replaced OEM Power Steering Hose Return (NEW)
- Replaced OEM Power Steering Hose Suction O-Ring (NEW)
- SPT Battery Holder
- SPT Oil Cap
- K&N Typhoon Intake
Engine Management
- COBB Access Port V3 (Street Tuned By Rallispec) (NEW)
Drivetrain
- OEM Exedy Clutch Kit (NEW)
- OEM Flywheel (Resurfaced)
- Motul Multi-ATF 1L bottle w/ Transmission Flush (NEW)
- Motul Differential Gear Fluid w/ Flush (NEW)
Suspension
- SPT Front Strut Bar
- OEM front and rear struts all rebuild with grease fittings installed- <50 miles
- RCE Yellow springs < 50 miles
- 4 New Continental tires with 3,000 miles on them currently
Exterior
-Wingless trunk
-WRX side skirts-
-Rear window spoiler
-APR rear diffuser
-Headlights completely disassembled and restored, amber taken out, all H.I.D components replaced Ballasts, bulbs wiring ETC
$12,500
BUMP for: New alternator
New battery
Perrin rear end links
Kartboy front end links
Oem inner and outer tie rods
Driveshaft shop level 5 750 HP front axles
Someone is getting a reliable daily driver that needs nothing.
https://i.imgur.com/LPadC3I.jpg
https://i.imgur.com/VZQBldx.jpg
zagwyn is offline   Reply With Quote
Old 05-23-2018, 07:05 PM   #2
zagwyn
Member#: 199850
2005 STI
the GD market seems to have withered away
Old 05-31-2018, 05:55 PM   #3
zagwyn
Member#: 199850
2005 STI
To the top
Old 07-01-2018, 12:01 PM   #4
zagwyn
Member#: 199850
2005 STI
bump...
Old 07-03-2018, 05:14 PM   #5
dzywrx
Member Sales Rating: (4)
Member#: 77610
2015 WRX-byebye 04
Sexy
so far away!
dzywrx is offline   Reply With Quote
Old 07-04-2018, 12:59 PM   #6
Heatstreak96
Member#: 307690
2012 WRX Hatch
Dark Gray
Bump for a sweet GD :3
GLWS
Heatstreak96 is offline   Reply With Quote
Old 08-04-2018, 04:00 PM   #7
zagwyn
Member#: 199850
2005 STI
price drop
Old 08-09-2018, 10:19 PM   #8
Evo-killr
Member Sales Rating: (49)
Member#: 252905
2002 WRX STI swapped
Series Gray
What’s the price drop?
Evo-killr is offline   Reply With Quote
Old 01-10-2019, 10:34 PM   #9
WRX-06CB
Member#: 496132
2006 Impreza wrx
$10,000
WRX-06CB is offline   Reply With Quote
