Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 06-13-2018, 11:45 AM   #1
wangmauler
Member#: 454822
2013 WRX Hatch
Default 2013 wrx clutch pedal squeak
Hey all, this sound started happening randomly a few weeks ago or so, mainly after it had just rained. Now it's happening more and more often, took a vid. Seems to be just when I press down the clutch. I should add that the I can feel the squeaking in my foot as I press down too. Feels like whatever grease was there has been washed away basically. I checked the spot welds, which look to be fine, and the break pedal does not move at all when I press down the clutch too. Suggestions? Thanks all.
PS
In case you were wondering, size 14 wide feet, and yes I wear old man sandals. Comfy AF!
wangmauler is offline   Reply With Quote
Old 07-03-2018, 02:32 PM   #2
kingsalami
Member#: 206257
2009 WRX 5-door
Try spraying white lithium grease on the pivots & return spring.
kingsalami is offline   Reply With Quote
Old 07-03-2018, 02:34 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
That does not tend to migrate into the bad spot, it's more of a surface lube.
Silicone or 3in1 is better.
Old 10-02-2018, 09:58 PM   #4
Gunner2118
Member#: 492232
2009 WRX Hatch
Obsidian
Default Clutch squeak
Just bought this 09 WRX and its always had a squeaky clutch. First started with white lithium grease but didnt work. Then put a couple machine bolts through firewall spot welds and that worked for about an hour. Next decided to take out pedal assembly (quite difficult) and on inspection noticed a crack in the tube. Welded the crack and sprayed tube with penetrating oil in case there was anything inside causing squeak. Inspected clutch master cylinder and bled any air in hydraulic lines. Reinstalled everything and it seems to have solved the squeak. Hopefully wont have to deal with it again. Didnt take any progress pics other than of pedal assembly i was spending to much time cursing the process.
https://pix.sfly.com/MmUYuM
https://pix.sfly.com/RXknQH
Link to crack in tube
*Subaru dealer was useless, they had nothing for a fix or even speculation on what it could be.*
Gunner2118 is offline   Reply With Quote
