Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 07-01-2018, 09:03 PM   #1
DetailersDomain
Member#: 165558
Default Introducing an exciting super easy way to seal your car - Sonax Spray and Seal
We are excited to tell you that we have tested out Sonax Spray and Seal and we are loving it. We have found Spray and Seal to be a great product to add to your routine maintenance. We have used gallons of the product in our rigorous testing and this has proven to be an easy to use product with great gloss and durability of up to 3 months. The water beading behavior is much like Sonax Polymer Net Shield, which we believe to be one of the best beading products in the industry. Spray and Seal has a a great just waxed feel to it, missing in the Polymer Net Shield and Brilliant Shine Detailer. Spray and Seal can be used to boost your coated, sealed, or waxed vehicles. This can also be used as a stand alone product as well. We recommend everyone to give this one a go.
What Sonax says:
SONAX Spray and Seal - Instant Shine Coating is a great compliment to any car enthusiasts' product arsenal. The easy-to-use formulation incorporates a unique Hybrid Polymer Technology that provides up to 3 months protection and generates excellent hydrophobic properties. After the car is washed and while it is still wet, simply spray entire car with the product and rinse. Completely dry all areas affected with a clean microfiber towel.
Direction for use:
- Wash vehicle and rinse thoroughly
- Shake bottle before use and turn the nozzle to open.
- Evenly spray the sealant on the wet vehicle (approx 4-6 sprays per 4 ft section).
- Rinse immediately with plenty of clean water and dry the vehicle.
- Dry the vehicle - Remove any leftover remnants with a microfiber towel.
Product Attributes:
- Spray on, rinse off - and it's sealed!
- Quick and easy during the car wash
- Enhances the color depth and provides a mirror like shine
- Impressive water and dirt repellent effect in no time at all
- works on cars with out any protection
- works on cars with sealant and waxes
- works on cars with ceramic coating
- works on cars with paint protection film
Please Note:
Do not use on hot surfaces. Do not apply in direct sunlight. Do not allow to dry. Always give special attention to the seams of the vehicle while rinsing product thoroughly.
Order some up - Sonax Spray and Seal
DetailersDomain is offline   Reply With Quote
Old 07-03-2018, 09:21 AM   #2
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
safe on glass, plastics, chrome? ... unable to watch video at work.. that info is probably in there
MtnXfreeride is offline   Reply With Quote
Old 07-03-2018, 09:31 AM   #3
DetailersDomain
Member#: 165558
yes.
the key again is to make sure everything is dried well.
Old 07-03-2018, 09:57 AM   #4
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
dried well, as in after applying and after rinsing it off? It looks like it beads enough to leaf blow the car dry.
Just want to make sure this isnt MORE work than a spray wax-as-u-dry.
Old 07-09-2018, 06:41 AM   #5
F3NTANYL
Member#: 424121
2007 Sti
Obsidian Black Pearl
How does this product hold up to brake dust, if it has been tested? Can it be used on wheels?
Looking for a new product to hopefully keep the wheels on my new car clean since I can't use wheel cleaners while the wheels are on the car (carbon ceramic brakes)
F3NTANYL is offline   Reply With Quote
Old 07-10-2018, 06:54 AM   #6
DetailersDomain
Member#: 165558
you can blow dry it but any left over drips should be wipe off.
no sir you need to rinse it off, but it does seem to easy the drying process.
Old 07-10-2018, 06:55 AM   #7
DetailersDomain
Member#: 165558
it works well it seems to make it very easy to clean up the wheels.
it won't prevent brake dust but will make it easier to clean
Old 07-12-2018, 03:42 AM   #8
brylemr
Member#: 414507
Looks like a good product. I might try it.
brylemr is offline   Reply With Quote
Old 07-17-2018, 11:49 PM   #9
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
How does this compare to HydrO2 or similar SiO2 applications?
cyralax is offline   Reply With Quote
Old 07-19-2018, 01:38 AM   #10
Zizzle
Member#: 488512
Will it fill any small scratches?
Zizzle is offline   Reply With Quote
Old 07-19-2018, 07:23 AM   #11
DetailersDomain
Member#: 165558
no it will not fix scratches
Old 07-19-2018, 07:24 AM   #12
DetailersDomain
Member#: 165558
give it a try it's a great product.
Old 07-19-2018, 07:24 AM   #13
DetailersDomain
Member#: 165558
this has it's benefits over the others and the others will have pros to them as well.
I believe this one is going to be one of the easiest wet applications.
Old 07-19-2018, 11:32 PM   #14
n2oiroc
Member#: 141952
18 golf arrrr!
looks like a more effective version of autoglym autogloss rinse. does it really need to be sprayed on as heavy in the vid? autogloss is just lightly misted on (2 pumps on a hood with a high volume sprayer) and still works quite well.
n2oiroc is offline   Reply With Quote
Old 07-19-2018, 11:34 PM   #15
DetailersDomain
Member#: 165558
we can get 4 BMW M2's with one bottle hope that helps.
Old 07-19-2018, 11:44 PM   #16
n2oiroc
Member#: 141952
18 golf arrrr!
ok, thanks! thats reasonable coverage. ill try some out the next time i order.
Old 07-19-2018, 11:46 PM   #17
DetailersDomain
Member#: 165558
no problem we are running a 15% off special till end of day tomorrow.
Promo Code SONAX.
7/20/18 Midnight
