Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 09-04-2018, 10:14 AM   #1
08OBS
Member#: 274397
2005 WRX V9 207
2018 Colorado Duramax
Default 2005 Subaru WRX Pedal Assembly Broken
Recently on my 05 WRX the clutch pedal was not fully returning after being depressed. I changed the clutch master cylinder, slave cylinder, and hydraulic line. I bled everything properly and I was still having the issue.
I then decided to record the movement of the slave to make sure it was working and I found my firewall to be moving. Below are two videos I took of the movement. Has anyone ever seen this on a GD chassis before? I know 08 to 14 GR's had this issue. The pedal assembly broke causing the movement of the firewall.
08OBS is offline   Reply With Quote
Old 09-09-2018, 07:32 PM   #2
08OBS
Member#: 274397
2005 WRX V9 207
Update:
The pedal assembly broke. The two tabs with the studs for the cutch master cylinder cracked off. One cracked off and the other one was just about there. The firewall was pushed forward a little but I should be able to bend it back into the original position.
Old 09-14-2018, 09:50 AM   #3
08OBS
Member#: 274397
2005 WRX V9 207
I replaced the pedal assembly yesterday and the car drives great. For anyone who feels a sudden change in their clutch pedal I suggest going under the steering wheel and looking at these studs. It's such a weird thing to break it took me a few days to find it.
Old 09-14-2018, 02:00 PM   #4
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Wow, that seems way out of the norm. Are you the original owner? I wonder what in the car's past may have caused that?
car_freak85 is offline   Reply With Quote
Old 09-14-2018, 04:27 PM   #5
08OBS
Member#: 274397
2005 WRX V9 207
I've owned the car for the past 7 years. I think the heavier pressure plate in the car had something to do with it. This is still a very strange thing to break.
Old 09-23-2018, 09:28 PM   #6
chilakas
Member#: 210354
2003 Wrx
Im on my 3rd pedal assembly, for some reason i keep cracking these things, i fabricated a bracket but to support the assembly but now it's really stiff. I hope you dont have the same issue but you should keep an eye on that thing. If the original broke it might be for a reason and the new one might break as well. I will be replacing my clutch master cylinder to see if is the issue as everything else has already been replaced.
chilakas is offline   Reply With Quote
Old 09-23-2018, 09:32 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I have read, and replied, to your thread. My question, the loads from the pedal should be pressing the bottom brackets into the firewall, thus my comment of flexing firewall. Since the broken mount is in compression, I just don't see how it's breaking IF the firewall is solid.
If the top mounts were breaking, yes, too much load could exceed what the bracket tab was designed for.
Old 12-03-2018, 11:26 AM   #8
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
I just had this happen to me (06 STi) Did you have to remove the steering column in order to get the brake/clutch pedal assembly out? I am trying to avoid having to remove that if possible.
pearson222 is offline   Reply With Quote
Old 12-03-2018, 04:36 PM   #9
car_freak85
Member#: 13530
EJ205
You can disconnect the steering column from the dash bar and drop it down a few inches to clearance.
