Welcome to the North American Subaru Impreza Owners Club Friday September 18, 2020
Old 10-30-2018, 04:09 PM   #1
CursezZz
Member#: 414974
2006 Subaru WRX STi
Obsidian Black Pearl
Default CursezZz 2006 STi 'Mr. Dancefloor'
I suppose i should make a build thread for my current vehicle, a MY06 STi. After selling my WRX in August of 2017 (HUGE MISTAKE), i bought quite a few vehicles before landing myself where i belong (and never should have left), in a turbo Subaru! I bought a S550 Mustang GT, sold that after about a month and a half, great car just terribly boring to drive and much slower than my previous car . Then i moved on to a 1988 RX-7 Turbo ii, that car was awesome except for the rotary, it kept flooding (due to a possibly failing ecu) After about a month of owning the Dorito, i traded to a friend for a 1990 Subaru Sambar and some cash. Driving the Sambar was the best 48hrs of my life. Sold it almost immediately and ended up in a 2008 Base C6 Corvette. LS3 and TR6060 was an amazing time! But it just didnt make me tingle in my downstairs like my old WRX did soooooooo after 2 months, you guessed it! I SOLD IT Then the search was on for a STi! After looking at a ton of over priced, modified, hacked up pieces of junk i decided the smartest thing to do was buy a close friends car that was for sale. (Don't worry he regrets his decision almost daily) I figured i knew the car was dealer maintained by the previous owner with a long 150k mile service history, some of it even done by a friend who is a senior master tech. Most mods were on the car when i purchased it from my friend and the best part was.... I knew it was all done right....because i assisted in installing every mod on the thing. and i didnt mind the mileage at all, the car was very clean and i planned on being an idiot and doing a full big turbo go fast build.
Engine Assembled and installed by Subaru genius and my soulmate. User carnz-pj-410 check out his build (one of many) carnz Impreza LSTi thread
The car is tuned by and will always be tuned by...... John Kerr at Innovative Motorworks.
Current Power level is: 513WHP&446ft/lbs on E60 on the IMW Mustang Dyno
As it sits now
CursezZz is offline   Reply With Quote
Old 10-30-2018, 04:11 PM   #2
CursezZz
Member#: 414974
2006 Subaru WRX STi
Mods are:
Exterior:
Bayson R eBay front lip
Stock BBS powdercoated Prismatic Gold by RC Hotcoats
04/05 tail lights
Interior:
Custom spec titanium shifter bling crafted by WC Lathewerks
JDM V7 STi seats with rails swapped for height
ATI Clock pod gauge cluster with:
AEM Xline WBo2
AP guys defrost vent mount
Engine:
IAG Performance Stage 2.5 Closed Deck block
Brand new OEM heads (new valve covers, AVCS lines/solenoids etc.)
GSC OEM sized valves
GSC Valve Springs/Retainers
Kelford R199-B Cams 264/260
Borg-Warner S362SX-E w/ .82 A/R
HKS Equal Length Headers
Rocksteady Tuning Rotated up and downpipe
Rocksteady Tuning Flex Fuel Sensor
Invidia Q300 catback
XSPower FMIC
Reversed intake manifold
Killer B oil pickup & baffle
Grimmspeed EBCS
IAG side to top feed conversion rails (Gold)
Injector Dynamics 1700X injectors
Walbro 450lph pump w/ DW hardwire kit
Grimmspeed sidefeed TGV deletes
MSI Solid engine mounts
Perrin/Omni 4 Bar Map sensor
Tomei Type-S Adjustable Fuel Pressure Regulator
IAG Competition Series AOS w/Pitch stop mount
Tial Q 50mm BOV
Tial MVR 44mm Wastegate
AEM IAT Sensor
Driveline:
ACT Sprung 6 puck clutch
07+STi 3/4 gear swap Legacy GT Spec B 5/6 gears
Turn in Concepts/Kartboy Tallboy short shifter
TigWerks semi solid transmission mount
Kartboy front and rear shifter bushings
TIC Unabomber's Super Sexy rear end kit
TIC Cherry Blossom Red crossmember bushings
Driveshaft shop Carbon fiber drive shaft
Suspension/Chassis:
Feal Adjustable Fixed Perch Struts
RCE Yellow Springs
KYB Tophats
TIC Fender Cowl braces
Oswald Rear Triangle brace
So here's some photos in no real chronological order:
The day i brought it home looking tall on those RCE Black springs 'Welcome to the Ghetto Baby'
Pretty quickly swapped the tails out to some 04/05 ones
I rocked the Rotas until i got these OEM beauties back from powdercoating
and all waxed up for her protection
Here with the fresh golds and RCE yellow springs on
I then took my first trip to the drag strip!
the best run i could muster that day (me on the right)
So now heres some random photos and items purchased!
My IAG Performance Stage 2.5 Closed Deck block...box
One of my brand new OEM B25 heads
the DSS Carbon Fiber Driveshaft!
Old 10-30-2018, 06:46 PM   #3
CursezZz
Member#: 414974
2006 Subaru WRX STi
My Kelfords
JDM Titanium goodness
My IAG fuel rails
Who doesn't love an HKS shot?
My Dialed Accessport mount from the AP Guys i love this thing!
second time at the strip this time at Cecil County Dragway, i had way too much air in the tire and it was cold, so i didn't do great
another trip to the strip, they kept staging me out of the groove and i would spin all of first gear BOOOOOOO Capitol Raceway
As you can see by the HORRENDOUS 60' times
Old 10-30-2018, 06:47 PM   #4
CursezZz
Member#: 414974
2006 Subaru WRX STi
The KSTech manifold and throttle body spacers i used to reverse the manifold!
Here are some shots from the biggest PITA install ive done to date on any car. the Reverse manifold of DOOM
finally reversed after 2 days and tons of work
and how it currently looks until the built setup goes in and i go rotated and such! it is not pretty but it works!
About time for longblock assembly!
A wild (mostly) assembled long block appears!!
Kelford are a bunch of liars! they state that the R199-B cams do not require clearancing, well suprise!
Before:
After some time with a grindy boi:
Old 10-31-2018, 12:23 AM   #5
Ryan410
Member#: 297589
Solid build! Previous owner must have really known his ****.
Ryan410 is offline   Reply With Quote
Old 10-31-2018, 09:58 AM   #6
CursezZz
Member#: 414974
2006 Subaru WRX STi
negative man kind of a douche nozzle
Old 10-31-2018, 10:24 AM   #7
MattSpano
Member#: 480838
2018 WRX 6spd Prem.
World Rally Blue
Beautiful build
MattSpano is offline   Reply With Quote
Old 11-01-2018, 01:14 PM   #8
CursezZz
Member#: 414974
2006 Subaru WRX STi
Originally Posted by MattSpano View Post
Beautiful build
THANKS! im only just getting started
Old 11-04-2018, 02:50 AM   #9
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
HAHA Love the purchase story, now he can see the error in his ways frequently. Keep the updates coming!
JDMJNKY is offline   Reply With Quote
Old 11-04-2018, 02:58 PM   #10
CursezZz
Member#: 414974
2006 Subaru WRX STi
its prob the best part lol the week i brought it to a meet after purchasing it, he said it multiple times
Old 11-06-2018, 11:06 AM   #11
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Nice looking build you've got going. Any thoughts/remarks on the DSS carbon shaft? I've been considering it but I wanted to make sure there were no fitment issues before I drop the coin on that thing.
Turpid Porpoise is offline   Reply With Quote
Old 11-06-2018, 11:17 AM   #12
CursezZz
Member#: 414974
2006 Subaru WRX STi
none! DO IT!
Old 11-12-2018, 06:31 PM   #13
96accord
Member#: 145105
2015 Honda Accord
Subscribed (even though it's dog slow right now).
96accord is offline   Reply With Quote
Old 11-12-2018, 08:50 PM   #14
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
HAHAHA. Let's get some updates!
Old 11-12-2018, 10:32 PM   #15
subarutrissi
Member#: 493969
2006 WRX Limited
Obsidian black pearl
Subaru Stars very nice impreza
this is a very nice subaru impreza
subarutrissi is offline   Reply With Quote
Old 11-14-2018, 12:26 PM   #16
CursezZz
Member#: 414974
2006 Subaru WRX STi
when it came time to set the valve lash the assembler was getting some odd readings, possibly because the GSC valves are a hair longer than OEM not really sure. so more buckets had to be ordered ughhhhh
and here it is fully assembled and ready to go in.....when my clutch arrives
The ACT 6 puck and my Motul break in
The gorgeous Titanium teardrop knob crafted and burned by Chris at WC Lathewerks, im currently waiting on production of my Ti boot retainer and reverse lock out.
Stock block out and whack little turbo exposed
Some junk swapped over
Crappy pic of my Walbro 450 with my pup in the background
Motul Gear oil cocktail ill be running with the new gears!
ALL TOGETHER NOW ready for re-install after the gear change
Old 12-16-2018, 10:41 PM   #17
CursezZz
Member#: 414974
2006 Subaru WRX STi
well i was only gonna do the 07+ 3/4 gear but after very little persuasion and peer pressure i decided to add Spec B 5/6 too!
now ill have longer third gear through
then came assembly time!!
THEN THE BEST PART!!!!! PICKING THE CAR UP!!!
More WC Lathewerks Hotness:
and installed!
more parts arrived! IAG Competition AOS they changed the look a little since the one i had on my WRX
Old 12-19-2018, 08:06 AM   #18
96accord
Member#: 145105
2015 Honda Accord
Next: Driver Mod?
Old 12-19-2018, 11:15 AM   #19
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
HAHAHA!
Sweet updates that LB looks sick. Makes you just want to build a motor for the clean look. I will have to read up on gear set mods and benefits, I like transmissions so that's peeked my interests. I wish I would have known you need those spacers for the IM, I have some not in use.
Old 12-19-2018, 12:24 PM   #20
CursezZz
Member#: 414974
2006 Subaru WRX STi
HAHAHA!
so pretty and shiny. putting the ugly used stuff back on did make me sad lol i was originally only gonna do the 07+ 3/4 gear but was peer pressured into the longer 5/6 because why not lol only marginally more expensive.
Old 12-22-2018, 06:15 PM   #21
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Welcome back to the subie world.
I kinda want to buy your old block just for the heads, because I plan on doing a closed deck in my RSTi at some point and could use them to build a motor on the side.
AcquaCow is offline   Reply With Quote
Old 12-23-2018, 09:17 PM   #22
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Where did you end up buying the heads?
BlueSTI4Me is offline   Reply With Quote
Old 12-24-2018, 10:32 AM   #23
CursezZz
Member#: 414974
2006 Subaru WRX STi
i bought em bare from Subaru, brand spanking new.
Old 12-24-2018, 10:32 AM   #24
CursezZz
Member#: 414974
2006 Subaru WRX STi
PM me and we can work something out!!
Old 01-15-2019, 02:06 PM   #25
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Huge build list for 350hp. Do you ever plan on getting serious?
bluemax189 is offline   Reply With Quote
