Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 12-04-2018, 12:35 AM   #1
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Default Brake Master Cylinder Failure
I had a brake failure a few weeks ago and I'm looking for support trying to determine the root cause. MC is from a 2004 WRX.
MC had fluid topped off, 50-60% pad life all round with DTC60's. Fluid flushed with Motul RBF600 a few track events prior. Pedal went dead, straight to floor with no previous signs of brake fade prior to having nothing. Pumped a couple times but didn't really come back.
Testing out in the garage the brake pedal was firm without engine on/vacuum. The pedal was soft starting up engine and first time pumping brakes after failure. The brakes firmed up after a few pumps.
I took the MC apart and tried to diagnose. I noticed there was some fluid and debris collected around the fwd most (secondary?) grommet and there was minor wear on the secondary/fwd piston. With the MC off the car, the piston seemed difficult (seemed sticky/friction) to work in and out of the MC housing. After a few cycles the pistons seemed to compress into the housing without much difficulty. There is a ~1mm ring in the housing that has wear marks from being dirty. The locking cap and interface with the brake booster was also very dirty.
Thoughts? I am not 100% ruling out air entering at some point during a fluid flush, although unlikely. No noticeable leaks around brake lines. The fluid level in the tank seemed to have gone down by about ~2/10".
corona672 is offline   Reply With Quote
Old 12-04-2018, 05:28 AM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
When you flushed the fluid, I bet you pumped the brake pedal using the buddy method for bleeding, didn't you? You over-extended the master cylinder piston travel causing the piston o-ring to travel over the ring of gunk that collects at the end of the normal, sealed-system travel distance. This is a common master cylinder failure, and most people only make this mistake once.
If you didn't do this... the problem is the same - the seal in the cylinder is shot and needs to be rebuilt or replaced. It happens.
mrsaturn7085 is offline   Reply With Quote
Old 12-04-2018, 04:27 PM   #3
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
How do YOU avoid this? I've only ever had it be an issue on higher mileage MCs.
Do you just do half pumps on the pedal? Motive bleeder?
car_freak85 is offline   Reply With Quote
Old 12-04-2018, 04:47 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I can't answer for mrsaturn7085......for me, a 14yo set of seals, I assume I will have issues due to age and maybe water.
So.......new MC, bench bleed, bleed when installed, call it a day.
But that is just me.
Decades ago, you could get all sorts of hydraulic rebuild kits, now, most places don't have them and the price is close to a whole new unit you swap in.
Sheesh, I bought rear wheel cylinder rebuild kits for our 99 Impreza L wagon (rear drums), only to show my son how to do it.
For about $4 more, I could have replaced the pair of wheel cylinders.
Old 12-04-2018, 06:22 PM   #5
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
You can order the internal parts OEM from Subaru to rebuild. Since my MC housing is pretty beat I'll just be getting a new assembly.
I did use the buddy method, so I would concur that the seals in the piston could have over-traveled. Especially on 14 year old seals. Time to invest in a venturi vacuum or a power bleeder...
Old 12-04-2018, 08:41 PM   #6
mrsaturn7085
Member#: 375462
WR Blue
You do half pumps of the pedal to avoid the issue I described. You are correct that it is more common on higher mileage parts - the usual stopping point of the seal builds up a step of gunk over the years (it's like a little plow that just keeps building a pile of garbage) and it hardens and gets sharp enough to damage the seal itself. Having a wife or other non-car person pump the pedal without coaching them first is a sure way to destroy a master cylinder.
You don't need a pressure or suction bleeder - the buddy method is still the best and easiest to clean up... though speed bleeders work fine if you don't have any friends.
Old 12-06-2018, 01:47 PM   #7
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Problem: My master cylinder broke!
Solution: Don't marry or hang out with non-car enthusiasts
Thanks for the diagnosis
Old 12-06-2018, 03:01 PM   #8
mrsaturn7085
Member#: 375462
WR Blue
I would not hone/rebuild a 14 year old cylinder.
You can have anyone pump the brakes, just explain the pedal travel thing before hand - easy enough.
Old 12-06-2018, 04:50 PM   #9
car_freak85
Member#: 13530
EJ205
Once you start playing with cars that are pushing 30 years old, you don't have much choice...
Old 12-06-2018, 05:00 PM   #10
mrsaturn7085
Member#: 375462
WR Blue
Subaru parts are like Lego blocks - I guarantee there are over a dozen valid part numbers that will work for this part if you're willing to use a line bender.
Old 12-06-2018, 05:13 PM   #11
car_freak85
Member#: 13530
EJ205
It's getting hard to find the 1-15/16" four-port MCs that were only available on base model 1992-95 non-ABS SVXs... (THE MC to mate big EJ brakes to an EA Subaru chassis).
Old 12-06-2018, 07:37 PM   #12
mrsaturn7085
Member#: 375462
WR Blue
I believe you mean 1-1/16" 4-port. I've never seen a nearly-2-inch master on a Subaru.
That's the same size as the STI master. Lines on the wrong side and don't want to bend lines? Euro and JDM masters have the port side flipped. Fix a 2-port cylinder by running two tee-fittings - you can still keep the diagonal split for safety.
I would put the extra effort into using new parts and a custom system than I would keeping an old master cylinder on life support.
