Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 12-05-2018, 03:20 PM   #1
UncleCecil
Member#: 494880
2000 Subaru Outback
Default Compatible Parts
I have a 00’ Outback Wagon. 3 yrs ago I had body completely restored (buddy is Classic Vehical Restorer) and coated with Linex. I replaced all shocks/ struts, suspension bushings, breaks/ caliper, Street Rays lift kit. Interior is clean and Engine replaced with 2.5 L with 86k. I would like to upgrade brake/ suspension/ exhaust systems for performance with mild engine tweak. Are there “any” parts from the RS/ WRX/ STi the are compatible transfers?
UncleCecil is offline   Reply With Quote
Old 12-05-2018, 03:53 PM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Front calipers are directly replaced with 06/07 4 pot WRX calipers. Rotors are exactly the same in front. Rear rotors are smaller on a WRX and calipers are the same (except for the 06/07). I haven't done the 2 pot rears so can't help with compatibility.
Engine wise, there's not much of anything you can do with a N/A that's not a boatload of money (aka, a full WRX engine swap would be the same money for way more gain).
Any Impreza/Crosstrek wheel set works. Crosstrek tire size is the same as your Outback for diameter.
I can't think of anything else off the top of my head. I've had an 02 and 04 Outback (same generation as yours) and swapped brake parts from the 02 when I had an 01 2.5RS to upgrade the GC8 for my track use.
Old 12-06-2018, 09:17 AM   #3
Loyale93
Newbie Moderator
Member#: 91347
2004 Tacoma Crew Cab
2012 Triumph 1050
Vehicle...
Loyale93 is offline   Reply With Quote
Old 12-06-2018, 10:06 AM   #4
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Originally Posted by Loyale93 View Post
Vehicle...
UncleCecil, if you fill in your profile (blue stripe at top, userCP), then members will have a better picture without asking.
Old 12-06-2018, 01:22 PM   #5
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
Jack, did you see a noticeable difference in the braking ability when you did the front swap? Debating whether to bother on my Outback.
D-rock240 is offline   Reply With Quote
Old 12-06-2018, 01:33 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Outback (Legacy based) or Outback sport (Impreza based)?
Makes a big difference.
Since asking about WRX, etc., guessing OBS (Outback sport).
Old 12-06-2018, 01:36 PM   #7
D-rock240
Member#: 284221
2011 WRX GV SSM
Legacy (BH). Actually I have two 3rd gen wagons at the moment.
Old 12-06-2018, 04:15 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
I was asking the OP, not you.
The Legacy based platform had better brakes than the OBS.
Yes, my apologies, I should have quoted the OP. But, Outback can mean 2 different things.
Your brakes are likely similar to mine, unless tracking, the Outback should be fine beyond decent pads and a fluid change. If poor, either learn to manage heat, do regular maintenance, maybe SS lines for firmer feel.
Old 12-12-2018, 08:44 PM   #9
UncleCecil
Member#: 494880
2000 Subaru Outback
Thank you. I wouldn’t think the CrossTreck wheels would be an optinas well.
Old 12-12-2018, 09:01 PM   #10
UncleCecil
Member#: 494880
2000 Subaru Outback
Which calipers can I use in Rear without 06/07 as an option?
