Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 12-05-2018, 04:57 PM   #1
putrio
Member#: 494757
2011 STI Hatch
Default Scrap Engine or....
Hi All! I spun a bearing...have not split the case halves on the short block to inspect the insides. Should I just take it to a scrap yard and get $20 for the short block, or is there another user for it?
Thanks!
putrio is offline   Reply With Quote
Old 12-05-2018, 05:32 PM   #2
Prodrive_sti
Member#: 357918
Where you located
Prodrive_sti is online now   Reply With Quote
Old 12-05-2018, 08:43 PM   #3
putrio
Member#: 494757
2011 STI Hatch
Originally Posted by Prodrive_sti View Post
Where you located
Cincinnati
Old 12-06-2018, 09:17 AM   #4
Loyale93
Newbie Moderator
Member#: 91347
2004 Tacoma Crew Cab
2012 Triumph 1050
Both of you, please fill in your profile.
Loyale93 is offline   Reply With Quote
Old 12-06-2018, 10:18 AM   #5
putrio
Member#: 494757
2011 STI Hatch
I updated mine, thanks for the heads up. Here in Cincinnati, we call our area tri-state, so I put that as the local chapter, but I'm sure there are other areas of the country that call themselves tri-state...so that might be wrong. Out of curiosity, where was the thread moved to?
I'm betting I could just sell the block on CL or something instead of trying to scrap it.
Old 12-06-2018, 11:01 AM   #6
86Dreams
Member#: 385256
V7 S204
I believe the tri-state area colloquially referse to NY, NJ, & PA.
I am facing that kind of question right now with a blown 5 speed. Even though your block is definitely worth more than $20, actually selling it all depends on some one wanting to buy it. You could put it up on CL for $30 dollars right now, but theres no guarantee any one is looking to buy one.
So I guess its kind of like a stock, if you can set it aside and hold it then itll probably be worth more sometime in the future. If you just want out then take your $20 buy a 12 pack and enjoy the extra 3 square feet of space you liberated in your garage.
86Dreams is offline   Reply With Quote
Old 12-06-2018, 12:50 PM   #7
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Tri-state is PA (specifcially the northern region thereof. Southern region guys are more often in the Mid Atlantic region forum, but both apply to PA)/NY/NJ
Ohio would be in the Midwest region.
The description beneath each region or chapter name tells what states are part of it.
SirBrass is offline   Reply With Quote
Old 12-06-2018, 12:58 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Cool
Agreed, I have seen a few Ohio, etc., peeps use tri state, and yes, the region is sorta spelled out for each specific region.........Ohio is NOT tri state per this (or most) forum regional sections descriptions.
BTW, some western CT peeps also use tri state instead of NESIC. Whatever, if this was the worst thing to deal with, I would be happy.
Old 12-06-2018, 12:58 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Methinks you did a lot of "copy paste" this morning......
Old 12-06-2018, 01:01 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Thanks!
Gut and clean it, make a side table.
Maybe a person will want to rebuild it.
Seems like most shops are "hands off" doing a stock SB rebuild, just easier and more reliable to get new. The cost to do a good rebuild is not much cheaper after cleaning, machining, parts and labor.
