Welcome to the North American Subaru Impreza Owners Club Sunday August 14, 2022
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 02-03-2019, 01:46 AM   #1
notguilty411
Member Sales Rating: (4)
Member#: 218030
2004 stg 2 WRX wagon
Default PA : 2006 Subaru Legacy GT Spec B. 210k $6,000
Year, Make, Model: 2006 Subaru Legacy GT Spec B. 65/500
Price: $6,000 OBO? Not really sure what the car is worth to be honest.
Mileage: 209,XXX
Transmission: 5 speed
Contact: email is best, [email protected]
Listing up for sale my daily driver 2006 Legacy GT Spec B. number 65/500. Found this car for sale locally on craigslist late summer of 2017 listed with a pretty vague description, less than stellar pictures, 170k miles looking rather neglected. I had no real need for the car at the time but contacted the seller on a whim and made the trip to check it out. The PO apparently acquired the car through some kind of trade deal and wasn't super knowledgeable with what he had, it sounded pretty risky but ultimately I decided the car was worth saving so we made a deal and I drove it home. My original plan was to clean it up, go through the car mechanically then drive it through winter and unload in the spring. Turns out I really enjoyed driving it so here I am a year and a half/35k miles later and its still sitting in my driveway. I am a professional and currently have four other vehicles in my stable, the Legacy has surved as my daily driver over the past year and it has been properly cared for as needed. The car runs, drives and stops without issue and everything works as it should. I would drive my pregnant wife across the country in it tomorrow if needed. Only real reason for selling is that I could use a daily with a little more storage space. That being said I would consider trades up or down for a well maintained Legacy wagon, Outback, Forester or something along those lines. Here are the details.
Current Modifications - Installed by me during my ownership unless otherwise noted
Cobb SF Intake
Invidia catted DP
Cobb OTS stage 2+ flash via APV2
unknown brand non-resonated mid pipe (on car at purchase)
unknown brand cat back (on car at purchase) possibly Magnaflow? No visible markings and I never dropped the mufflers to look for any id markers. Sounds good regardless.
OEM catless UP
Grimmspeed UP/Turbo/DP gaskets
Cobb turbo inlet
AVO IC to TB hose
DIY TGV deletes
Killer B oil pick up
OEM WRX SMF
Exedy stage 1 clutch
TSK3 TOB/snout kit
Group N engine/trans/pitch stop mounts
Kartboy tans cross member bushings
Whiteline steering rack bushings
Whiteline ALK
Whiteline control arm bushings
Whiteline F/R adjustable sway bars/endlinks
Tein H-tech springs (on car at purchase)
Hawk HPS front brake pads
Perrin shifter bushings
Cobb or Kartboy exhaust hangers, can't remember which ones I bought but brand new sitting in a box in my garage waiting to be installed.
35% window tint on side and rear windows
HID's of some sort (on car at purchase)
LED interior lights (on car at purchase)
Font lip (on car at purchase)
Maintenance completed during my ownership-
Purchase 170k -
History mostly unknown. According to the PO the engine was pulled and the top end gone through around 160k miles due to a dropped valve, I have no proof other than his word but after having since pulled the engine myself for a clutch replacement I did find evidence of turned bolts and what appeared to be shiny new head gaskets. The cold side of the turbo is powder coated red so I am assuming it was either rebuilt/replaced at some point prior to my ownership as well. Did an oil/filter change after purchase with 0w40 Castrol Edge and Subaru blue filter.
175k -
Oil/Filter
Installed adjustable sway bars/end links
177k -
Installed catted DP and flashed Cobb OTS stage 2 map
178k -
Replaced driveshaft
tire rotation
new AC belt
179k -
Installed Cobb SF intake/airbox and flashed Cobb OTS stage 2+
180k -
Oil/Filter
185k -
Oil/filter
tire rotation
187k - Clutch went out completed the following
Oil/filter
coolant flush
Had wheels refinished and installed new tires Goodyear eagle sport A/S 225/40R18
Gates timing belt
OEM waterpump
OEM idlers
OEM TB tensioner
OEM t-state
OEM oil pump seal
OEM crank seal
OEM RMS
OEM oil seperator
oil pan gasket
DIY TGV deletes
OEM spark plugs
Installed Cobb turbo inlet
Installed AVO TMIC/TB hose
Installed OEM WRX SMF
Exedy stage 1 clutch disk/PP
TSK3 TOB and snout kit
Engine/trans/pitch stop mounts
ALK
F/R brake rotors
Hawk HPS front pads
brake fluid flush
Trans fluid replaced
shifter bushings
etc.
188k -
Replaced front right axle
four wheel alignment
193k -
Oil/Filter
Tire rotation
200k -
Oil/filter
tire rotation
201k - Lancaster County Subaru
PA state inspection/emissions testing
Airbag recall
brake line recall
204k -
Oil/filter
209k -
Oil/Filter
Left rear wheel bearing
tire rotation
Cons - Mechanically the car doesn't need anything but If I were to keep it the next things on my list to address would probably be springs/struts. The car is on Bilsteins and Tein H-tech springs, if I had to guess the Bilsteins are probably not original at this mileage but I haven't touched them. The Tein springs are a little soft in my opinion but otherwise ride fine. I haven't touched any of the rear suspension bushings but everything appears to working as intended. Next would be a proper pro-tune, the OTS Cobb maps are ok but not perfect by any means. I used ATR to turn off the TGV codes in order to clear the associated CEL's but otherwise they have not been tuned for.
Cosmetically the car is a 15 footer in my opinion. The front and rear bumper covers have some damage and there is paint chipping of the leading edge of the hood. There are a few other minor dings/dents/scratches associated with a 15yr old/200k mile Subaru but all in all it cleans up pretty good for what it is. I never ran a Carfax but there is evidence of paint work on the front end. Hood and fenders have been painted for sure, all panels are stamped Subaru however. Interior wise I would say 7/10, minor wear on the driver seat outer bolster, steering wheel and shift knob, couple minor knicks and scratches here and there but pretty clean for the mileage and everything works. I currently have Subaru all weather mats installed in the car and I have the original carpet mats to go with as well.
Thule rack and bike trays are NOT being sold with the car.
All that being said I'm in no real rush to get rid of the car but could use something with a little more versatility. Not really sure what the car is worth but I feel like somewhere in the ballpark of $6k is reasonable. Feel free to contact me anytime with questions, email is best [email protected].
Pictures were taken a couple months back, car remains in the same condition with the exception of small scrape on the rear passenger side of the bumper from me backing into it in my driveway. I can send/upload more photos as requested.
Thanks for looking.
https://i.imgur.com/pf1IUGm.jpg
https://i.imgur.com/lDIau6X.jpg
https://i.imgur.com/TxpgrvL.jpg
https://i.imgur.com/dymnAhb.jpg
https://i.imgur.com/VZFT9tD.jpg
https://i.imgur.com/8BckAWj.jpg
https://i.imgur.com/Pi6fgt8.jpg
https://i.imgur.com/pKpp0me.jpg
https://i.imgur.com/zlvzxnX.jpg
notguilty411 is offline   Reply With Quote
Old 02-03-2019, 01:18 PM   #2
MortonCharbo
Member Sales Rating: (3)
Member#: 487057
2002 WRX Wagon
Your car makes me tingle a little bit. GLWS! If I find a box of money, I'd buy this in a heartbeat.
MortonCharbo is offline   Reply With Quote
Old 02-04-2019, 12:11 PM   #3
notguilty411
Member#: 218030
Thanks!
Daily bump.
Old 02-12-2019, 02:58 PM   #4
notguilty411
Member#: 218030
Bump. Just turned 211k, been commuting about 1,000 miles a week in it lately.
Old 02-13-2019, 01:44 PM   #5
frugalrhombus
Member#: 494291
2019 STI
Dark Gray
Dude this thing is gorgeous, I was actually looking for a hawk eye to use for a project but this could be a viable option. But I'd kind of feel bad doing it to a car this rare.
frugalrhombus is offline   Reply With Quote
Old 02-24-2019, 04:17 PM   #6
fullmetal
Member#: 263794
Donít know if your interested but I have a 07 black WRX base wagon with 198k on it I wouldnít mind trading
fullmetal is offline   Reply With Quote
Old 02-24-2019, 09:43 PM   #7
notguilty411
Member#: 218030
Maybe, had a couple WRX wagons in the past. Send me details and Iíll take a look at it. Thanks.
[email protected]
Old 08-13-2019, 04:26 PM   #8
KaZ
Member#: 4335
2009 Nissan Maxima
Navy Blue
Still available?
KaZ is offline   Reply With Quote
Old 08-14-2019, 01:32 PM   #9
notguilty411
Member#: 218030
Originally Posted by KaZ View Post
Still available?
Actually, yes it is. I havenít actively been trying to sell it lately but Iíd let it go if somebody wants it. Currently has 225k on it. If interested shoot me a pm and we can talk.
Old 11-04-2019, 08:39 PM   #10
notguilty411
Member#: 218030
Bump, decided to list this thing back up for sale. Mileage is currently at 229k. $5k OBO, possible trade for a well maintained Forester/Outback/Wagon of some sort.
Maintenance in the past 20k consisted of..
@ 213,101
Cobb exhaust hangers installed
@ 214,714
Oil/Filter
Tire rotation
@ 220,374
Oil/Filter
Tire rotation
@ 225,109
Oil/Filter
Tire rotation
Right rear hub/wheel bearing
@ 228,301
PA Inspection/emissions
AC low pressure schrader valve replaced
AC recharged
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
