Welcome to the North American Subaru Impreza Owners Club Saturday February 23, 2019
Old 02-11-2019, 10:32 AM   #1
thejuggler1
Member#: 481151
2016 WRX Limited
Default HID Tap to Turn Relay
I have aftermarket HID headlights on my '16 WRX (were installed before I bought it). I am looking for a tap to turn relay but everything I've found are for LED (stock) headlights. I bought one relay but it did not work. Any idea if their are any relays that work on HID headlights or have I bought a faulty or cheap relay?
thejuggler1 is offline   Reply With Quote
Old 02-11-2019, 12:02 PM   #2
hrbutler52
Member#: 295691
2011 WRX
Blue Mica
A tap to turn relay should not be affected by your HID headlights, as it runs the turn signal which is either a tungsten filament or a LED depending on your aftermarket headlight. Check that your relay is compatible with ground side switching [AKA "pull type circuit"].
hrbutler52 is offline   Reply With Quote
Old 02-11-2019, 01:14 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're referring to the TapTurn relay it should be compatible with your '16-
https://www.autowindow.com/install-instructions
The headlights don't matter for the turn signals as already noted above.
Also the '16 should already have the tap-turn function built into the BIU, so the aftermarket module would not do much for you unless you are changing the turn signals to LED.
