Welcome to the North American Subaru Impreza Owners Club Monday November 11, 2019
Old 02-20-2019, 06:44 PM   #1
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
Default '13 p0301 misfire STUMPED please help!
Hi All,
I'm a newbie so sorry if this is misplaced. Hoping to get some help...
Car:
13 WRX 2.5L Turbo Professionally Tuned with Accessport
95k miles (just purchased about 1 month ago)
Fuel up car and car starts and drives super rough on the second start
Thought it was a bad mix of fuel. p0301 and PFFFE misfire codes
Clear codes and run down the tank. Car is running fine. Was a smidge low on oil so it was topped off. Fuel up again and what do you know. Second start after refueling same codes.
Recently cleaned MAF and air cleaner
Changed spark plugs, inspected coil packs (even swapped 1/3 to see if the code would jump to cylinder 3)
After spark plug change, codes still there. Went for a drive and the car ran better than ever. Got home turned off the car, cleared the codes. Went to start the car and it idled like GARBAGE. Took it around the block and it ran super rough.
I'm trying not to get elbow deep in repairs here. Any suggestions where to start?
Do I cough up the money and change all the coil packs?
The spark plugs had some build up but weren't in horrible shape when I changed them.
Is it worth looking into the EGR purge valve? Since it is only after fueling?
Does this sound like carbon build up?
Read an interesting thread about an engine wiring harness issue for this model. https://forums.nasioc.com/forums/sho....php?t=2550077
I appreciate any help you experts can offer. I am expert when it comes to Fords and Hondas, so I can dabble with the parts, just not very well versed on Subarus since this is my first one.
Thanks for any help!
PEARLWHITE925 is offline   Reply With Quote
Old 02-20-2019, 06:50 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
One thing to keep in mind, every time you clear codes, flash a map or disconnect the battery, the ECU loses fine learning.
Some cars are not bad with that.
Other cars need several cold starts and some running to relearn.
This is not just Subaru, this is pretty much ANY car with an ECU.
Beyond that, I will let others with newer Subaru engine experience comment.
Old 02-20-2019, 07:20 PM   #3
n2oiroc
Member#: 141952
18 golf arrrr!
check the harness in the thread you linked. its a somewhat common issue and an easy fix to solder it.
n2oiroc is online now   Reply With Quote
Old 02-20-2019, 08:14 PM   #4
goldfingerfif
Member#: 428541
2016 STi Base
Lapis Blue Pearl
I still don't get how that fixes anything as those wires just connect to EMF shields around the wires. It didn't fix my misfire code but good place to start regardless.
goldfingerfif is offline   Reply With Quote
Old 02-20-2019, 08:18 PM   #5
goldfingerfif
Member#: 428541
2016 STi Base
Lapis Blue Pearl
Can you log roughness for cylinders 1-4 with all the other normal stuff to see how bad it is and when it is occuring? Does your AFR look ok? Timing? AF Corrections and Learn really high? Also check ALL ground connections, that's the lesson I learned.
Old 02-21-2019, 05:47 PM   #6
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
I will try to log this weekend and get a post up, thanks!
Old 02-21-2019, 05:47 PM   #7
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
Thanks Charlie-III!
Old 02-25-2019, 06:29 PM   #8
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
Here is the datalog from a 20 mile drive yesterday. Notice anything that looks out of whack? I'm pretty new to using this, so any feedback you have here is helpful.
https://drive.google.com/open?id=1G2...Nua4j_KMiy80zc
Old 02-28-2019, 09:47 PM   #9
moldy1
Member#: 391884
Bumping and subscribing cause I have a Ď13 with the same exact issue.
Itís been a week since mine threw a misfire code. Cleared code/ reset ecu but then car would stall out when coming to stop.
moldy1 is offline   Reply With Quote
Old 03-02-2019, 12:46 AM   #10
moldy1
Member#: 391884
Iím pretty new to this too, but for what itís worth, I did a log on mine. My AF learn was all negative and beyond -8%. Yours all seem to be in line with info I found thru link below.
Hereís a link that might help.
https://www.cobbtuning.com/subaru-da...ging-overview/
Old 03-07-2019, 05:28 PM   #11
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
UPDATE:
Wiring harness fixed via the link I referenced. Car idles, drives and starts smoothly. Have added fuel twice and no changes.
Thanks @moldy1
Appreciate the link as this helped me actually learn what my Accessport is logging.
Old 03-18-2019, 02:19 PM   #12
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
UPDATE: Car ran well for several weeks with no issues after having the wiring harness fixed. Filled up the fuel tank this weekend and what do you know... misfire back again with a rough start and idle.
Should I try to change the tune? Really getting frustrated with this.
On another note, I noticed the car is consuming a lot of oil, which there was a class action filed against Subaru about for these motors. Not sure if these could be related.
Thanks for any and all continued help here.
Old 03-19-2019, 05:22 AM   #13
n2oiroc
Member#: 141952
18 golf arrrr!
Check the cylinder roughness monitor and see if one stands out. Unfortunately, those symptoms sound like a cracked ringland.
Old 04-29-2019, 07:59 PM   #14
PEARLWHITE925
Member#: 497697
2013 WRX Hatch
Default Compression Numbers
Sooooo ran a compression test and I am not happy with the numbers
Cylinder 1: 85
Cylinder 2: 105
Cylinder 3: 80
Cylinder 4: 110
Any input? Thanks again for any help here.
Old 04-30-2019, 09:41 AM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Looks like a HG.
You can redo the test but with a shot of oil in the cylinder. If numbers come up, then you also have ring issues.
Or, you can do a leakdown test to see if rings or valves are also an issue.
Old 10-26-2019, 06:02 PM   #16
CarClubof1
Member#: 470860
2007 Foz XT Limited
I am having similar problem. Looking for some sage advice. I have a strange “misfire” problem. I use the air quotes because I’m not sure if there is a real misfire. Here are the details.
2007 Subaru Forster XT. 159000 miles. Gave a P0301 at start up the other day. Turn on my Roughness Monitor for Cylinder 1 and it was going ape ****. Was climbing all the way to 100 and then back around, over and over. As the car warms up the number would climb less and less until finally around 150 degrees it would read 0. The car does not seem to be demonstrating any signs that is misfiring. The car starts fine, idles fine, runs great. DAM at 1.000, no knock at all. No strange smells or noises. Boost comes on strong, car does not seem to lack power at all, and it will add timing as needed. I sent some data logs to IAG who did my tune and they said they did not see anything out of the ordinary.
So, the other day I broke out my service manual and started troubleshooting. Did a compression test. Numbers ok, all with in a few psi of each of other. All the plugs looked ok. They had about 10k on them. Checked the gaps, all with in spec. So, I decided to swap the coil packs around and see what I got, and I got the same problem. I did notice at this point that if the car is already warmed up a little, there is little to no activity on the Roughness Monitor.
So, I went ahead and replaced the spark plugs and coil packs. The coil pack had been original and had started to show signs of the heat sink separation anyway. Gapped the plugs to .029-.030. Put everything back together and same problem. Again, car running great, feels better than before, but Roughness Cylinder 1 craziness still the same.
Next, I’m putting in brand new OEM fuel injectors for Cylinder 1 and 3 but have not had time yet and wanted to see if anyone had had a similar problem. I read allot of other posts about sticking valves, low compression, fuel pumps, but it’s only the one cylinder and the car is running fine. Any insight would be approached. I also have a few data logs of the problem if anyone would like a look. Thanks all.
CarClubof1 is offline   Reply With Quote
Old 11-08-2019, 02:14 PM   #17
08sTiAWD
Member#: 508090
Like Charlie said, I have a built motor with 2 different maps that I run and when I change between them I have to let my car idle for about 10-15 mins before I do any kind of driving or the car runs like crap.
You also might try to add some octane booster in there as well being that this seems to only happen when you fuel up.
08sTiAWD is offline   Reply With Quote
