Welcome to the North American Subaru Impreza Owners Club Thursday April 25, 2019
Old 03-17-2019, 08:48 PM   #1
ilovedemhotrides
Member#: 326147
Default Budget build - anything stick out that I need for 500+whp On 93
Hey fellow Subaru fanatics,
Currently building up my 04 Sti after a rod knock. I am doing a budget build and am in the process of it all. I just yanked the engine and am evaluating the short block.
I have an FP black HTZ, 1000cc side feeds, Walbro 255, equal length header, full exhaust (Catless), blitz fmic, TGV deletes, ebcs, intake.
Do you see anything else that I will NEED to make 500 - 550whp. I know the turbo is fine for this and I am getting my block built with forged rods and Internals. - essentially a stage 2 + short block but pieced together myself to save some money.
Should I be good with the stock cams and fuel pump?
Anything else I should account for? I will need a new tune for sure.
ilovedemhotrides is offline   Reply With Quote
Old 03-18-2019, 01:26 AM   #2
nasiocnerd
Member#: 499216
first off, I don't think a 255 lph will get 500-550hp, and I think the best way to safely get that power would be with a e85, which will require 1300cc injectors
nasiocnerd is offline   Reply With Quote
Old 03-18-2019, 01:47 AM   #3
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Agree with what Nasiocnerd is saying.
BlueSTI4Me is offline   Reply With Quote
Old 03-18-2019, 02:06 AM   #4
Nfaber
Member#: 492353
2007 2.5i
Crystal Gray.
Yea I think 500+ is actually a lot more power than you think. You could probably push 400 without a ton of work, but if you don't want to use e85 than I'm pretty sure it's going to cost you.
Nfaber is offline   Reply With Quote
Old 03-18-2019, 02:10 AM   #5
nasiocnerd
Member#: 499216
Also, make sure you have strong head studs like APR 625s (if you don't have some already). Unless you like your heads lifting
Old 03-18-2019, 05:55 AM   #6
ilovedemhotrides
Member#: 326147
Yeah I do have arp head studs already. I did the headgasket 3 years ago for this exact reason.
Can I reuse them? As they are only 3 years (Aprox 9,000 miles) old and look to he in good shape
Old 03-18-2019, 05:58 AM   #7
ilovedemhotrides
Member#: 326147
Noted.
So I should also look into getting a higher flowing pump. Maybe a 340?
Old 03-18-2019, 06:00 AM   #8
ilovedemhotrides
Member#: 326147
I made 380whp on stock internals at like 22 psi. I am hoping to make a lot more than that with my built motor lol.
Just to be clear I am talking a dynonet not a mustang dyno
Old 03-18-2019, 02:21 PM   #9
nasiocnerd
Member#: 499216
Originally Posted by ilovedemhotrides View Post
Noted.
I would say at the very least 340. Most setups with DW300 or AEM340 are maxing out before 500hp. From my conversation with tuners, they recommended the walbro 450 for any target at or above 500hp.
As for the head studs, from what I have been told, they are easily reusable (I reused mine). Good luck with the build!
Old 03-18-2019, 03:09 PM   #10
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
500WHP on 1,000CC injectors puts you pretty close to max safe duty cycle, you may want to step into an ID1300 or FIC1200 for some more head room.
I'd definitely recommend a fuel pump in the 320-340lph range as well. Keep in mind that flow drops as pressure rises.
I believe most of the bigger engine builders will recommend a closed deck block in the 500-550whp range as well.
Probably need a 4 bar map and you don't need cams but a stage 1 cam would make it easier to achieve your goals.
Turpid Porpoise is offline   Reply With Quote
Old 03-18-2019, 05:11 PM   #11
ilovedemhotrides
Member#: 326147
Appreciate the reply brother. To get cams or not to get cams.... Do you think if I stay stock cams I should upgrade the springs / retainers ?
Old 03-18-2019, 06:31 PM   #12
Turpid Porpoise
Member#: 476573
It definitely wouldnít hurt and provides reasonably priced peace of mind so you wonít have to worry about it if you intend to spin the motor higher than the original redline.
Old 03-19-2019, 02:05 AM   #13
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
With that turbo, fuel and injectors you won’t hit 500whp. It will get you close maybe 450 but not 500. I’m going through this exact issue right now with my new engine. You want 500whp, you need e85 or some kind of race fuel. Pump gas just won’t do it. I’ve been going back and forth with the guys at IAG for a while trying to figure out how I can make 500 without e85.
Brother EddieJ. is offline   Reply With Quote
Old 03-20-2019, 06:58 AM   #14
ilovedemhotrides
Member#: 326147
Originally Posted by Brother EddieJ. View Post
With that turbo, fuel and injectors you wonít hit 500whp. It will get you close maybe 450 but not 500. Iím going through this exact issue right now with my new engine. You want 500whp, you need e85 or some kind of race fuel. Pump gas just wonít do it. Iíve been going back and forth with the guys at IAG for a while trying to figure out how I can make 500 without e85.
Ah man that stinks. I guess 450ish isnít end of the world. Stinks I donít have e85 within 20 miles of me
Old 03-20-2019, 10:41 AM   #15
PDXREALTOR
Member#: 468393
2017 STI
5 gallon pails of TORCO octane boost is cheap. 3oz per gallon of gas put you over 100 octane. Easily 500 whp capable. Add a dash of meth spray and you're golden.
Even if I had e-85 I'd still run the torco and and a small squirt of wiper fluid.
PDXREALTOR is offline   Reply With Quote
Old 03-20-2019, 01:23 PM   #16
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
In before the 'why is my car overheating?' post...
Ah man that stinks. I guess 450ish isn’t end of the world. Stinks I don’t have e85 within 20 miles of me
350 whp isn't the 'end of the world' on an older GD chassis.
500+ whp on 93 octane isn't going to be a realistic goal with what you've posted. E85, maybe - but you'd need more fueling.
I'll put it this way - you start off by saying 'budget build' and then say '500 - 550 whp'. These don't go together.
mrsaturn7085 is offline   Reply With Quote
Old 03-20-2019, 06:33 PM   #17
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
This 100% . . . It sounds like you just need to build around what you have and see where the whp ends up. Otherwise this will NOT end up being a budget build.
Scuby04STi is offline   Reply With Quote
Old 03-21-2019, 02:42 AM   #18
ilovedemhotrides
Member#: 326147
Yeah I guess youíre right. I was under the impression with a built bottom end and full bolt ons with an FP black 500whp would be no problem.
Let me rephrase my question. Given my goal to make some serious power for a fun weekend car, what is the biggest hold up or bottleneck ? Sounds like fueling. So adding in some sort of meth solution might be the key to free up some HP. Can also run bigger injectors than the 1,000cc I currently have but then I need to probably look into the conversion to top feeds.
Old 03-21-2019, 08:11 AM   #19
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Who is tuning your car on 1k side feeds?
Zee Biker is offline   Reply With Quote
Old 03-21-2019, 01:19 PM   #20
mrsaturn7085
Member#: 375462
WR Blue
Generally speaking, the bottleneck limitations on all Subaru cars will be fueling and turbo until you break the motor.
Pick a power target, size your fueling (this is easy). Still in your budget? Good - move on to the turbo.
Find a turbo that meets the same flow ratings for your goal and figure out the cost of installing it (including manifold + wastegate). Budget for the intercooler if you need it. Still in your budget? Good - move on to the motor.
As soon as you run out of money, go back to the start with a lower goal.
Old 03-21-2019, 02:16 PM   #21
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Also consider buying some of these things from members on here, a lot of us have a LOT of old parts. LOL
Old 03-21-2019, 04:27 PM   #22
rtv900
Member#: 428511
2016 STI
what, 200hp per liter isn't budget build territory?
sounds realistic to me
spend budget
make 500hp on dyno once
drive car twice
shred motor
start new budget
rtv900 is offline   Reply With Quote
Old 03-23-2019, 10:50 AM   #23
DanT55
Member#: 456981
02 WRX
Maybe a good water meth system running 93 pump gas could get your there if E85 is not an option?
DanT55 is offline   Reply With Quote
Old 03-23-2019, 11:23 AM   #24
TDagen
Member#: 163648
2002 Resurrected WRX
https://forums.nasioc.com/forums/sho....php?t=2429748
Here’s Juan’s old FP black thread. I would say it’s kind of a budget build, he’s running E85 but the timing is low for the first page dyno graph. He’s even doing this on a tmic. Almost hits 500whp with low timing.
TDagen is offline   Reply With Quote
Old 03-23-2019, 11:47 AM   #25
Rideit636
Member#: 275099
Budget, 500whp, and pump don't belong in the same sentence. ESPESSIALLY on a non-closed deck, and then on a stock location exhaust housing. You're setting yourself up for failure. Been there, done that, cracked liners. This build plan wouldn't last a few thousand miles. If you truly want 500whp on pump gas, you need a rotated 3582 or bigger. Your fuel system isn't going to cut it on any fuel. Back to the drawing bored on this one. Your cheapest bet if you want to retain that turbo and MUCH safer route is switching to top feed, buying some ID1300X's, a Walbro 450 (an AEM340 will do it on the edge), and going flex fuel. You'll make your 550whp and have some longevity.
Rideit636 is offline   Reply With Quote
