Welcome to the North American Subaru Impreza Owners Club Sunday May 19, 2019
Old 05-12-2019, 10:58 PM   #1
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
Default Built Engine Coolant
So i currently have a built 2006 WRX STI IAG Short Block, CNC Ported & Brian Crower Internals for the Heads with Cosworth Gaskets in a 705 Casting with a Rotated 6466, etc.
Since its a 2006 STI i would typically use the green coolant but since im running a 705 casting and new lines can i run SuperBlue? Its a super niche question but im not quite sure. I have a Mishimoto Dual Core Radiator (Not X Line) if that matters?
Awdthony is offline   Reply With Quote
Old 05-12-2019, 11:07 PM   #2
Blktrax
Member#: 220971
2002 WRX 223K Mi.
SuperBlue is 100% backwards compatible with Subaru green. However the coolant still should be serviced every 30k miles as the green was supposed to be.
Advantage is SuperBlue already premixed 50/50 with distilled water and corrosion inhibitors. Where as Subaru green is 100% Coolant and you have to make your mix with distilled water. Plus recommended adding a bottle of Subaru coolant conditioner.
Using tap water just introduces all the fun chlorine and other minerals the make corrosion and deposits form in the cooling system.
Blktrax is online now   Reply With Quote
Old 05-14-2019, 01:03 PM   #3
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
When you say add Subaru Conditioner, is that to the blue or green?
Old 05-14-2019, 02:25 PM   #4
gabo_s13
Member#: 468498
2014 WRX Hatch
When I went to the dealership to buy me some of the blue stuff, they told me there was no need to run the conditioner on it.
gabo_s13 is offline   Reply With Quote
Old 05-14-2019, 03:58 PM   #5
rtv900
Member#: 428511
2016 STI
What is a 705 casting?
you mean aluminum?
rtv900 is offline   Reply With Quote
Old 05-14-2019, 05:42 PM   #6
Waddlz
Member#: 395275
2012 STi
you can get Subaru blue coolant at Walmart/O'reillys for half the price of the dealership. its Zerex by Valvoline and is $14 a gallon.
Waddlz is offline   Reply With Quote
Old 05-14-2019, 06:10 PM   #7
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Both, doesn’t matter. I’ve run blue in both my ‘02 wrx’s, One of witch for the last 5 years. Just changed it again and did the t-belt last month. Add one bottle.
Your mileage may vary. I run it in absolutely every Subaru I own, and whenever the coolant is serviced.
Period.
http://www.scoobyenthusiast.com/subaru-maintenance/all-about-subaru-cooling-system-conditioner-soa635071.html
Old 05-15-2019, 03:44 PM   #8
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
you mean aluminum?
The case halves all use a casing # to identify them, one of the options for a 2.5 is a #705 case.
I haven't run anti-freeze for years in mine, never understood the whole "only use XXX in your Subaru" stuff. LOL
Scuby04STi is offline   Reply With Quote
Old 05-15-2019, 05:02 PM   #9
Delphi
Member#: 239335
2011 WRX
Running generic green in all my cars. Never had one issue
Delphi is offline   Reply With Quote
Old 05-15-2019, 05:22 PM   #10
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I just run water in anything that touches a track. I will never be "that guy", lol.
Old 05-17-2019, 12:00 PM   #11
subaru_gc8
Member#: 29292
2004 WRX wagon
do you drain it cause water causes lots of corrosion
subaru_gc8 is offline   Reply With Quote
Old 05-17-2019, 12:35 PM   #12
Jedi03
Member#: 491095
2009 STi Blue
any should work as long as its maintained/flushed on a proper basis, basically when the glycol starts to get to acidic. i have done all types and will be switching when i need...splurged for Subaru oe coolant when doing my first flush, arm an a leg in cost just about lol. i personally use tap water with undiluted antifreeze, haven't had any issues on any of my vehicles...
Jedi03 is offline   Reply With Quote
Old 05-17-2019, 01:28 PM   #13
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Not really, I guess every few years.
I disagree, I have spent my whole life around marine application engines that use RIVER WATER to cool themselves. As long as its not terribly acidic its fine. I have run water in my car for 40k or so, and in at least a half dozen track only cars. NEVER had a corrosion related issue.
