Welcome to the North American Subaru Impreza Owners Club Saturday July 11, 2020
Old 06-09-2019, 07:42 PM   #1
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Default Control arm widths
Sorry if this is a dead horse but I can't find what im looking for. I have an 02 wrx front subframe with 98 forester control arms. I had axle bind from sitting so low so I got 05 impress axles that were shorter and it helped but I still have some bind, that and my tire rubs frame a little so I'd like to widen the front track a bit. Are there "wider" control arms or do I just go ahead and build a set?
no694terry is offline   Reply With Quote
Old 06-10-2019, 02:22 AM   #2
binny
Member#: 198108
MY98 WRX
GD Sti are about 20??mm wider (to the ball joint) the nolothane arm kit has the extra castor as well
binny is offline   Reply With Quote
Old 06-10-2019, 07:57 AM   #3
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I'm only looking for about 10mm each side, I cant even find out if the WRX GD arms are wider than the SF Forester arms
Old 06-12-2019, 04:04 AM   #4
binny
Member#: 198108
MY98 WRX
Not sure you can check out the published track width and see what the difference is or measure some if you can
Old 06-12-2019, 06:15 AM   #5
Suryank
Member#: 500698
+1
Suryank is offline   Reply With Quote
Old 06-12-2019, 07:32 AM   #6
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
i've googled track widths, theyre all over the place so i dont know what to believe. One guy on IG helped me out and measured his Aluminum GD Sti arm, its the same as my SF and I assume that one would be the widest of the GD's so looks like I'm just goign to have to make my own custom wider set
Old 06-13-2019, 07:44 AM   #7
sub_sifu
Member#: 301690
2002 Wrx
Youre right, info is all over the place.
I've read that it's +10mm width on each side for the 06-07 wrx sedan aluminum control, but can't personally verify this, and might be just repeating misinformation. I actually put them on my 02 wagon and didn't notice any difference. Here is a picture of them lined up. I don't think this helps you much, but it's something. Courtesy of our friends over at legacygt
Sedan axles are supposed to be +10mm over wagon axles on 02-07 imprezas, so you might consider trying different axles too.
sub_sifu is offline   Reply With Quote
Old 06-13-2019, 09:16 AM   #8
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Thanks. I have 05 wagon axles in now and it helped. I had a guy on IG send me his measurements on the GD sti arms and they were the same as my SF arms. So I started to just build a custom set last night. Debating on a tube brace or a plasma cut sheet metal web thing as a stiffener. They're about 13mm wider. Should solve any axle bind issues and the slight rub i get at full lock, plus all the potential handle benefits
Old 06-13-2019, 07:35 PM   #9
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Not a tube brace. Weld in a gusset. Or as you put it “sheet metal web thing”. It’s not like you’ve got a z axis to triangulate with, for instance like a roll cage. So tubular bracing is not a great idea.
bdubblu is offline   Reply With Quote
Old 06-13-2019, 08:12 PM   #10
jamal
Member#: 71875
There are two widths of that style control arm. The 1st gen impreza or GG wagon arms, and the 02-07 sedan arms. The difference is somewhere in the 10mm ballpark.
The 2nd gen foresters got the "sedan" width control arms. 1st gen are the narrow ones.
The 04-06 usdm sti arms are aluminum and add caster but maintain the same width.
jamal is offline   Reply With Quote
Old 06-14-2019, 06:49 AM   #11
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
that arm up there with my son is a first gen Forester arm and it measured the same 13 3/4" as an 05 Sti sedan arm. Unofficially because our measuring techniques aren't the best
Old 06-15-2019, 06:45 PM   #12
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Had a tie rid issue after I aligned it
Before
After. Moog ES800303 tie rods for 07-11 Honda CRV
