Welcome to the North American Subaru Impreza Owners Club Tuesday December 10, 2019
Old 11-30-2019, 01:34 AM   #1
TigOlbitties
Member#: 508879
2019 Subaru STi
Red
Default 2019 Subaru STi trunk w/o wing swap with 2018 Subaru STi trunk w/wing
Hi All,
I tried searching different forms but mostly only saw STi/WRX swaps.
I have 2019 STi w/o wing (has lip spoiler) and recently found a 2018 trunk w/wing. I think the swap is pretty straight forward but I'm having trouble understanding if I need to swap the torison bars as well? my current does not open all the way using remote unlock.
Online parts website does not show separate part numbers.
https://www.1stsubaruparts.com/v-201...and-components
any help would be appreciated!
TigOlbitties is offline   Reply With Quote
Old 11-30-2019, 11:27 AM   #2
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Good question. I bet the torsion bar on STI's with the large wing are beefier.
Scorpius is offline   Reply With Quote
Old 12-02-2019, 11:06 PM   #3
08redWRX
Member#: 186068
2019 STi
Just did this swap (went from wing to non-wing) and swapped the bars. Tested my wing trunk with his torsion bar (non-wing) and you could tell it didn't hold as well, but probably would've been fine. Took 5 minutes to switch them so just switched them to piece of mind. According to subie OEM site they use the same part #'s so not sure how they could be different but changing them just gives piece of mind.
08redWRX is offline   Reply With Quote
Old 12-03-2019, 03:41 PM   #4
rtv900
Member#: 428511
2016 STI
when I removed my wing I had to add a chunk of steel to the rear of the trunk inside to ballast it. I let the trunk loose once after removing the wing and I thought it was going to smash the rear windshield
rtv900 is offline   Reply With Quote
Old Yesterday, 12:55 PM   #5
Dale2011WRX
Member#: 304299
2018 2018 sti, black
2014 Crosstrek, tangerine
When I switched my 18 sti trunk lid for a 17 wrx trunk lid we had to change the torsion bars, and when we got them out you could see that the sti bars were definitely beefier than the wrx bars. Sucks because changing the torsion bars was way more difficult than just switching trunk lids.
Dale2011WRX is offline   Reply With Quote
